Old 02-10-2013, 02:11 AM   #73591
greer
Oddometer: 3,859
Originally Posted by hyperboarder View Post
Me and my DR are not getting along right now. 99, mostly stock, and after sitting in the garage for a bit, just refusing to start. The battery was not great before I forgot to put it on the tender, so I replaced it with a Motobatt. It will fire and run for about 3-6 seconds on full choke, but dies after that. It's got spark, it's got compression, no gas in the airbox, any ideas? About to pull the carb to give it a good once over.
While you're piddling with it, check that little bitty filter in the carb inlet elbow; that thing is apt to cause trouble at some point.
Sarah
'08 DR650, '13 TU250X
greer is offline   Reply With Quote
Old 02-10-2013, 03:28 AM   #73592
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
Originally Posted by dman View Post
Thanks for the link and pics. Question ... is the gas cap cutout big enough for a standard IMS gap with shorty vent tube and Procycle check valve? The vent probably sticks about 1.5" above the IMS cap. Is there only one Acerbis cap with integrated vent ... their web site seems down and some retailers show caps that look different than your picture. Also some forums mention the threads are close but not exact, etc.
Thanks - dman
your welcome.
rannier runner said he's using it just fine but i find when I have the Fandango tankk bag loaded with stuff the front area is pressing right on top of the gas cap. the vent area (lock area) still is exposed some on the front and I have not had any issue with the tang bag creating a seal up there so air (& thus fuel) can not be pulled in however. there is plenty of natural design area for any cap but I'm thinking a vent will be crammed (bent over and pinched tight?) in there. see all pictures here again http://www.advrider.com/forums/showp...6&postcount=76 obviously it's working for RR.
i went with the acerbis cap for security reasons but it also eliminates having a vent sticking up. you can lock the cap or have it work unlocked like a normal cap.
the stock acerbis cap pulls in air but does not vent out (like oem caps that do not leak when dumped & does not leak vapor). because it does not vent out, the IMS gets hot from the engine and rock hard as the gas expands. this concerned me how hard the tank got (as a side benefit however the fuel capacity is up now ) as I was worried about blown out tank seams or fuel pushing unnaturally into the carb.
ProCycle posted how to fix this. you screw out the inside green piece and pierce the inner rubber 1 way bladder with a needle so it vents out some. it did this and went a step farther and drilled that hole with the smallest drill bit. now when i blow out the bottom a resistant but very small flow of air heads out the top of the cap at the lock area. I dumped the bike since with full gas tank and it was basically 1 drop of gas that came out with the bike sitting on its side. the tank is no longer rock hard from expanded gas.
IMO a modified Acerbis locking gas cap on an IMS (or Acerbis) tank is the way to go for several different reason. http://www.procycle.us/bikepages/dr650.html#bodyframe
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 02-10-2013 at 03:33 AM
Old 02-10-2013, 06:04 AM   #73593
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,964
Originally Posted by 1989THEARK View Post
Unfortunately the aquabox is the only case with mount system that will work for my phone.
my charging cable plugs into the side of the phone requiring about another half inch.
But for all the things you have tried that didnt work.
whats your setup right now?
or what have you tried and DID work.
you suggested a baggie.
is that what your running?
rainy season is coming i want this problem solved before it becomes a problem
This is my current setup.
I gave up trying to make non-waterproof units into things they're not.
Old 02-10-2013, 07:08 AM   #73594
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 930
Sarah
+1
When I did my air box and re-jet I was disappointed with the amount of dirt I found in the diaphragm / slide area of the carburetor , I had always kept the original secondary filter clean and checked the foam for holes yet there was way more dirt in the carb than there should have been. My recommendation is change the stocker out for an after market sooner than later to avoid wear in the carb, especially if do any amount of dirt riding.
New Mexico, not really new, not really Mexico.
Carl Childers is offline   Reply With Quote
Old 02-10-2013, 07:11 AM   #73595
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,964
Originally Posted by Carl Childers View Post
+1
That's not the same filter she's talking about. She means the one in the fuel line elbow at the carb.
Emmbeedee screwed with this post 02-10-2013 at 07:31 AM
Old 02-10-2013, 08:23 AM   #73596
hyperboarder
Potato Farmer
hyperboarder's Avatar
Oddometer: 1,024
Originally Posted by motolab View Post
If it still idles poorly, the pilot jet is likely to be clogged.
