Old 01-22-2013, 07:27 PM   #73096
motolab
motolab's Avatar
Oddometer: 2,621
Originally Posted by TinkerinWstuff View Post
That is interesting, I haven't heard of pinging on a stock setup. Thought I read up on this one pretty thorough before going forward but didn't see any of those. Did you see that on ADV or somewhere else?
A quick search reveals http://www.advrider.com/forums/showp...ostcount=67419, http://www.advrider.com/forums/showt...6#post18052596, http://www.advrider.com/forums/showt...3#post16094853, http://www.advrider.com/forums/showt...g#post15781952, http://www.advrider.com/forums/showp...ostcount=15252, http://www.advrider.com/forums/showt...n#post20447527, and http://www.advrider.com/forums/showt...n#post20440712
I added some octane boost to get through this tank and it helped. The only time I got pinging was when my oil temps exceeded 270 for a moment.
As I said, if you can hear it, it's pretty bad. Enough detonation can be present to damage the engine without you ever hearing it.
I did not see anywhere else that people had to adjust timing for the HC piston.
See http://www.advrider.com/forums/showt...n#post10906911.
So I'm tempted to leave that as a last resort.
Increasing exhaust flow would also help.
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-22-2013, 07:28 PM   #73097
jmderyke
Miner
jmderyke's Avatar
Oddometer: 43
Originally Posted by smilin jack View Post
Ran out to the garage and measured my 2006 take off springs. Put new heavier springs front and rear a while back.
stock fork springs= 1 3/8inch OD and just under 22inches long
shock spring= 2 1/4inch ID and 10" long
Hope that helps.
Dave
thankyou very much it did help
jmderyke is offline   Reply With Quote
Old 01-22-2013, 08:33 PM   #73098
Sierra Thumper
Oddometer: 641
Originally Posted by 1989THEARK View Post
more light less power?
where do i sign
i have bin throwing back and fourth the idea of just getting the oem battery again.
my bike is an 02. its still the stock battery even AFTER the owner wrecked.
and it barely stopped working a week and a half ago.
thats nearly 10 years of life.
if i can get 4 years out of a battery its a blessing.
10.!!
people should write stories of these magical devices.
but i would like a direct comparison of the DDM's vs the stock headlight.
procycle has a very good comparison of there HID kit.
if its anything like that. i'll hit the take my money button as soon as i see the photo's.
I regularly get 10 years or more out of a battery, especially a quality one. I do it by keeping my bikes plugged into battery tenders anytime they're not being ridden
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 01-22-2013, 09:10 PM   #73099
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
I also get about that time out of my batteries by constantly riding my bikes
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Old 01-22-2013, 11:34 PM   #73100
1989THEARK
1989THEARK's Avatar
Oddometer: 334
I live in southern cali. it doesnt get TOO cold here but lately its bin dropping down into the low 30's which is somewhat rare.
it hasnt bin getting its normal semi warmer weather lately so im worried about the heat of the DR650 killing the battery.
never had to worry about the cold weather.
this bike almost always starts first click of the starter regardless of weather.
or battery condition. the day before the battery took a bing steaming poo. it still started up just fine.
Originally Posted by rpet View Post
where do you live?
The main drawback of the new Li batteries is apparently they die quickly and don't crank when the weather is cold.
I'm in NY and it's 20 right now, so that's not an option for me.
Otherwise I'd love to ditch that fat battery!
1989THEARK is offline   Reply With Quote
Old 01-22-2013, 11:49 PM   #73101
1989THEARK
1989THEARK's Avatar
Oddometer: 334
I didnt think it dropped that much voltage. maybe i'll wip out the handy dandy voltmeter and see how many volts its dropping through the circuit out of curiosity.
if its loosing that much power i'll definitely rig my own circuit up with relays and probably go up a guage in wire.
i dont know if this is a stupid question but.
what is the MININUM CCA needed for the 650.
the stock battery has a CCA of 120.
that seems pretty sad to me.
apparently i can get a powersource battery for cheaper than the oem.
and it puts out 175 CCA its not much of an improvemt but for cheaper and higher CCA.
maaaaybe its worth the investment?
im just throwing that out there even though im going tomorrow to pick up my yuasa
Originally Posted by victor441 View Post
I've always had the best results w/ Yuasa batteries, not the cheapest but they are reliable and long lived. So far as the light output goes the first thing to do is add relays with a fused feed direct from the battery, the stock wiring typically drops 2 volts or so which will cut light output nearly in half and a high powered bulb would make the drop even worse. The relays are cheap if you go DIY or you can get a quality kit from http://www.easternbeaver.com/Main/Wi...s/h4_kits.html
I installed relays and a plus bulb in my own bike and the lighting is not bad at all now ....also FWIW the stock reflector and lens are glass and can handle the added heat of an H4 plus or high power off road bulb OK
Old 01-22-2013, 11:54 PM   #73102
1989THEARK
1989THEARK's Avatar
Oddometer: 334
Bold statement. but what brand for what bike/car/jet ski/ time machine?
because i normally get 4 years out of a battery this is the first time i have EVER gotten 10 years out of ANY battery regardless of brand,size,configuration
Old 01-23-2013, 02:14 AM   #73103
Sierra Thumper
Oddometer: 641
I get the best life out of the stockers....most bike makers put damn good batteries in their machinery.......and they usually use Yuasa's But I've also had good luck with other quality batteries....you do need to pay for the quality tho, don't expect a $40 shipped e-bay special to last 10 years in your time machine
Old 01-23-2013, 06:43 AM   #73104
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,263
So fill us in on the outcome. Does the 350 rear spring fit a 650?
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 01-23-2013, 07:33 AM   #73105
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 938
front tire question, specific
Just recently picked up a DR650, of course, and was wondering about a specific tire to see if it will fit on the front...
I'm not sure if a 3.00-21 would fit in a Bridgestone ED03..anyone know?
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is offline   Reply With Quote
Old 01-23-2013, 07:35 AM   #73106
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,183
Should fit just fine. That's the same as a 90/90-21.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 01-23-2013, 08:08 AM   #73107
Rusty Rocket
Life behind "Bars"
Oddometer: 9,263
I run an ED-03 300x21 all the time. It is a really good tire.
2009 DR650
Old 01-23-2013, 08:15 AM   #73108
TIGERRIDER007
Oddometer: 938
thanks
Was looking to replace the front with a good value tire, a Bridgestone ED03 or a Metzeler Unicross...
Thanks for the guidance!
Scott
Old 01-23-2013, 10:28 AM   #73109
victor441
victor441's Avatar
Oddometer: 948
FWIW there is a very handy rim width vs. tire size reference at http://www.mtsac.edu/~cliff/storage/...Size_Chart.pdf
I generally double check the tire makers site to be sure and so far all have agreed...
BTW, I have an '06 Tiger myself and love it (ride a DR650 as well)
victor441 screwed with this post 01-23-2013 at 10:38 AM
victor441 is offline   Reply With Quote
Old 01-23-2013, 10:30 AM   #73110
Rusty Rocket
Life behind "Bars"
Oddometer: 9,263
My favorite combo for offroad tires is: (BTW, both are DOT approved)
http://www.motorcycle-superstore.com...chAutoComplete
in 130/90-17
shop around for price. I've gotten mine from several sources, usually someone has one or the other on sale.
I got a RockyMtnATV $25 gift card for renewing my BlueRibbon Coalition, and a $10 card for renewing my AMA membership. so that's likely where I will source my next set. Had good luck w/ Bob's Cycle Supply also.
2009 DR650
Times are GMT -7.   It's 11:12 PM.
