Old 12-28-2012, 07:55 AM   #72196
amk
Oddometer: 496
Originally Posted by canoli View Post
So the ongoing struggle to get my Safari tank dialed in continues. When I last checked in you guys told me to fill it up and see how far I can get before it craps out. Seemed like the logical thing to do so I filled it with 33 liters (still had some in the tank when I rolled up to the gas station) and rode it for 275 miles. Then 5 miles from town in 108 degree heat, it stopped. It looked like I still had a lot of gas left so the only thing I could do was shake the bike a bit and luckily got some gas into the engine. Once at home I let everything cool down and I sprayed the carb inlet elbow with ALOT of WD40 and proceeded to empty the remaining gas into another container. When the Safari finally ran dry I found that it still had an additional 4 1/4 liters of gas remaining…and I was pissed. So I stripped the tank off grabbed a set of vice grips and cranked the elbow over to the 90 degree position. Was pretty happy that nothing snapped off and after I put the tank back on I re-routed the lines and removed the cheap inline filter I installed.
This is what it looks like now.
Does this look right to you? How bad is that bend in the hose?
Going out for a ride tomorrow and hopefully I can get another 50-60 miles before it goes dry. If not, I might be putting the Safari in the flea market and picking up a Acerbis. I really need the range and don't want to carry external containers if I don't have to.
Stay tuned and thanks again for your help.
Canoli
I cannot pinpoint you to the exact cause of the problem, but the theory of problem solving is simple enough. DR does not have a gas pump, i.e. gas flows free to the carb by its weight and atmospheric pressure.
So the first one is to make sure the carb's inlet is below the petcock. The last usually has a pipe of 5 cm. height inside the tank, so everything under the the pipe is stayed there forever and cannot be used.
Second, make sure the gas inside is under the atmospheric pressure, the breather is not blocked etc. Just take the gas cap off and depress start button again.
Third, remove all barriers between tank and carb's inlet, i.e. filters, here I am not sure, but there probably is a small oem one right in the tank petcock or in the carb. Take the petcock out, open it, disconnect the hose from inlet and blow into petcock, should be no resistance to the air flow.
It is one of three reasons, which one is yours? It actually may be all 3 of them simultaneously.
amk is offline   Reply With Quote
Old 12-28-2012, 09:59 AM   #72197
Kommando
Kommando's Avatar
Oddometer: 7,390
This is what it looks like now. Does this look right to you? How bad is that bend in the hose?
Not quite right. The DR and other carbed bikes are primarily fed by gravity. There's a bit of suction/siphon going on too, but the primary method of getting gas into the carb from the tank is by gravity feed. As long as there is no kink or blockage in the line, you basically just want the fuel to NOT have to flow uphill to get into the carb. Suction will overcome a little bit, but it can also allow air-bubbles to get into the line and affect fuel flow. The flow from my petcock to my carb is all either down or sideways. There is no uphill flow. As long as my tank is venting ok, I have no flow issues. I can run my tank pretty dry. Route your fuel lines so that there is NO uphill flow. If you can't do that, you may want to install a fuelpump.
Kommando is offline   Reply With Quote
Old 12-28-2012, 09:59 AM   #72198
TRAVELGUY
Old Traveler
Oddometer: 717
I had a temporary problem with emptying my safari also. Was getting a vapor lock at the aftermarket filter I had installed. Changed to a different filter and all went well. When the vapor lock happened I could just blow into the tank vent and clear the vapor lock then tank would empty. When I disconnect my fuel lines from the carb to drain my safari the tank totally empties.
Hope this info helps.
TravelGuy
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 12-28-2012, 10:56 AM   #72199
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,864
Do Acerbis tanks have this much of a problem emptying fuel?
Mambo Dave is offline   Reply With Quote
Old 12-28-2012, 11:02 AM   #72200
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Canoli
Looks like you have a "L" right angle fitting there, and then your fuel hose has to go UP HILL to the Carb. As long as you have a bit of fuel pressure (head) in your tank, it's likely you can use most ... but maybe not all of remaining fuel in your Safari.
