01-25-2013, 08:21 PM
#73336 |
Oddometer: 181
+1
When I put pressure on the throttle (closed, but a bit of pressure so it's opened just a tiny bit), the decel popping disappears. I'm running at 1350 rpm instead of the recommended 1500, so I bet if I just bumped the idle up a little bit, problem solved. But, the decel popping is not bad and doesn't bother me yet. |
01-25-2013, 08:36 PM
#73337 | |
on the road o'dreams
Oddometer: 5,377
I think around 1500 RPM idle is about right to reduce de-cell popping. Another Tip! EAR PLUGS!
01-25-2013, 08:48 PM
#73338 |
Oddometer: 214
spokes
I'm trying to put a replacement spoke in and have gotten the broken one off but for the life of me, I cannot get the thread started on the new one.
Is there a trick to get the thread started; as it the threads are touching but seems they're bit short (they're the right ones for the bike though)?? thanks
Currently riding DR650 (2011) Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks
Thumper Dan screwed with this post 01-25-2013 at 09:41 PM |
01-26-2013, 02:52 AM
#73339 | |
kezza
Oddometer: 731
Mine's the same... get over it.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250 Website: http://www.territoryon2wheels.com "May the Road Never Rise to Defeat you..." |
01-26-2013, 04:57 AM
#73340 | |
Oddometer: 265
+1 tune for performance - decel popping won't hurt anything Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
DR650 - Living the Dream!
01-26-2013, 06:47 AM
#73341 | |
Kool Aid poisoner
Oddometer: 4,813
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
01-26-2013, 07:33 AM
#73342 |
Miner
Oddometer: 40
01-26-2013, 09:36 AM
#73343 | |
Oddometer: 597
Short spoked?
That means when you are starting to screw the spoke nipple on, the nipple will not be through the rim much, if any at all. Sometimes you have to grind the end of the spoke off so it doesn't puncture the tube. Sounds like you are using the short spoke on the long spoke side which won't work.
Attitude ~ The difference between Ordeal and Adventure James |
01-26-2013, 10:35 AM
#73344 |
Life behind "Bars"
Oddometer: 6,243
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
01-26-2013, 11:16 AM
#73345 |
MADMark
Oddometer: 128
11,000 miles of fast highway so far. Only issue is a very, very small oil leak; probably from the tensioner. haven't had the time to completely diagnose. It's not enough to even leave a spot on the ground.
MAD (yes, those are my real initials) |
01-26-2013, 11:24 AM
#73346 | |
MADMark
Oddometer: 128
Staying ahead of idiots who try to tailgate keeps me moving between 80 and 90 mph on I287. I tend to ride fairly aggressively and always downshift while braking. If braking hard, I downshift very quickly. No issues.![]() Besides, riding it hard is a lot of fun.
01-26-2013, 12:45 PM
#73347 |
Oddometer: 8
Why Gas Tank, Why?
So I'm attempting the beginning maintenance on my DR, and I managed to change the handlebars successfully, so go me. Although I did undo things that didn't need undoing, like the clutch and the box next to the throttle...whatevs, it still ran fine after than particular mod.
Yesterday I tackled the gas tank, and put an IMS on it. After much frustration, I found I could only' keep the thing running when the vent line from the gas cap to the ? was not on it at all, otherwise it would die as if it ran out of gas. I figured, ok, I can deal w/ this temporarily in the winter before finding a better system, and it ran fine on the round-the neighborhood test drive I took it on. Fast forward to this morning, and I can't get the thing to stay running. It starts fine, idles ok (seems to idle fine only when throttle is fully open), and then I take it as far as the end of the driveway before it stalls out. Generally in first gear, as soon as I try to get it to move further, it just dies. There's gas in it, the tube from the petcock to whatever is 4 inches to the right of the petcock seems clamped on fine, no leakage or anything. I've tried putting the vent tube from the gas cap back on, no dice. So why in the hell is my engine dying w/in <2 min of running? I was so proud until this morning... In short, at the moment I'm an ignorant noob and a dumb brute. HULK ANGRY |
01-26-2013, 12:56 PM
#73348 | |
Oddometer: 181
![]() Since you know what the petcock is, did you reuse the original petcock, or install a new one? Also, attempt to blow through the gas cap tube with your mouth and see if you are able to, and let us know. One more thing, idling and the throttle being fully open simultaneously is impossible. Full throttle means maximum acceleration. Idle means just sitting there on the kickstand running without you touching it. |
01-26-2013, 01:30 PM
#73349 | |
PussyWagon™ Chauffer
Oddometer: 3,576
How much fuel in the tank? IMS petcock or stock?
Steve 07 KLX250S w/300 kit, 05 DR650SE, 04 XT225 99 VFR800 w/870 kit, 96 GPz1100 |
01-26-2013, 01:43 PM
#73350 | ||
Oddometer: 214
I measured the old one with the new one and it does seem longer. I was starting to think, if I had to do this on the side of the ride for whatever reason, it would be very painful. I will source out some disc side spokes. Its raining where I am and nothing better to do then to put a tyre and wheel back on! Thanks to both and another learning experience for the mighty DR
Thumper Dan screwed with this post 01-26-2013 at 04:30 PM |
