Old 12-06-2012, 07:56 PM   #71806
Sierra Thumper
Oddometer: 641
Originally Posted by Emmbeedee View Post
I don't see any separate gaskets but I'll ask them if they can sell me a couple. Seems a shame to have to buy a whole new cap just for that, though a Billet one might be nice. Of course, what would be the point of a nice durable Billet cap if its gasket went and I couldn't get a replacement?
I have to say my eye's light up when I saw those billet caps.....but I about shit a brick when I saw the price....50 bucks and they don't even lock? And when the gasket fails in a couple years I gotta buy a whole nother cap???
Fug that.........
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 12-06-2012, 08:01 PM   #71807
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,772
Fug that.........
I've sent an email to find out if we can get gaskets separately. Seems ludicrous that you can't.
"Don't play a lute to a cow" (Old Chinese Idiom)
Emmbeedee is online now   Reply With Quote
Old 12-06-2012, 09:29 PM   #71808
FuzzyNugs
Oddometer: 27
Originally Posted by TrophyHunter View Post
Grifter - Did the adjustable Tusk handguard mounts fit your bars? I have tapered bars and the mounts won't fit around the "still tapering" section. They have mounts for larger bars but they don't have adjustment...plus it adds to the cost. I used some old large bar mounts I had laying around for the time being.
I like the adjustability of the standard Tusk mounts so I'll grind 'em out when I set time aside. I could use longer screws but the contact points 'tween the mount and the bar would be minimal.
TH, I have tried the Tusk handguards on normal bars with a great fit and then on fat bars with their adapter kit. I had the same issue with them being slightly off on the tapering part. I just cranked them down extra tight, but in the end wasn't happy. Then I tried the Acerbis Rally 3 guards which don't have a metal spine and they were nice, but shifted on falls. Now I'm using the Highway Dirtbike guards and couldn't be happier. I'm finally learning to spend the money on the good stuff first. Seems I am always buying a replacement for the original, whether it be parts, gear, or tools.
FuzzyNugs is offline   Reply With Quote
Old 12-06-2012, 10:25 PM   #71809
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,373
I've not tried the HD guards ... but they look very good ... and are priced accordingly. But sometimes cheap is also good.
Lets do the math here ... my Tusk guards were $30 (few years ago). I've hit the ground with them at least 10 times that I remember. No serious crashes ... but fell on rocks couple times, whacked a couple trees and even hit a SUV mirror! (whoops ... sorry! ).
My Tusk guards shift a bit too when hit ... because that's exactly how I set them up. My levers and perches are the same ... all just snug, not super tight.
In a fall ...everything can move or rotate a bit, rather than snap off. Be sure to Loc-tite nuts and bolts. The guards shift when hit hard ... and I just force them back in position. Seems OK. This is an old Enduro rider trick on bike set up.
I believe Acerbis guards (the decent ones) are around $80 to $100 these days? I believe the Highway Dirt Bike ones are around the same?
I did not expect much from the Tusk guards ...but can't find much fault with them in the 3 or 4 years I've had them on the bike. I have them on my WR250F as well. Holding up fine ... and they've taken a real beating on that bike. My rating ? Cheap and Good ...! two things that rarely go together.
Old 12-06-2012, 11:16 PM   #71810
eakins
Butler Maps
eakins's Avatar
Oddometer: 14,425
Originally Posted by procycle View Post
The Clymer people finally got tired of listening to me carp on about the lack of an aftermarket manual for the DR650. I've been asking for this for YEARS.
I have one sample copy. It looks pretty good. I haven't had time yet to make sure they didn't replicate the errors in the factory manual.
ProCycle should have the first shipment of Clymer books in about 2 weeks.
nice job!
...Jeff, we're getting closer to you with our new Nor Cal map
Ozarks
, Nor Cal , COBDR shipping, AZBDR scouting
Facebook:
http://www.facebook.com/butlermaps
Old 12-06-2012, 11:35 PM   #71811
GSF1200S
Oddometer: 334
Originally Posted by opium89 View Post
How is it going to support anything if the starter shaft is bigger on the outside diameter than the inside diameter of the bearing? It's either going to prevent the starter shaft from going in that slot on the cover, or it's going to run right up against the inside race of the bearing. This really isn't making much sense to me at the moment. The inside diameter of that bearing is just a hair under 12mm. The starter shaft is 14mm. Quite simply, it ain't gonna fit! I also just confirmed that the part numbers for a 1999 and 2000 are the same. Lists the bearing as 12x28x8.
