Old 01-30-2013, 01:47 PM   #73291
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,288
Originally Posted by 3DChief View Post
Mine has the spray-on liner, probably about 5 or 6 coats. It helps, but not as much as you would think. The skid plate is still too reflective for sound waves. It's not vibration noises, it's all the noises the engine normally makes that are being reflected up at you instead of towards the ground. At first I was trying to find things to quiet it down, finally decided it isn't a big deal and I just ignore it now. I would like to find a really porous foam (think stripper pad on a floor buffer) to put in there and will try it if I find one. I just don't want anything that will hold water, it still needs to drain well.
Tim
i'm leaning towards dynamat extreme. i wonder what washing machines use to sound deaden on the pricy model?
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 01-30-2013, 01:48 PM   #73292
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,288
Originally Posted by Feelers View Post
Mass loaded vinyl with one side with adhesive is your best bet.
i have no idea what that is???
Alaska
Old 01-30-2013, 01:51 PM   #73293
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,288
Originally Posted by Rusty Rocket View Post
I have always cut strips of HD innertubes and squeezed them between the frame and skidplate on all my bikes. I think that much of what people are hearing is the plate vibrating harmonically. This may not be enough for some of you. The DR650 is the quietest bike I have ever owned, I've never had a streetbike so I can't compare what others perceive as noisey.
You definitely want closed cell foam,(like GSF suggests) especially offraod. The bufferpad will soon be adobe. Think about using a "pool noodle" or foam pipe insulation instead.
have tubes between on the front of the plate. yes it's harmonics and reflective sound. don't expect no sound just muffle what is there.
Alaska
Old 01-30-2013, 01:53 PM   #73294
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,288
Originally Posted by jessepitt View Post
I also use inner tubes to dampen vibration but like any other sane or intelligent person I wear earplugs, so the noise doesn't really bother me.
well of course, but if i can quite things even more the better. there is a reason why very expensive cars are quite. it's work to do so. nothing wrong with that.
Alaska
Old 01-30-2013, 01:57 PM   #73295
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,288
i'm guilty of it, but most everyone hates rants...just give em unbaised opinions, feedback and research findings.
i see a rant and my brain turns off on the info...say what?
Originally Posted by Adv Grifter View Post
As a sound recording pro ... I agree. I've done many many similar rants on ADV ... most riders just ignore ... if falls on "deaf ears" .
Everybody has an excuse, like, "... plugs are too uncomfortable", " ... they don't fit my ear canals". "... too expensive". " ... too much trouble to put in and out". Yada Yada. Got an issue? Get a tissue!
As you say, hearing loss is no joke. And yes ... it's the low freq buffeting from wind noise that does damage to the tiny Scilia around the ear drum. First you loose ability to hear high frequencies ... makes understanding speech in a noisy place hard. Goes downhill from there.
So easy to protect your hearing. At least wear them on long rides ... and learn how to insert them properly .... many riders do it wrong.
RANT OFF!
Alaska
Old 01-30-2013, 02:17 PM   #73296
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,288
just talked to tech at dynamat.
solution is 1st stick dynamat extreme to skid plate and then dynalinner 1/2" foam to that. takes care of both sources of noise.
warm up skidplate 1st with hairdryer then stick.
he knows bikes and skid plates.
http://www.amazon.com/Dynamat-10415-.../dp/B00020CATC
http://dynamat.com/products_car_audio_dynaliner.html
Alaska
eakins screwed with this post 01-30-2013 at 10:08 PM
Old 01-30-2013, 02:18 PM   #73297
tv guy
Commuter
tv guy's Avatar
Oddometer: 103
I used some heater hose between the skid plate and frame IIRC 3/4" ID. Once cut open it fits around the frame rails (with a bit of trimming) and stays in place when you take the plate off to change oil etc. Quiets things down quite a bit.
Motorcycling, it's more than Adventure....
It's Transportation!
tv guy is offline   Reply With Quote
Old 01-30-2013, 02:38 PM   #73298
neo1piv014
ADV in training
Oddometer: 621
This is a common question. Guys think riding with ear buds they are OK ... and they are partly right! You are protecting your hearing from low frequency wind damage.
BUT ... if you crank up the Tunes ... this will also take a toll on your hearing over time.
At speed we tend to listen LOUDer and LOUDer as the day goes on ... and we've all read the studies about the Japanese teenagers going deaf from listening to their Walkman/Nano too LONG and too LOUD. Tens of thousands affected in Japan.
With hearing damage its not just db levels ... it's duration of the abuse and proximity or source of the sound to your ear drum. Ear buds are in close proximity to your ear drum ... and more worrisome ... they SEAL up your ear canal providing NO venting ...which is critical to prevent damage. Loud Ear Buds inserted ALL THE WAY IN ... really can hammer your ear drums when cranked up to max.
In my industry very few use Ear Buds for this reason. We use open air headphones ... and take them off for loud transients or gun shots.
