Old 01-21-2013, 06:02 AM   #73066
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,951
Originally Posted by tbrduc View Post
Hello,
it seems that this thread is about 'newer' DR's.
Mine is a '92 and as you know, different in many ways.
I tried searching for older models but the search engine here wasn't helpful
Where can I find data here on the older models?
It's basically stock, except for a JE piston, tires and airbox-jet modes from Uncle Jesse.
thanks.
http://www.advrider.com/forums/showthread.php?t=61568
Old 01-21-2013, 06:19 AM   #73067
mrprez
KJ4WMZ
Oddometer: 1,265
Originally Posted by acesandeights View Post
Yes, it's stiff in fact, but doesn't feel like it's riding on the spring. That's how it felt in stock form like it was riding solely on the spring.
I rode again today and went over a little dirt jump the kids around the neighborhood use on their bicycles. I didn't jump it due to all the mud, just up and over a few times as if it were "whoops". My bike follows the terrain really well. Both tires stay planted to the ground. I know what you mean by the pogo because that's what my stock suspension felt like, but a really soft pogo stick. Now it's a stiffly, firmly planted, completely connected to the ground feeling. I'm still not sure whether it's a little too stiff, but I'm almost thinking riding for the last 18+ months with the stock suspension has made me forget what a good set up should feel like. Mine feels like the compression is stiff and the rebound just sticks the bike to the ground...no pogo. Hope that helps. BTW, when are the tires coming again!?
I just checked the sag, it is more than it should be so I'll add in some more preload and see what gives give. I'd like to get this to ride somewhat like my DRZ did.
Tires? Probably sooner than you'd think!!!
How's the coffee?
John
Sent via morse code
mrprez is offline   Reply With Quote
Old 01-21-2013, 07:57 AM   #73068
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 4,095
Originally Posted by mrprez View Post
How's the coffee?
John
Gone
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 01-21-2013, 08:10 AM   #73069
mrprez
KJ4WMZ
Oddometer: 1,265
Gone
Sorry....good stuff.
I just got back from a test ride after resetting the sag on the rear shock. Pogo stick gone. Rides pretty well, can't wait to get out in the dirt somewhere and see how it does. NM, CO, UT, NV, OR?
You should plan to ride with us when we get out that way. Maybe a day or 2 or 3?
John
Sent via morse code
Old 01-21-2013, 08:21 AM   #73070
acesandeights
Asperger
Oddometer: 4,095
I'll plan on it John. I would think NM, CO, UT, NV, OR would be a good test to see if you've got your suspension dialed in
Old 01-21-2013, 09:34 AM   #73071
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,269
Hello,
thanks.
The Pre-'96 DR650S Thread: http://www.advrider.com/forums/showthread.php?t=61568
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 01-21-2013, 02:15 PM   #73072
ram1000
ram1000's Avatar
Oddometer: 1,837
The DR is headed back together after getting the frame powder coated semi-gloss black. While it is apart I took the RMZ450 forks apart and the machine shop is cutting new grooves in the dampening tubes to shorten the travel from 12.2" to 11.5". This will allow me to set the forks down farther in relation to the Cogent rear shock so that steering can be made more responsive.
A good adventure bike will get you to where you wish you had a good dirt bike! (and back)
:2014 XC800 :2012 WR450
ram1000 is offline   Reply With Quote
Old 01-21-2013, 02:26 PM   #73073
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,269
Preload?
Nevermind... figured it out. :)
I had had a question about preload, but then thought about it a little more, re-read the ProCycle page, and answered my own question. I ended up going with 1" of total preload (0.47 kg springs). I also set the preload on the emulators at the two turn starting point suggested on the ProCycle page.
It's now 4 PM and the bike is back together. I haven't gone for a test-ride because it's too damn cold, but it feels nice from just sitting on it and pushing on the front end.
While I was out there, I installed that new case saver that they sell, and that fancy anodized blue rear brake clevis. I was hoping the brake clevis thing would help with the play in the rear brake. It might have helped a little... I won't know for sure until I ride it.
