Old 01-29-2013, 05:23 AM   #73246
SCExpat
Ex-expat
SCExpat's Avatar
Oddometer: 635
Originally Posted by Sierra Thumper View Post
Yep, there could be many reasons why a clutch would need replacing before 15k miles on a DR, but the most likely reason is stated above...the po just plain wore it out through his riding style.
I'm always suspicious of replaced parts like clutches on lower mileage machinery.....makes me wonder what other hidden wear and tear the machine went through to prematurely wear out the clutch.
My exact concern. I thought 15K was a bit early for a new clutch. As I am in no rush I am going to pass on it. Even if it is a good price. A nicer one will show up before it gets warm enough for me to ride here.
SCExpat is offline   Reply With Quote
Old 01-29-2013, 05:37 AM   #73247
doug s.
Oddometer: 1,354
if it otherwise looks decent, you could always offer $1500, and then walk away if the seller says no...
doug s.
doug s. is offline   Reply With Quote
Old 01-29-2013, 05:46 AM   #73248
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,740
Originally Posted by GSF1200S View Post
I used a floor mat made out of closed cell foam sold at Lowes for workshops.
I have always cut strips of HD innertubes and squeezed them between the frame and skidplate on all my bikes. I think that much of what people are hearing is the plate vibrating harmonically. This may not be enough for some of you. The DR650 is the quietest bike I have ever owned, I've never had a streetbike so I can't compare what others perceive as noisey.
You definitely want closed cell foam,(like GSF suggests) especially offraod. The bufferpad will soon be adobe. Think about using a "pool noodle" or foam pipe insulation instead.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 01-29-2013, 05:54 AM   #73249
WindPipe
WindPipe's Avatar
Oddometer: 211
The primary nut, however, was way loose and would have come off in time. Its amazing how much these guys vary unit to unit.
What size socket do I need for that primary nut. My searches have come up empty ...
The future is wide open.
WindPipe is offline   Reply With Quote
Old 01-29-2013, 05:56 AM   #73250
shu
Oddometer: 1,073
That's what I did as well. Seems to work fine for me- of course, I wear earplugs when I ride.
...........shu
shu is offline   Reply With Quote
Old 01-29-2013, 06:55 AM   #73251
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
I also use inner tubes to dampen vibration but like any other sane or intelligent person I wear earplugs, so the noise doesn't really bother me.
jessepitt is offline   Reply With Quote
Old 01-29-2013, 07:05 AM   #73252
barko1
barko1
barko1's Avatar
Oddometer: 3,415
I bought a piece of compressible foam designed for the purpose but frankly since I always where earplugs I don't notice much difference. I wonder if several coats of Plasti-Dip might work. It is pretty tough, you can cover your whole car with it (might be good for DR side panels!).
Originally Posted by eakins View Post
Best material to use on the skid plate to quite the vibration it makes and noise it focuses up into the bike???
Thinking the stick on sound deadeners panels where it does not touch the frame. Or a spray on line-x on the bottom underneath surface too??? how about that spray on under car body sound deadener??? the black stick stuff?
thanks, bill
DR650, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), Triumph Thunderbird Sport, Triumph Daytona Super III, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 01-29-2013, 08:13 AM   #73253
SkunkWizard
recycle crime scene tape
SkunkWizard's Avatar
Oddometer: 762
Originally Posted by ram1000 View Post
After many weeks of waiting and working on the DR I finished my project, except for new tires next month. Just turned the key off after starting to make sure it still runs. The project was:
1. strip the bike down to its frame and powder coat the frame black
2. clean up all the rims and hubs exhaust and any other component that needed a thorough going through
3. disassemble the previously installed RMZ450 front forks to change the oil to a lighter weight and at the same time shorten the overall travel from 12.2" to 11.5"--- this allowed me to drop the forks into the triple clamps farther than before and tighten up the steering for serious off road handling, while turning the rear preload down a little for a more trail oriented ride
4. also installed a new set of fat bars that I think I will like even better than the previous bars
5. I previously had purchased a new ULY front headlight assembly but opted to put the stock lights back on and sell the ULY headlight since I also recently bought a 2009 KLR for my road riding adventures
6. rewired the BMW plug and cig lighter plug a little nicer
Job done well! be proud show it off
looks very Latrodectus hesperus
~DR 650~
Upgrades:
1. dented tank
SkunkWizard is offline   Reply With Quote
Old 01-29-2013, 08:47 AM   #73254
LucasLeader
LucasLeader's Avatar
Oddometer: 296
Is your chain a little loose?
LucasLeader is offline   Reply With Quote
Old 01-29-2013, 10:04 AM   #73255
motolab
motolab's Avatar
Oddometer: 2,852
Originally Posted by opium89 View Post
My other one doesn't pop much at all. You don't think tweaking that needle a bit might help? I find it curious that it all but goes away when the choke is opened up.
Sorry for not replying sooner and thanks for the PM to remind me.
The area the needle is responsible for is 1/4 opening. The needle should not be used to tune closed throttle even though there may very well be enough overlap to affect it. To illustrate the problem: Let's say that you had tuned the clip position to achieve perfect running at 1/4 opening, and you now raised the needle to richen the mixture at closed throttle. The result will be that the mixture at 1/4 opening will now be too rich, while the effect on closed throttle may or may not be as desired. Closed throttle is solely the responsibility of the fuel screw unless the pilot jet size is out of range. You can test this by evaluating 1/16 to 1/8 opening running and/or by whether or not the engine can be killed at both extremes of the fuel screw's adjustment range. Of these two, the former is absolute (misadjusted float height, clogged/incorrect pilot air bleed size or worn parts notwithstanding) while the latter should only be used to give you hints.
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-29-2013, 10:55 AM   #73256
ram1000
ram1000's Avatar
Oddometer: 1,838
I am waiting for new tires before I adjust the chain...
A good adventure bike will get you to where you wish you had a good dirt bike! (and back)
:2014 XC800 :2012 WR450
ram1000 is online now   Reply With Quote
Old 01-29-2013, 11:19 AM   #73257
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
A very good point ... and valid reason for concern. When buying ... and I've bought over 50 bikes ... a good idea to have close look at the seller. How is his garage kept? Does he keep maintenance logs? Lots can be learned from his answers regards maintenance or "fixes" he has done on the bike.
All that said ... as I said before ... the DR is a pretty tough customer and can handle abuse well. Still ... a hard used bike would never be my first choice. Good luck! Good shopping.
Old 01-29-2013, 11:21 AM   #73258
shu
Oddometer: 1,073
Black Widow Spider. (Had to look it up.)
...........shu
Old 01-29-2013, 11:22 AM   #73259
Adv Grifter
Oddometer: 6,128
I also used HD innertube stripes on all places where frame contacts skid plate. Not sure how much it helped but seems OK. Spraying with some sound deadening stuff can't hurt. More the quieter.
Old 01-29-2013, 12:51 PM   #73260
gjcarving
Oddometer: 116
I did mine a few months ago. I believe it is a 30mm. Had to go to an auto parts store to get one. Pep boys! Hope yours is not as loose as mine was. Mine ate a bunch of the clutch basket apart on the back. Enough that I decided to replace it. Good luck!
gjcarving screwed with this post 01-29-2013 at 02:24 PM
gjcarving is offline   Reply With Quote
Times are GMT -7.   It's 08:36 PM.