If you listen riding ... try to keep the volume down. Over time you'll get used to a lower level.
I've already got an SMH5 on my "to buy" list. Once I add that to the side of the helmet, will I be alright with the disposable foam ear plugs you get at the hardware store?
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 01-30-2013, 04:26 PM   #73299
YnotJP?
Oddometer: 2,538
Chucksklrst; I have a Laminar windscreen on my DR 650. I put it on back in 2010, before Procycle was listing it. I like mine very much. Keep the wind off your chest. I rode from Seattle to San Diego in February 2011, with snow part of the way so it was tested. I did drill and mounted with some plastic nuts and bolts with rubber gromets between the screen and headlight surround as the 3M stuff didn't hold it as well as I wanted. I am 72 and the screen does make long rides a lot nicer. I would post photos however I must admit I have no idea how.
YnotJP? is online now   Reply With Quote
Old 01-30-2013, 04:58 PM   #73300
Chucksklrst
Chucksklrst's Avatar
Oddometer: 24
How about sending me some photos to Chucksklrst@aol.com I need close ups of front and side views and a few from the cockpit. Thanks
Chuck Henderson (US Army RET 1968-1991) (Forever Home Colorado) STOC# 086, KLRST# 001
RIDE a little FASTER, RIDE a little FURTHER
14 FJR1300A (Ruby FeeJeR) 09 DL650 ABS (Weezer)
08 DR650 (Dirty Rider)
Chucksklrst is offline   Reply With Quote
Old 01-30-2013, 06:23 PM   #73301
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Chucksklrst View Post
Looking at how to post photos, I guess I need to have a photo host to be able to post photos. I don't see a way to up load photos direct from my hard drive. am I mistaken?
A lot of guys here use Smug Mug for photo hosting. It's owned/operated by site owner Baldy and run by his kids. It's not FREE but is the best, IMHO ... and helps keep ADVrider on the air. It's about $30 a year (IIRC) Every little bit helps.
You can also use Google's Picasa hosting site for pics. Free but limited. I use both.
Old 01-30-2013, 06:34 PM   #73302
Adv Grifter
Oddometer: 6,128
Most times those hardware story plugs are junk ... and end up being expensive and they HURT! Try Howard Leight Razor Lite ear plugs. 200 pair to a box ... about $25. The Razor's are soft and smooth, attenuate 32 db of noise. I can wear them all day without discomfort. I prefer UNcorded version and if you keep your hands clean you can re-use them at least a half dozen rides. Once wet, they are ruined. Toss them.
http://www.howardleight.com/earplugs/laser-lite
Old 01-30-2013, 06:51 PM   #73303
neo1piv014
ADV in training
Oddometer: 621
Half a dozen rides, figure three uses per pair...yeah, I can swing 600 rides for $25. Even if I commuted to work every single week day of the year, I'd still get two years out of $25. I could live with that lol. Thanks for cluing me in!
Ride videos
'01 DR650
Old 01-30-2013, 07:39 PM   #73304
doug s.
Oddometer: 1,348
Originally Posted by doug s. View Post
if it otherwise looks decent, you could always offer $1500, and then walk away if the seller says no...
doug s.
Originally Posted by SCExpat View Post
This idea fits my cheap arse just fine. A good deal plus I can get some farkles and still not have much $$$ in it.
being a bit of a cheap arse myself, that's how i bought my '00. it was on a local c/l, adwertized for $3k; it already had sm wheels, which was what i was wanting to do anyways. the pics looked good, but when i went to look at it, the bike had obviously been beaten on. there was a li'l dent in the rear swingarm from the kickstand, and the front steering stem bearings were shot. and, the rear wheel was obviously installed incorrectly, as it was off-center - a re-lacing was in order. plus, misc scrapes, etc... i offered $1k and got it for $1300. i figured that was about the price for a set of sm wheels & tires, and the bike was a freebie! the cheap price has let me spend quite a bit on it, and it's now almost perfect, for me. and, the bike's motor is in great shape; smooth and pulls really strong, w/the fcr-39 carb, kientech hi-flow midpipe, fmf powerbomb hi-flow header and tsukigi gsxr1000 exhaust can...
doug s.
doug s. is offline   Reply With Quote
Old 01-30-2013, 07:52 PM   #73305
poppawheelie
poppawheelie's Avatar
Oddometer: 592
Laugh Spot
Originally Posted by procycle View Post
Get yourself a SPOT satellite tracker. It will go a long way toward calming your wife's fears. If I remember correctly the tracking subscription is around $150/year. Absolutely worth every penny.
Just returned from riding Ecuador. My wife had a fun time tracking me on SPOT, Andes to Pacific and back across to the Amazon Basin. She could even see where we attempted a mud road, stopped and turned back. Highly recommend it.
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie is offline   Reply With Quote
Times are GMT -7.   It's 05:55 PM.
