Old 12-30-2012, 04:52 PM   #72316
dickensheets
smprparatus
Oddometer: 278
Originally Posted by Albie View Post
Oh look, 8 posts. You must be a n00b.
Murcan????
Ok off to get the dictionary. Again. I wish I was more read sometimes.
dickensheets is offline   Reply With Quote
Old 12-30-2012, 04:56 PM   #72317
dickensheets
smprparatus
Oddometer: 278
Ok I don't get it. WIKIPEDIA doesn't know about the Murcan. I feel left out. What's a murcan.
Old 12-30-2012, 05:24 PM   #72318
barko1
barko1
barko1's Avatar
Oddometer: 3,332
A region in the brain stem that is supposed to regulate sexual response. Dysfunction = trouble
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 12-30-2012, 05:33 PM   #72319
sunthechip
Oddometer: 126
tire leak
I was riding and the bike started to loose traction. I checked an there is a screw that went straight into the tire. I got my pump and put some air in the tire. The part with the screw in it isn't leaking any air, but the area around the tire nipple is. Any Idea what is going on?
sunthechip is offline   Reply With Quote
Old 12-30-2012, 05:38 PM   #72320
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 3,259
The screw punctured the tube and the air is coming out around the hole in the rim that the valve stem pokes through.
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 12-30-2012, 05:41 PM   #72321
joefromsf
Dark Happens
joefromsf's Avatar
Oddometer: 1,536
Screw went thru the tire and then punctured the tube. Air is leaking from the tube where the screw punctured it, but the path of least resistance to escape the tire is the gap around the nipple. The screw has made a pretty good seal in the tire.
joefromsf is offline   Reply With Quote
Old 12-30-2012, 05:45 PM   #72322
doug s.
Oddometer: 1,320
Originally Posted by ndthl View Post
Has DRJens or anyone swapped a xf650 engine into a dr650?
I need to fix the gearbox and engine on my dr and found a xf engine, both are same model year (1997). Has anyone made this swap before?
I am in Queensland, Australia.
What would I have to modify on the engine to make it fit? Other posters here have said that I might have to swap the head as the xf has 2 carbies. Would I just be able to swap the head from my DR onto it? I am not a mechanic, pardon my n008 questions.
Wil
while i dunno for sure, i can't imagine there'd be much (if any?) mods needed as the engines are identical except for the heads. if i were contemplating this swap, i'd be more interested in finding the dual-carb set-up from the xf rather than swapping heads to get your single carb to fit. the xf heads have bigger valves, why would you want the smaller valve heads of the dr?
doug s.
doug s. is online now   Reply With Quote
Old 12-30-2012, 06:23 PM   #72323
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 163
Originally Posted by Sierra Thumper View Post
If I'm going to spend 5200 bucks on a bike its going to be a clean low mileage KTM....
More power to you. I would never attempt to tell anyone what (model) bike they should buy; but for what I'm going to be doing with MY DR650, you probably wouldn't want to do on any $5000 GayTeeEmm? See below:
http://www.advrider.com/forums/showt...=556240&page=6
http://www.advrider.com/forums/showt...=669987&page=3
http://advrider.com/forums/showthrea...ight=Francisco
VooDooDaddy is offline   Reply With Quote
Old 12-30-2012, 07:16 PM   #72324
procycle
procycle's Avatar
Oddometer: 2,280
Murcan????
First you've got to spell it right. Merkin
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 12-30-2012, 07:16 PM   #72325
ER70S-2
ER70S-2's Avatar
Oddometer: 6,296
Originally Posted by VooDooDaddy View Post
......you probably wouldn't want to do on any $5000 GayTeeEmm?
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 12-30-2012 at 07:23 PM
ER70S-2 is online now   Reply With Quote
Old 12-30-2012, 07:19 PM   #72326
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,155
Originally Posted by S.ROB View Post
I made it through the first 1900 pages. Can't lurk any longer, purchased my first DR in Feb of 2012.
A 1990 250 sold it in April, purchased a Blue 2005 650 with 4200 miles two weeks later.
Close to stock, I shimmed the needle,desnorkled. removed the brass cover off the air fuel mixture screw,
KN air filter,renthal bars,acerbis hand guards,250 tail light. also in the process of making a skid plate.
Thanks for the helpfull information. still got some pages to read.
Scott
Welcome to the asylum.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 12-30-2012, 07:22 PM   #72327
Rusty Rocket
Life behind "Bars"
Oddometer: 9,155
a murcan.
sat that ^^^^ many times quickly. = "american" cuz we are able to own guns.
Then say,.... oh-wah, tah-jer, kiam.... many times fast. If you don't get it, PM me.
2009 DR650
Old 12-30-2012, 08:26 PM   #72328
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 2,417
What the heck!
Repleced the snapped head pipe with a FMF PowerBomb. After the install and a short ride retorqued the header bolts. Admit I don't know the tq spec but thought they were damn tight.
Rode little over 100 miles today and when bike cooled checked the status of the header as someone mentioned that things may have been too tight without enough flex as a reson the OEM snapped at 6000 miles.
Well the new header was loose, no problem just tighten back up...except one of the bolts is missing.
So....what is the tq spec and why did one vibrate completely out?
Any day on a dirt road is a great day
blk-betty is offline   Reply With Quote
Old 12-30-2012, 08:44 PM   #72329
Phreaky Phil
Oddometer: 1,816
Originally Posted by blk-betty View Post
What the heck!
Locktight is your friend. Without locktight or a lock washer, most things will vibrate undone. Heating and cooling makes things even worse.
Phreaky Phil is offline   Reply With Quote
Old 12-30-2012, 09:39 PM   #72330
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
What the heck!
I don't know the torque spec ... but if in doubt tighten it up where you had it on the install ... but this time USE LOC TITE! It will stay put.
Times are GMT -7.   It's 09:09 AM.
