Old 01-18-2013, 02:48 PM   #72946
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,741
two questions. i have 32k miles on the '06 DR, she's due for some carb work. stock needle jet is Y-5M but it's also $40 and i dont wanna spend $40 on a frickin needle jet unless it's made of unobtainium. also need a float needle and they're only sold with the float "assembly" whatever the hell that means... i'm running the KTM needle so i'm willing to give the X-6 needle jet a try, i suppose.
i need alternative Mikuni part numbers for the following items please:
needle jet and float valve needle and a source. thanks.
(please dont try to sell me a DJ jet kit, neither of these items is in one..)
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed screwed with this post 01-18-2013 at 02:49 PM Reason: alternative not replacement
vintagespeed is offline   Reply With Quote
Old 01-18-2013, 03:02 PM   #72947
procycle
procycle's Avatar
Oddometer: 2,252
Moose racing has a "rebuild kit" that includes these items. Any Parts Unlimited dealer can get one for you. I'm certain the contents are not genuine Mikuni but probably will fit your budget.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 01-18-2013, 03:03 PM   #72948
robndeb
Oddometer: 3
Originally Posted by procycle View Post
Doing your own work and making your own decisions you can take that gamble if you want to. If or when there is a problem down the road you won't have some else to blame.
Also, learning how to, and doing the work yourself guarantees that it
is done right. I don't trust anyone to work on my DR.
robndeb is offline   Reply With Quote
Old 01-18-2013, 03:03 PM   #72949
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,160
Gold Valve Installation
Hey... I can't seem to find the threads for the Index; sure wish they were stickied at the top of Thumpers. I was wondering where there might be some write-ups on Gold Valve installation. My Fork Solution kit from ProCycle arrived yesterday and I was just looking at the instructions and thought, yeah, I need a write-up. :) I thought there was supposed to be a video, but there wasn't one in the package.
Local shop wants $275 to install them (HAHAHAHAHA) so I definitely will be doing this myself.
Rob
'12 Suzuki V-Strom DL650
'10 Kawasaki KLX351S #320
'96 Suzuki DR650
'92 TW200
Rob.G is online now   Reply With Quote
Old 01-18-2013, 03:19 PM   #72950
procycle
procycle's Avatar
Oddometer: 2,252
Take a look here
--> http://www.procycle.us/info/articles...k-upgrade.html
Old 01-18-2013, 03:20 PM   #72951
Sierra Thumper
Oddometer: 641
I don't let ANYONE work on ANY of my bikes........EVER
It almost impossible to find anyboby that can do ANY work properly anymore.....the art of knowing you're job and having pride in it has died in america
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 01-18-2013, 03:26 PM   #72952
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,160
Thanks, Jeff!!
Edit: What's the poor-man's version of the damping rod holder tool?
Rob
'96 Suzuki DR650
'92 TW200
Old 01-18-2013, 03:29 PM   #72953
procycle
procycle's Avatar
Oddometer: 2,252
This is only true if the person doing their own work actually knows what they are doing. Which is not all that common.
Not to put any disrespect on the original poster but he seems to want to leave the half trashed rod in the motor.
Old 01-18-2013, 03:31 PM   #72954
motolab
motolab's Avatar
Oddometer: 2,530
You can get one for less than that.
You can get one as part of a rebuild kit.
The X-6 emulsion tube's outlet will be .055 mm (.0022") smaller than the Y-5M's. If the WOT CO trace showed an overly rich mixture in the low to low mid rpm range with fresh components, then perhaps a smaller emulsion tube would be a good idea, but keep in mind that a change of .055 mm is pretty large. Also note that the Y-5M emulsion tube, being nickel plated, will be much more resistant to wear than the X-6.
Since emulsion tube wear is caused by slide guide wear, I would recommend replacing the slide guide. I would expect it to be worn out just based on the mileage. Also inspect the slide for needle hole enlargement/ovaling and grooving on the downstream side.
Have a look at http://www.advrider.com/forums/showthread.php?t=528038.
Regards,
Derek
motolab is online now   Reply With Quote
Old 01-18-2013, 03:34 PM   #72955
BergDonk
BergDonk's Avatar
Oddometer: 3,381
But at least when we stuff up, we know who to blame, and we've learn't how to get it right next time, one way or another, if it wasn't fatal.
I rarely get anyone to work on any of my stuff, and on the odd occasion I do, its stuffed up 4/5 times anyway and I wonder what I was thinking. And that's not just machinery.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 01-18-2013, 04:18 PM   #72956
TrophyHunter
Oddometer: 2,167
http://www.advrider.com/forums/showp...ostcount=36300
Check the link to Distech's write up for the bolt tool but I think others here posted a 1" square tube will also hold it.
Jeff - you and Distech pulled the tubes apart. My memory is slippin' but I don't think I pulled the tubes since none of my seals were acting up. I think I did the factory lowering on my son's bike without pulling them, too.
Am I remembering incorrectly - can you pull the damper rod without removing the seals & separating the tubes?
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 01-18-2013, 04:28 PM   #72957
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 3,951
Yes, damper rods can be removed without separating the tubes.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 01-18-2013, 04:38 PM   #72958
Richguzzi
Richguzzi's Avatar
Oddometer: 63
I do believe I have to agree completely on that one. The 18 year old kid that works the parts counter and also puts in time back in the shop is not going to care about my bike. Last time a bike of mine saw the inside of a shop, 1984, it came back with a couple of big scratches and they told me nothing was wrong with the motor. A couple of weeks later when I pulled the head and cylinders because I knew something wasn't right I found the piston pin clip missing and the pin had been gouging the cylinder wall. They didn't do it but they told me it ran like it was supposed to when I told them it was making a noise and down on power....
2012 DR 650
1986 Cagiva Alazzurra Tracker/Fighter/Cafe/Brat/Bobber project
1971 Moto Guzzi Ambassador
Slow old grey haired guys with arthritis and other ailments rule!
Richguzzi is offline   Reply With Quote
Old 01-18-2013, 04:57 PM   #72959
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,847
Rob
FYI, I got the fork solution kit and rear shock shaft assembly. I called a couple places in town just to ask about recharging the shock and was given the name of a guy that works out of his house. I called him to ask about recharging the shock and after talking to him about his experience, and based on what three shops in town said, I let him do the work. He charged $150 to do the front and rear (front fork solution kit and rear shock shaft assembly). It would have been $100 if I pulled the forks and rear shock and brought those to him, but I figured if I went that far I'd do the whole job, so I dropped the bike off at his house and should have the bike back Sunday.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 01-18-2013, 05:13 PM   #72960
procycle
procycle's Avatar
Oddometer: 2,252
+1
Yes, indeed.
Times are GMT -7.   It's 11:37 AM.
