Old 12-20-2012, 04:09 AM   #72031
blackcap
blackcap's Avatar
Oddometer: 538
Originally Posted by procycle View Post
You don't have oil for your main air filter? Or maybe you are using motor oil on that as well. The problem with motor oil as opposed to proper air filter oil is it tends to drain out the lowest point of the filter so the filter has to be serviced more often.
In any case, I'm sure you could use motor oil on the secondary filter without getting any oil significant amount of oil into the top of the carb.
using proper filter oil on the main filter but running it as a long time between cleaning and oiling operation. i run the stock filter (simple and after trying other intake filter i didnt really feel there was any benefit except with the unifilter, but then i got scared off that when i saw the video of it letting water through after being oiled with notoil i think) nicely oiled with filter oil and wrapped with a pool filter sock that is also oiled. sitting in the bottom of the air box in a plastic zip loc bag are another 6 or 7 ready oiled pool filter socks and another oiled foam air filter that is in a plastic bag and wrapped up tight with tape to keep it from expanding and taking up all the airbox space. my maintenance routine is to check the air filter every oil change (or before if riding particularly dusty conditions) and if the filter sock is looking a little worse for wear, peel it off along with the majority of the dirt captured there, slip a new one over the reasonably clean foam filter and pop the old one into a separate zip lock bag inside the airbox. the spare air filter is there incase everything goes pear shaped with the original one. then when i manage to find somewhere that knows what air filter oil is, out comes the dirty filter and socks, everything washed in petrol, allowed to dry, re lubed and put back in the right place.
i found a husky dealer here selling belray oil a few days ago so everything got a refresh but that setup lasted me 40 000km without needing to buy anything and probably could have gone another 20 or 30 000 more. you gotta remember im currently in SE Asia and its pretty normal to completely remove airboxes and filters on just about any bike here so even trying to find someone that know what an air filter is can be difficult, let alone the right kind of oil.
"One must die sometime and to die with ones boots on is very noble" - Carl Stearns Clancy, first RTW motorcycle, 1912-13
Australia to Iceland on a DR650 http://oztoice.wordpress.com
and facebook https://www.facebook.com/oztoice
blackcap is offline   Reply With Quote
Old 12-20-2012, 04:15 AM   #72032
blackcap
blackcap's Avatar
Oddometer: 538
Originally Posted by ER70S-2 View Post
This has worked well for me, but I don't ride in extreme dust conditions. Even when completely dirty, there is no dust in the tube, or top of carb. It's easily cleaned and re-oiled. Idea by Rusty Rocket.
More info here:
http://www.advrider.com/forums/showp...9&postcount=82
this looks like it could work out nicely with a little piece of oiled stocking tied around the inlet or even just stuffed into the housing as a rudimentary prefilter. easily replaceable and easier to wash than the pleated unifilter design.
Old 12-20-2012, 04:26 AM   #72033
blackcap
blackcap's Avatar
Oddometer: 538
Originally Posted by motolab View Post
K&N has these little guys:
Not counting the spout, they measure about 1-1/2" X 1-1/2" X 1".
Regards,
Derek
and this is pretty much the answer to my prayers. ive had enough of spraying a small amount of lube into a bottle, wait for the foam to settle and gas to release and then spray again. takes ages to get a reasonable amount of oil from a pressurised can into a bottle and get the gas out. sitting the unpressurised bottle in boiling water accelerated the process though.
i dont suppose you Derek or Jeff at procycle sell these little beauties?
Old 12-20-2012, 04:27 AM   #72034
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,734
Cut the pool skimmer basket sock to fit this and rubber band it on. I did that with the K&N. I took this stock pod filter and fit it on the other unfiltered hose. Not sure if it accomplishes anything but what the hay.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is online now   Reply With Quote
Old 12-20-2012, 06:31 AM   #72035
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 3,215
Originally Posted by Cobain View Post
Some nice ebay pegs, $19 shipped
I have had these on my DR for over a year; 19.99 well spent
By God, Woodrow; it's been one hell of a party.
dogjaw is offline   Reply With Quote
Old 12-20-2012, 07:03 AM   #72036
kbuckey
Oddometer: 862
Originally Posted by Adv Grifter View Post
Thanks for the First Person comments. WoW! By now I've read quite a few problem reports with these batteries. In some cases the batt was faulty and Shorai replaced it free. But if problems are common then might be best to hold off at least until next generation.
I think we will get there on this type of battery ... eventually!
I gave up on my Shorai, too.
