Old 01-17-2013, 04:02 PM   #73081
Trbig67
Oddometer: 108
So there isn't a plugged vent somewhere? This is just one of those inherent things of the bike?
Trbig67 is offline   Reply With Quote
Old 01-17-2013, 04:03 PM   #73082
Trbig67
Oddometer: 108
And.. I've never seen what you're talking about on the regular DR650 page of Procycle. Is it listed somewhere else? Does it have an official name?
Old 01-17-2013, 04:17 PM   #73083
rpet
Awesometown
rpet's Avatar
Oddometer: 333
Look again - it's there!
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
rpet is offline   Reply With Quote
Old 01-17-2013, 04:26 PM   #73084
Trbig67
Oddometer: 108
FInally found it. Thank you.
Old 01-17-2013, 06:37 PM   #73085
Load Clear
Oddometer: 25
Rear Brake Lever
Hey guys - are rear brake pedals all the same? Bent mine up pretty good and plan to put a new one on.
Load Clear is offline   Reply With Quote
Old 01-17-2013, 07:03 PM   #73086
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,116
Originally Posted by Rusty Rocket View Post
Looks like TinkerinWstuff is tinkering with stuff again. Hope you didn't get a hernia lifting that motor out.
that thing isn't too bad.
This was as far as I got by 5pm today. Maybe have it wrapped up tomorrow if I'm ultra super lucky.
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 01-17-2013, 07:07 PM   #73087
LucasLeader
LucasLeader's Avatar
Oddometer: 276
I've never seen an aftermarket replacement. I think it's just mild steel so you should be able to bend it back into shape. I've had to do it with my shift lever.
LucasLeader is offline   Reply With Quote
Old 01-17-2013, 07:25 PM   #73088
ER70S-2
ER70S-2's Avatar
Oddometer: 2,565
The question has been asked: "How heavy is the DR engine?" You could tell us here AND post it up in Krusty's DR Index (Hiya Krusty, thanks again for the DR650SE INDEX ). Or you could let us down and be forgotten forever.
Here: Topic 12:
http://www.advrider.com/forums/showp...2&postcount=32
2004 DR650: 46,358 miles of
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 01-17-2013, 07:42 PM   #73089
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,817
I bought two of the first batch Procycle made up.
"Don't play a lute to a cow" (Old Chinese Idiom)
Old 01-17-2013, 07:46 PM   #73090
TinkerinWstuff
Take it apart
Oddometer: 1,116
Here: Topic 12:
I will see what I can do!
I just know it should be 1ounce lighter now than it was before
1999 Suzuki DR650
Old 01-17-2013, 09:03 PM   #73091
ER70S-2
ER70S-2's Avatar
Oddometer: 2,565
Tank ewe.
I'm sure you're correct. Removing all that alum from the piston for valve clearance must be good for a multiple of pounds.
Old 01-17-2013, 10:18 PM   #73092
Thumper Dan
Oddometer: 214
noob question, why do you have to remove the motor to put the new high comp piston in? Can't it be done whilst motor is in the bike?? I'm sure there is another reason.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks
Thumper Dan is offline   Reply With Quote
Old 01-18-2013, 06:45 AM   #73093
TinkerinWstuff
Take it apart
Oddometer: 1,116
I'm not sure if it can be. Seems like there's a real possibility. Someone will undoubtedly chime in that knows for sure.
But by the time you have it far enough apart to attempt to remove the jug in the frame, it's three more motor mount bolts and a couple other misc garbage to have it on the ground. Literally less than 10 more minutes to have it on the bench.
Too bad my bench is over flowing with other garbage and there was no room for the motor.
1999 Suzuki DR650
Old 01-18-2013, 07:10 AM   #73094
procycle
procycle's Avatar
Oddometer: 1,607
Just a tad over 100 pounds.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 01-18-2013, 07:15 AM   #73095
procycle
procycle's Avatar
Oddometer: 1,607
Yes, the top end can be serviced in the frame. It's not much more work to remove the whole thing but leaving the bottom end in the frame gives you a built in 'engine stand' to hold it firmly when installing the cylinder, rotating the crankshaft, torquing the head bolts, etc.
Times are GMT -7.   It's 01:23 PM.
