Old 12-27-2012, 09:44 AM   #72181
doug s.
Oddometer: 1,314
Originally Posted by Rusty Rocket View Post
What do you have to do to allow for the extra stroke, so it doesn't hit the head?
when at top-dead-center, the top of the piston is in the same location as stock, it's yust that the crank journal is closer to the top of the piston, and the rod is shorter; so when the piston is at bottom dead center, it is further away from the top of the cylinder, thus increasing displacement...
doug s.
doug s. is offline   Reply With Quote
Old 12-27-2012, 09:54 AM   #72182
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 8,993
doug s.
Makes sense.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 12-27-2012, 11:06 AM   #72183
Feelers
Oddometer: 187
Question
doug s.
Does stroking the engine increase the amount of compression? It seems to me that it will. If so, would it still run on normal gasoline?
Would the stroker kit be available as a standalone kit without the big bore? It seems to me that wouldn't be a problem. It might have a tougher time at idle?
Is there an advantage of doing one vs the other assuming very similar final displacement?
I should probably be asking Jeff, but anyone with engine knowledge should be able to help I think.
Feelers is offline   Reply With Quote
Old 12-27-2012, 11:19 AM   #72184
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,351
Originally Posted by procycle View Post
I'm confident the stock trans will be up to it (with a billet 3rd gear set).
There's no reason to think it will need any more cooling than the current 790. It will gain a lot of internal cylinder area to shed heat. But really, a bigger motor doesn't just automatically make more heat. It depends on how hard you run it. With the longer stroke and more torque it should have an easy time of of it. In equal conditions a smaller lower powered motor has to be run harder to give the same performance as a larger more powerful motor.
According to physics, more power has a direct correlation to more heat , but as you said, the larger area should help offset that. I know given my propensity to pin the throttle on pretty much everything I ride, I'd be running it hard.
Old 12-27-2012, 11:32 AM   #72185
procycle
procycle's Avatar
Oddometer: 2,251
All things being equal, yes, a longer stroke will increase compression. I will modify the dish in the top of the piston to compensate.
This will never be a kit. In any case it would not work with the stock piston because the stocker is too long below the wrist pin. With the stock piston you could only increase the stroke a couple of millimeters before the bottom of the piston hits the crankshaft. The 790 piston is a much more modern design and has the necessary clearance under the piston.
As far as what is an advantage - It totally depends on what the goals are for the end result. Longer stroke makes more torque at the expense of rpms and vibration and depending on the motor can be more difficult or expensive than just a bigger bore.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 12-27-2012, 12:58 PM   #72186
procycle
procycle's Avatar
Oddometer: 2,251
Originally Posted by PPCLI-Jim View Post
So when is production gonna start on it?.... I am fairly certain there would be interest in this kit....
Sure, plenty of interest until we start talking about the cost. A bare minimal 900 kit - custom built crank & rod, modified 790 kit, gaskets, etc would run at least $3000. Add a cam, 3rd gear and whatever will be necessary to keep the clutch hooked up and it would easily go $4k-$5k or more.
Nope. Never going to be a kit but if someone else besides me is crazy enough to want to do this I'll be happy to help point them in the right direction.
Old 12-27-2012, 01:57 PM   #72187
Rusty Rocket
Life behind "Bars"
Oddometer: 8,993
Reminds me of the 750cc 2 stroke Maico single that Rick Sieman and DirtBike magazine built back in the last century
2009 DR650
Old 12-27-2012, 03:37 PM   #72188
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,706
doug s.
Your thinking is a little confusing. Using the same rod and piston would make the piston HIGHER in the bore.
Most stroked engines use a shorter compression height on the piston (distance from piston pin centerline to top of piston) to make up the diffrence so the piston doessn't hit the head. A 10mm stroker would have 5 mm more at TDC and 5 mm more at BDC. So- all things being equal you would make the compression height 5 mm shorter so the piston top ends up in the same location. By doing this you increase the stroke but the piston TDC height from crank centerline ends up being the same.
You can use shorter rods but that often leads to piston to crank counterweight clearance problems.
And yes, increasing the stroke increases the compression. More "swept volume" with the same compression volume = higher compression ratio. Compression ratio = Swept Volume + Compression Volume / Compression Volume.
Mongle is offline   Reply With Quote
Old 12-27-2012, 04:15 PM   #72189
procycle
procycle's Avatar
Oddometer: 2,251
You can't do it that way with most modern motorcycle engines because the wrist pin is already as high in the piston as is practical. There just enough room between the wrist pin and the cylinder head to fit rings with no extra distance available to make a shorter compression height.
Which is how this one is done with a 5mm shorter custom made Carillo rod. The thing that made it possible is the 790 piston which has a lot of counterweight clearance with the stock crank.
Old 12-27-2012, 04:18 PM   #72190
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 3,220
This post makes me appreciate my simple DR all the more. http://www.advrider.com/forums/showp...3&postcount=33
Every time a new thumper comes out I get excited and think it might be something to replace the DR. Then I read posts like this. All that just to change the oil.
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 12-27-2012, 04:23 PM   #72191
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,706
Yes, when we stroke the pin ends up being into the oil rings. No biggie though, you run a shorter pin with a support rail. Like so:
Two diffrent ways of getting the same tamato juice! We often go this route to keep rod length longer for geometry and because custom rods are more expensive then the pistons. Of course, you only need one rod...we need 8
Old 12-27-2012, 07:30 PM   #72192
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,351
What's the big deal, I use Rotella in my DR.
Old 12-27-2012, 08:17 PM   #72193
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,208
You could also run the stock length rods and use a cylinder spacer on the DR. Just another tomato juice.
We would do that on some bikes that could run stock rods on stroked cranks (two piece rods with plane bearings made it easier)Though somewhere i have a cylinder spacer for a stroked RZ350 laying around.
Not gonna work on your V-8's though
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 12-27-2012, 08:19 PM   #72194
YnotJP?
Oddometer: 2,363
We got many rods from Spade Carillo in the mid 1960's, for small block Fords and Chevys. Never had a rod problem.
They are a thing of beauty. Needing only one is nice. But, you should buy two, just to have one to hold and look at.
YnotJP? is offline   Reply With Quote
Old 12-27-2012, 11:40 PM   #72195
trailrider383
867-5309
Oddometer: 3,220
Say what?
Times are GMT -7.   It's 05:47 PM.