I went to a deposition and 6 (incredibly booooooring) hours later went out to the bike. Temp about 30. Wouldn't start. Turned lights on. Waited. No Start. Waited. No Start. A total of 10 to 15 minutes passes and it finally starts! Only seemed like an hour. It never actually failed me but that just sucks!
kbuckey is offline   Reply With Quote
Old 12-20-2012, 08:43 AM   #72037
MikeyP
Oddometer: 21
You could buy a full size equivalent and pour some in a smaller bottle if you need a travel size. I recently purchased this one after reading some reviews that the squeeze bottle is easier to get the oil where you want it.
K&N 99-5050 Filter Care Service Kit - Squeeze
MikeyP is offline   Reply With Quote
Old 12-20-2012, 08:52 AM   #72038
DockingPilot
Oddometer: 9,734
Originally Posted by kbuckey View Post
I went to a deposition and 6 (incredibly booooooring) hours later!
I do expert work sometimes and would rather have my teeth pulled. Last one for me was 7 hours and video taped.
Frank Reinbold
Old 12-20-2012, 09:04 AM   #72039
MikeyP
Oddometer: 21
Originally Posted by bross View Post
I've tried two Shorai's and won't be using any new tech batteries anymore. I had a Shorai in my CBF1000 and like Rob it wouldn't start the bike on cold mornings and cold meaning 50F in the morning in AZ. The last thing I thought I had to worry about last winter in AZ was my frigging battery. Battery died in my wife's DR200 so I put a new Shorai in that. We were on a tough dual sport ride with lots of starts/stops and the battery died and the bike needed to be bump started for the final day and all the way home. A few times with the battery fully charged, after a brief stop the bike would be completely dead, necessitating a bump start and then behave normally for the rest of the ride. And no it wasn't just a loose connection. Bikes been running fine with a good old lead acid battery back in it. Good article on the new batteries here, very technical but sill a good read...
http://www.advrider.com/forums/showthread.php?t=770364
Bottom line is I don't think these batteries are ready for dual sporting, at least for me.
I have a Shorai that the PO installed and at first I was having some issues with it running down pretty quick after not a lot of cranking if I was having a problem. I used my friend's charger to balance the cells and since then it's worked really well for me down to mornings in the low 50s but I haven't had an opportunity to try it near freezing. Here is the inexpensive charger he used, which is a general purpose hobby charger that has tons of modes to work on many battery types. The only trick is you need an adapter to work with the Shorai battery, but it's a cheap adapter.
Thunder ac680
Thanks for linking to the interesting battery thread. I'm only 5 pages in but enjoying it.
Old 12-20-2012, 09:15 AM   #72040
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,442
DisTech rocks!! And so do the tunes.
Glad to see that you're still checkin' in. Your earlier DR posts showed me how to contribute to the thread.
everybody here should have this bookmarked
http://advrider.com/forums/showthread.php?t=415263
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 12-20-2012, 10:07 AM   #72041
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,048
Give a little personal experience on Bikemaster Gel batteries: I had one in my TLR and it went bad after 1.5 years. The original battery lasted 6. Anyway, kind of pissed me off. When I called where I bought it they said don't worry they have a warranty (which I didn't know). They called me back the next day and Bikemaster was sending me a new battery..no charge. We will see if it last longer then the first one.
I got the new battery and decided to put it in my DR650 (same size) just to see how it did. Cranked it over better then the Yusa.
First one going bad might have been a fluke. who knows. But their customer service seemed pretty good.
Mongle is online now   Reply With Quote
Old 12-20-2012, 10:12 AM   #72042
motolab
motolab's Avatar
Oddometer: 2,742
I've got plenty in stock.
Regards,
Derek
motolab is offline   Reply With Quote
Old 12-20-2012, 10:29 AM   #72043
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,706
Mine disintegrated, so I cut up part of a used synthetic car-wash sponge into a rod shape, stuffed it in there, and coated it with the same filter oil that Uni air filters use (which are synthetic foam / spongy stuff). All I can say is that no dirt is getting past it, so it works for me for now.
Mambo Dave is online now   Reply With Quote
Old 12-20-2012, 10:34 AM   #72044
WilderRider
WilderRider's Avatar
Oddometer: 1,805
Shorai
I will weigh in with my experience on the Shorai battery.
I now have about 13,000 miles on mine and almost one year. Took it to Panama and back this fall. Worked flawlessly.
The only near issue I ever had was turning the bike on in 25 degrees here in Colorado on my way back. Took a second or two, but still cranked over. Not a problem. I am loving it.
RISK: "The loftier your goals, the higher your risk, the greater your glory."
WilderRider is online now   Reply With Quote
Old 12-20-2012, 11:06 AM   #72045
motolab
motolab's Avatar
Oddometer: 2,742
On second thought, K&N filter oil is meant for gauze, and may not be the best for use on foam. I can tell you that it's nowhere near as tacky as the foam filter oils I'm familiar with.
Regards,
Derek
Times are GMT -7.   It's 02:35 PM.