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G screwed with this post 01-21-2013 at 04:03 PM
Old 01-21-2013, 05:01 PM   #73074
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
The red pegs and shift lever are very sharp. Power coated also? It's so nice it'll be a shame to get her mudded up! It was 65F here in Nor Cal. Perfect riding weather.
Old 01-21-2013, 06:53 PM   #73075
ram1000
ram1000's Avatar
Oddometer: 1,837
The red parts are paint, and I intend to paint the rear grab bars and my homemade bag racks red also. They are primered now. A few other parts will be red like the oil cooler brackets and little brake brackets. I intend also to paint the valve covers red- got that idea from the Husky 630. Thanks...
Old 01-21-2013, 08:31 PM   #73076
Adv Grifter
Oddometer: 6,128
Red and black have always been a killer combination. Love it. Those red accents really set off things ... and hide a lot of homeliness!
The Huskies red heads are way cool. Great inspiration.
Old 01-21-2013, 11:26 PM   #73077
ER70S-2
ER70S-2's Avatar
Oddometer: 7,259
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 01-21-2013, 11:56 PM   #73078
1989THEARK
1989THEARK's Avatar
Oddometer: 378
Question Battery
I dont want to start a flame war or anything.
but my stock battery in the DR finally gave out.
im the second owner of the bike.
it was wrecked and i have bin taping it back together.
after being crashed having some covers smashed
forks bent
tank crushed
tail of the frame slightly bent.
the bike STILL rides awesome.
i used to ride a ex250.
dont ask me what year becuase i had parts from god knows how many different bikes.
after being crushed on my buddy's ktm950 i realized
i really REALLY "REALLY" !!!
wanted my own dual sport.
though i need to get the hang of dirt riding.
my skills for a lack of a better term. SUCK in dirt.
anyway
back to the problem at hand. i have bin thinking about getting a antigravity battery. i read they are good. last long strong crank. but i haven't got any good answers on wether they can deal with the heat the dr650 puts out.
this is my eco bike if it aint broke i dont fix it. i dont plan on farkeling up the bike. i love its simplicity and its get on and go ability. so no extra lights. at most i will just go to a dual headlight. since i hate the stock headlight output with a passion. its one of the reasons i dont like to ride at night. planning to just drop in a new bulb and see if its an improvement..
dang i keep getting off track.
sorry im a total noob here.
i think this is actually my first post on ADV.
i've gone on DR specific forums and thumpertalk but im hardly ever here.
since this is the axis of evil for DR650's on ADV i figured i'd post here and deal with the onslaught opinions.
1989THEARK is offline   Reply With Quote
Old 01-22-2013, 04:15 AM   #73079
jmderyke
Miner
jmderyke's Avatar
Oddometer: 43
Hi guys I have a dr 350 and I am wanting to swap my rear shock spring, since the 650 is still being made figured I might be able to grab a used one from a 650. So can anyone tell me the specs of the 650 rear spring? mine is
11" x 2 1/4" id thanks
jmderyke is offline   Reply With Quote
Old 01-22-2013, 07:09 AM   #73080
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,295
JE 10.5:1 piston change
just an update for you regulars -
I did finish the HC piston last Friday. Test rode local gravel roads on Saturday to break it in.
She ran a good bit hotter, hopefully it settles down a little as it breaks in but I'll probably be putting a KTM fan on the oil cooler.
first impressions: I did feel an improvement in the throttle response and believe it was a little smoother. I was neither overwhelmed nor underwhelmed by the increases in power. It's definitely snappier but I kind of expected more. For the $200-ish cost of the DIY upgrade it wasn't bad. Further testing on the trail will be needed to get a better idea of the power and heat tradeoffs. Before doing the piston change, I believe I read somewhere on the web where someone compared the change as similar to the gains felt with the pumper carb. I think I would agree with that.
I did have pinging at low RPM loads. Down where she used to tractor, she now pings. I had a half tank of regular gas and attempted to put some premium in it at the station. But the local pumps only have one handle for three grades so by the time you select and pay for 1.5gallons of premium, I bet I was lucky to get .5gallon of premium in the tank.
I will probably fiddle-fart around with the carb jetting some more to see if I'm still in the sweet spot.
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Times are GMT -7.   It's 12:48 AM.