QUESTION: Does the Safari not have a reserve? If not, perhaps you could fit a different Petcock ... one with a reserve intake that is LOWER than the current one in the Safari. This should give extra range.
Question 2 : Does the Safari have TWO petcocks? (right and left side)
I went through similar problems with my IMS tank. I also had to remove an inline aftermarket filter and had to rotate metal Carb intake pipe. All this helped, along with cleaning my dirty Petcock filter. But on your NEW tank should not be an issue ... yet.
I've retained the stock Carb inlet filter in the metal tube ... but I carry TWO
spares when on the road. One load of bad gas will CLOG this tiny filter ... so keep an eye on it. Usually it can be easily cleaned. Sometimes not, hence carrying a spare.
Now ... with my IMS tank ... I can go to about 220 miles before reserve. And what was once just 10 to 15 miles on reserve is now up to 32 miles.
Cleaning the petcock made the BIGGEST improvement. So now up to just over 250 miles until DRY. (although still about a 1.5 liters left unused) Not perfect but better. 220 miles is fine for me and what I do. PLAN AHEAD!
Good luck!
Old 12-28-2012, 11:27 AM   #72201
neo1piv014
ADV in training
Oddometer: 627
Looking at my Acerbis4.9 tank, it appears that the petcock actually sits below the level of the intake on my carb. Anyone else notice this? I can't actually hook up the fuel line without there being a bit of an uphill climb to it or a bend.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 12-28-2012, 11:38 AM   #72202
George 99
George 99's Avatar
Oddometer: 787
Don't know if this could help, but... I have pressurized the gas tank on my ST1100 with lung power and piece of hose to get fuel to the carbs when the 'lectric pump failed. Not recommended for a long trip, and do remember to remove the hose from yur mouth before ya inhale.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 12-28-2012, 12:43 PM   #72203
Ren20
Finding Touge
Oddometer: 111
Is this an IMS or Acerbis tank? Seller claimed to be acerbis. But look IMS to me. I think acerbis is more angular, correct?
Ren20 is offline   Reply With Quote
Old 12-28-2012, 12:49 PM   #72204
adventurebound9517
Oddometer: 339
I just purchased the acerbis tank and it looks the same to me. You will know for sure when you fill it up.
adventurebound9517 is offline   Reply With Quote
Old 12-28-2012, 01:25 PM   #72205
Phreaky Phil
Oddometer: 1,929
Canoli
This seems to be a common problem. When I fitted mine I had it the same as yours and when I hit reserve the bike would die even though I had changed to reserve. I had to blow down the tank vent to get fuel into the carb before it would go again.
What you need is a longer hose between the T piece and the carb and it needs to loop down and back up to the tank. This cures it. Straight in like you have it seems to cause an airlock. With the hose going down hill there is always some fuel in it.
Phreaky Phil is offline   Reply With Quote
Old 12-28-2012, 01:41 PM   #72206
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,945
My Acerbis tank is a 5.3 gallon. The petcock is above the intake on my carb, but I have a TM 40.
Old 12-28-2012, 01:42 PM   #72207
Cobain
night owl
Cobain's Avatar
Oddometer: 132
Thats the one on craigslist right, in spokane?
Cobain is offline   Reply With Quote
Old 12-28-2012, 01:47 PM   #72208
Ren20
Finding Touge
Oddometer: 111
Yea, Spoken with the seller. He confirmed it's an acerbis. Only wish He posted pictures of different angles.
Old 12-28-2012, 01:52 PM   #72209
acap650
acap650
acap650's Avatar
Oddometer: 734
Originally Posted by ren20 View Post
is this an ims or acerbis tank? Seller claimed to be acerbis. But look ims to me. I think acerbis is more angular, correct?
ims
acap650 is offline   Reply With Quote
Old 12-28-2012, 01:57 PM   #72210
canoli
human
canoli's Avatar
Oddometer: 1,793
Thanks I'll put a "loop" back in it.
Canoli
canoli is offline   Reply With Quote
Times are GMT -7.   It's 05:47 PM.
