Old 01-17-2013, 02:55 PM   #72916
motolab
motolab's Avatar
Oddometer: 2,852
Originally Posted by Adv Grifter View Post
By my "seat of the pants" evaluation, it's tuned fairly close. But as mentioned, my DJ needle shows some wear, may need replacement?
In the pics, the DJ needle looks like it's made out of stainless steel, so it won't wear all that rapidly, but that does mean that if wear is visible, other parts, such as the emulsion tube, slide guide and slide are likely to have borne the brunt.
And this bike has not been on the dyno.
Would you like it to be?
Given my basic tuning set up ... what needle would you recommend to maintain status-quo or maybe go one better?
If you want to maintain the status quo, put another DJ needle in it. If you want better, try the non-USA oem needle or the KTM needle. However I would inspect the carb and replace any other worn parts first. If you do go with other than the DJ needle, be prepared to start over with your tuning.
Regards,
Derek
motolab is online now   Reply With Quote
Old 01-17-2013, 03:17 PM   #72917
Trbig67
Oddometer: 108
Problem... I rode the bike one day and everything was fine. Next day when I started it, it was puking oil out everywhere. I found out that the seal around the shaft the front sprocket is on has popped out. I tapped it back in place.. seemed like a nice tight seal, started it up and watched it get slowly pushed right back out again and oil dump all over. Why is the crankcase building up this much pressure? Plugged hose/vent somewhere? I don't know where the vent is on this thing.
Thanks.
Trbig67 is offline   Reply With Quote
Old 01-17-2013, 03:57 PM   #72918
BergDonk
BergDonk's Avatar
Oddometer: 3,925
Thanks.
This is not unknown. It happened to me on a cold start so I made a mechanical retainer. I ended up making and selling a stack more. I don't do them anymore, but Procycle does. Get one, bolt it on and problem fixed. And for others out there, do it before its a problem as insurance, because when it happens it really is a PITA.
My story starts at #197 here:
http://www.advrider.com/forums/showt...646076&page=14
There is more over on DRR:
http://drriders.com/topic5922.html
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 01-17-2013, 04:02 PM   #72919
Trbig67
Oddometer: 108
So there isn't a plugged vent somewhere? This is just one of those inherent things of the bike?
Old 01-17-2013, 04:03 PM   #72920
Trbig67
Oddometer: 108
And.. I've never seen what you're talking about on the regular DR650 page of Procycle. Is it listed somewhere else? Does it have an official name?
Old 01-17-2013, 04:17 PM   #72921
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Look again - it's there!
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 01-17-2013, 04:26 PM   #72922
Trbig67
Oddometer: 108
FInally found it. Thank you.
Old 01-17-2013, 06:37 PM   #72923
Load Clear
Oddometer: 35
Rear Brake Lever
Hey guys - are rear brake pedals all the same? Bent mine up pretty good and plan to put a new one on.
Load Clear is offline   Reply With Quote
Old 01-17-2013, 07:03 PM   #72924
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,295
Originally Posted by Rusty Rocket View Post
Looks like TinkerinWstuff is tinkering with stuff again. Hope you didn't get a hernia lifting that motor out.
that thing isn't too bad.
This was as far as I got by 5pm today. Maybe have it wrapped up tomorrow if I'm ultra super lucky.
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 01-17-2013, 07:07 PM   #72925
LucasLeader
LucasLeader's Avatar
Oddometer: 296
I've never seen an aftermarket replacement. I think it's just mild steel so you should be able to bend it back into shape. I've had to do it with my shift lever.
LucasLeader is offline   Reply With Quote
Old 01-17-2013, 07:25 PM   #72926
ER70S-2
ER70S-2's Avatar
Oddometer: 7,247
The question has been asked: "How heavy is the DR engine?" You could tell us here AND post it up in Krusty's DR Index (Hiya Krusty, thanks again for the DR650SE INDEX ). Or you could let us down and be forgotten forever.
Here: Topic 12:
http://www.advrider.com/forums/showp...2&postcount=32
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 01-17-2013, 07:42 PM   #72927
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,946
I bought two of the first batch Procycle made up.
Old 01-17-2013, 07:46 PM   #72928
TinkerinWstuff
Take it apart
Oddometer: 1,295
Here: Topic 12:
I will see what I can do!
I just know it should be 1ounce lighter now than it was before
1999 Suzuki DR650
Old 01-17-2013, 09:03 PM   #72929
ER70S-2
ER70S-2's Avatar
Oddometer: 7,247
Tank ewe.
I'm sure you're correct. Removing all that alum from the piston for valve clearance must be good for a multiple of pounds.
2013 WR250R
Old 01-17-2013, 10:18 PM   #72930
Thumper Dan
Oddometer: 329
noob question, why do you have to remove the motor to put the new high comp piston in? Can't it be done whilst motor is in the bike?? I'm sure there is another reason.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Times are GMT -7.   It's 08:39 PM.
