Old 01-18-2013, 09:51 PM   #72976
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Feelers View Post
I used these pieces and it worked great.
18inch long piece of black 3/4inch I.D. pipe threaded on both ends
4inch long piece of black 3/4inch I.D. pipe threaded on both ends
1 90 degree elbow
A threaded brass cap 1 1/8inch flat to flat. Which looks like this:
http://s3.pexsupply.com/images/produ.../c74-147-1.jpg
That solution will work for sure ... but I might suggest trying the lazy cheapskate's trail side method:
stabilize fork on bench or whatever (or have a helper hold it)
insert correct hex/allen key into damper rod bolt at bottom of fork .
Have someone hold Allen in place ... now Whack it with a hammer! (counter clock please!) Do NOT hit your helper with hammer!
The sudden shock can usually break loose the Damper rod bolt from the damper rod ... without it being held from the inside. Worth a try.
If not ... try the above tool. Also, an air wrench can also work on this same principle. I've done the lazy man's method three times on my DR with success. TIP: when you put it back together do not OVER tighten bolt into damper rod and don't use Loc-Tite.
NOTE: This may not work for KYB forks built on Tuesday by that grouchy guy who over torques everything that passes by. My forks were built by a cute 17 year old girl on a Friday. Gentle hands!
Adv Grifter screwed with this post 01-18-2013 at 10:15 PM
Old 01-18-2013, 10:23 PM   #72977
motolab
motolab's Avatar
Oddometer: 2,777
Originally Posted by ER70S-2 View Post
There was a question about removing the idle fuel screw plug over on DRRIDERS.com. I posted a link to Jessepitt's photo essay on the procedure: http://www.advrider.com/forums/showp...5&postcount=71
A couple of points to mention:
1) It is likely that the drill will pull itself into the fuel screw when it breaks through the far side of the plug. The result can be just a little nick, mostly ruining the head, or somewhere inbetween. The way to avoid this is to use a drill stop, which, when properly set, will prevent the drill from going any further when it breaks through.
2) I've seen quite a few cracked/broken fuel screw wells. These are the result of the plug cocking as it is being pulled out. The way to avoid this is to tap the hole (I use a M4X.7 tap, which takes a 3.3mm or #30 drill). Grind the point off of the tap (if it has one) for clearance with the head of the fuel screw. Tap only deep enough to get through the plug. Then use a metal tube with squared ends and an ID just larger than the OD of the plug in conjunction with a screw and a washer with the same or larger OD than the tube as a puller to extract the plug. This way it is guaranteed to come out squarely.
3) Shimming the needle clip richens the mixture by lowering the slide rather than by raising the needle (except when the slide is against either stop), as the shim increases the preload on the slide spring.
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-18-2013, 10:50 PM   #72978
LeDakaR!
LeDakaR!'s Avatar
Location: route66moto.com San Francisco CA/ Austin, Texas
Oddometer: 448
Got back from Death valley on my DR and loved my wolfman/ramount/teknic/kolpin gear...
if any of you fellow riders want anything let me know...ill hook you up!
RIP Benjava, I finally did Alaska, thanks to you
www.route66moto.com
moto rental/sales and tours, location et vente moto, import-export
LeDakaR! is offline   Reply With Quote
Old 01-18-2013, 11:00 PM   #72979
zoid
Dirty Old Hippie
zoid's Avatar
Oddometer: 1,257
How about more pictures?
zoid is offline   Reply With Quote
Old 01-19-2013, 01:19 AM   #72980
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Originally Posted by procycle View Post
There are 2 reasons why you don't see grips on the DR page. First, I like to keep the number of 'general' items that folks can usually get at any shop to a minimum - especially on the pages that are so filled out like the DR page. Second, for most folks replacing grips on the DR for the first time can become a nightmare of a job.
Some day we'll have some separate pages for our favorite general items.
I want the ProGrip foam rally grips.
No-one has them
NordieBoy is offline   Reply With Quote
Old 01-19-2013, 04:18 AM   #72981
greer
Oddometer: 3,836
Shipping may cost a war pension, but Amazon and Phat Performance show them in stock.
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 01-19-2013, 04:20 AM   #72982
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,797
Re: grips...
I may have to replace mine eventually when I change bars, but I'm certainly not going for foam grips (that nobody has) when this 'solution' has worked for me on two bikes and many miles so far:
Tightly wound in a spiral, these cushion and leave no noticeable pressure points that had my hands tingling after many miles with traditional grips.
And, they're wider than most grips - I don't even have big hands, but I find this far more comfortable.
Yeah, yeah, I wish I had some other color rope to change it... sorta... but it's what I had on hand from the limited choices Home Depot had that day. (Of course within days they had most colors available again.)
If even only as a stop-gap until you can find foam grips, I think if its comfort you're looking for, you might try this out.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 01-19-2013, 07:01 AM   #72983
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
I got this response, thanks Jesse.
Jessepitt should do a manual for us rookies. These photos are fantastic!!!!
This is the definitive answer to "THE CAP OVER THE STOCK NEEDLE ADJUSTMENT SCREW."
Even I can do this now!!!
If you don't understand this. You might seriously consider taking the bike to a shop or have someone show you.
jessepitt is offline   Reply With Quote
Old 01-19-2013, 07:05 AM   #72984
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,824
Fellas,
Can the carb inlet tube on the stock BST be rotated ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 01-19-2013, 07:15 AM   #72985
neo1piv014
ADV in training
Oddometer: 621
I've probably read your suspension rebuild articles a hundred times each, since those are the upgrades I'm likely to do in the near future. Very, very well written.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 01-19-2013, 07:17 AM   #72986
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Regards,
Derek
If you look at the write up you will see that I use a drill bit with an old, dull counter-sink collar on it for grip and drill it by hand. There is really no way to loose control and damage the screw. I dont even drill all the way through the plug. The plug has a tiny hole already drilled in it which acts as a pilot for the drill bit but also allows a small fine thread screw to be turned a couple threads in if you leave a little bit of the cap when you drill.
Prehaps I should remove a small amount of the spring in order to counter the increased preload?
Old 01-19-2013, 07:26 AM   #72987
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 4,042
Originally Posted by DockingPilot View Post
Fellas,
Carefully, yes. You want to be sure and have a good bite on the tube or it can bend. When I had a stock carb I believe I used a large adjustable wrench on the tube and once it "cracked", I was able to rotate it without harm.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 01-19-2013, 07:48 AM   #72988
Porky
Don't Pass Gas
Porky's Avatar
Oddometer: 497
Originally Posted by Mambo Dave View Post
Re: grips...
GREAT IDEA
Have been thinking about thicker grips but want to retain my Cramp Buster. Your idea will enable me to keep my Buster.
'08 Suzuki DR650
'15 Yamaha FZ 07
No fat chicks, fender will scrape.
Porky is offline   Reply With Quote
Old 01-19-2013, 08:00 AM   #72989
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,535
Originally Posted by LucasLeader View Post
My bike does the same thing. Doesn't burn up a noticeable amount of oil and stops smoking after a minute. It's been doing it a lot less lately too. I think the only problem I have with it is being a little embarrassed when I'm warming up my bike and spitting smoke at people walking by me.
Same here. My '96 has 20K miles on it. Only after a long period of not starting.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 01-19-2013, 08:08 AM   #72990
Rusty Rocket
Life behind "Bars"
Oddometer: 9,535
Wow! Just the right colors. U should be selling that rope and idea on the KLR forum, you'll be able to retire in no time
Re: grips...
2009 DR650
Times are GMT -7.   It's 05:29 AM.