Here's something that's a bit odd...the breakdown of the starter in the parts fiche shows that it has a bit of a tip....If the starter actually had that tip, and it was 12mm, the bearing would make perfect sense. In my case, the end of the starter is completely flat and ends at the splines...like so:
UPDATE: I just fitted the new bushing and starter clutch next the the starter shaft. The starter shaft doesn't even exceed the width of the clutch. My verdict is this bearing and clip are COMPLETELY unnecessary. Does anyone disagree?
Im really glad someone brought this up. I had to replace my stator cover since there was a hairline crack that weeped oil. I changed to a 250w stator and all that, and the fitment of everything pretty much made sense.
However, while the stator cover had a bearing and retainer, and the starter shaft clearly extended into the center of the bearing (inner race), the starter shaft was CLEARLY smaller, to the point that the bearing itself would seem totally unnecessary. I put it back in anyways, but I scoured the manual, tried researching on google, etc and could not find any information about this. I figured if the bike made any weird noises when starting or when running, I would immediately tear the cover off and look for galling or damage. Sounds perfect. Even took the cover off due to paranoia and everything looked perfect.
Mine is a 2008 with low mileage and I dont believe the cover had ever been off.
GSF1200S is online now   Reply With Quote
Old 12-06-2012, 11:38 PM   #71812
GSF1200S
Oddometer: 334
Opium89, do you know what grenaded the 99 engine?
Old 12-07-2012, 07:07 AM   #71813
TrophyHunter
Oddometer: 918
Fuzzy - I couldn't get my head around HDB's price. I had Cycra's ($100) on the WR and appreciated them. My reasonably priced Maiers were well used and still functional, but had some bends in them. I changed the bike color to white and wanted to update things a bit.
I'll have to check out your HDB's on our next ride. SprintST had 'em on his DR when he was here. He had indicator lights installed in the holes which had a clean look.
www.dualsportmoto.com
2005 DR650
2013 HD Road King
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 12-07-2012, 07:44 AM   #71814
opium89
opium89's Avatar
Oddometer: 1,134
In lieu of a starter clutch torque limiter that absorbs engine kick-back, Suzuki in all their wisdom installed a solid idler gear for a year in the 99-2000 (98-99?) models. They went back to a starter clutch shortly after realizing what a huge mistake they made and everyone's cases getting grenaded.. This will most likely happen to every one of these models eventually. There's a lot of info about it on the Google machine.
http://bit.ly/TLIs7O
Tea parties are for little girls with imaginary friends.
opium89 is offline   Reply With Quote
Old 12-07-2012, 08:39 AM   #71815
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 7,438
Replacing my speedo cable because the jacket on the original was torn. Sure as shit, water was penetrating. Anyway, anyone know should the speedo housing at the wheel, be packed with grease on reassemble ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
*2010 FOREVER WEST*
NEW ENGLAND AND CANADA OFFROAD F800GS
14 DAY IDAHO ADVENTURE KTM 950
TRANS AM TRAIL WEST
TRANS AM TRAIL VID CLIP
THE DEAN OF WESTERN ADVENTURE ROUTES
DockingPilot is offline   Reply With Quote
Old 12-07-2012, 08:47 AM   #71816
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 2,039
Originally Posted by mrprez View Post
I had to cut mine off.
http://breakingbooks.wordpress.com
http://www.kenmarshallmetalworks.com/
2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
acesandeights is offline   Reply With Quote
Old 12-07-2012, 09:05 AM   #71817
procycle
procycle's Avatar
Oddometer: 1,597
Sweet!
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 12-07-2012, 10:04 AM   #71818
sunthechip
Oddometer: 39
headlight cover
Anyone know where I can get a headlight cover that is white and black? And any Ideas what type of windshield this is?
sunthechip is offline   Reply With Quote
Old 12-07-2012, 10:17 AM   #71819
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 428
Yep, Speedo drive should have grease in it. Packed in but not necessarily packed totally full.
Rick
Cogent Dynamics Inc.
motocd.com
NC Rick is offline   Reply With Quote
Old 12-07-2012, 10:46 AM   #71820
TrophyHunter
Oddometer: 918
Windshield - http://www.adventuremotorcycleparts....PUS06-ATT.html
Similar - http://www.nationalcycle.com/catalog...orScreens.html
I've never seen a two toned headlight surround. Not to say it doesn't exist but I'd just paint yours to your liking.
2005 DR650
2013 HD Road King
Times are GMT -7.   It's 04:34 AM.