Nobody unscrewed the idle speed screw or closed the fuel screw while you weren't looking, right?
Regards,
Derek
That's my thought, time to pull the carb and give it a good once over.
Sarah
Ditched that long ago in favor of an in line. I'm going to give the fuel lines a good check too, make sure they're clear, but I don't expect that's the problem.
Current: 08 Yamaha WR250R, 05 Suzuki DL1000, 92 Ford E250 Motohauler
Gone but not forgotten: 2008 KLR650, 2000 GSXR1000, 1999 ZX6R, 2000 GSXF600, 2004 Ural Tourist, 99 Suzuki DR650
Quarter Life Crisis 2011 Ural National Rally
hyperboarder is offline   Reply With Quote
Old 02-10-2013, 08:55 AM   #73597
kbuckey
Oddometer: 877
Originally Posted by Mongle View Post
Ahh, keep doing what you are doing...I've never gotten 5000 miles out of a rear tire on ANY motorcycle I have owned. My DR is usually due around 3500-4000 depending on the tire.
I'm sure someone will come along saying they get 10K... they must count miles hauled on the trailer or something.
Amusing. I guess I'm just a wuss 'cause my mileage has been
Tourance: 10519 miles
Tourance: 8997
Tourance: 9773
Bridgestone Trailwing 21/22 (emergency replacement somewhere in N. CA.): 6178
Tourances currently on the bike: 9842 - have the replacements waiting to go on.
None of it "on a trailer."
kbuckey is offline   Reply With Quote
Old 02-10-2013, 09:01 AM   #73598
1989THEARK
1989THEARK's Avatar
Oddometer: 379
Cool2
Originally Posted by canoli View Post
Anyone have a link that shows how to replace the brake pads (both front & back)? Never done it before but it needs to be done...soon.
Thanks,
Canoli
I know this is a vague answer. but if you have ever done brakes on a car.
there isnt anything more you need to know. take off the caliper.
push the piston in with the old brake pad(if you dont have a piston depressor)
remove old pads.
pop in new pads.
slightly (SLIGHTLY!!) grease any point that the brake pad slides on.
RE-Mount and call it good.
remember that new pads dont stop you very quickly so take it i easy.
if you have a good wire brush.
spin your wheel and scrub that rotor so create a little more friction against the pads to brake in quicker.
i've bin doing this for a long time.
some manufacturers even tell you to do it but thats more on cars. never really seen it said on motorcycles
1989THEARK is offline   Reply With Quote
Old 02-10-2013, 09:09 AM   #73599
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,278
I don't recall any specific photos, but it's easy. For the fronts, remove the caliper (two 12mm bolts), and then snap the old pads out and the new ones in. Remove the reservoir cap and see if you can press the piston back in with your fingers. If not, you may have to crack the bleeder on the caliper to do it, but it'll get a little messy if you do, since some fluid will squirt out.
On the rear, the easiest method is to remove the rear wheel, though I managed to change mine once with it on the bike... I don't quite remember how though.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 02-10-2013, 09:40 AM   #73600
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 4,063
Rob
Removing the rear wheel to change the rear brake pads is not the easiest method. There are ony 2 brake pins that have to be removed, then slide the pads out. No need to remove the wheel.
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100
Lil' Steve is offline   Reply With Quote
Old 02-10-2013, 10:21 AM   #73601
motolab
motolab's Avatar
Oddometer: 2,857
What color & consistency was the dirt?
Regards,
Derek
motolab is offline   Reply With Quote
Old 02-10-2013, 10:28 AM   #73602
motolab
motolab's Avatar
Oddometer: 2,857
True, except fuel filters get more restricted as dirt accumulates, which is generally a gradual process (i.e. no clogging completely all at once). That means that the symptoms will first manifest with the fuel being consumed more quickly than it can be replaced at large openings/high rpm.
Regards,
Derek
Old 02-10-2013, 10:41 AM   #73603
Escaped
Escaped's Avatar
Oddometer: 491
I also get excellent mileage out of Tourances.
QUOTE=kbuckey;20692600]Amusing. I guess I'm just a wuss 'cause my mileage has been
Tourance: 8997
Tourance: 9773
None of it "on a trailer."[/QUOTE]
2006 DR650 55,637 miles
DR650 - Eyes open all of the time
Escaped is offline   Reply With Quote
Old 02-10-2013, 11:48 AM   #73604
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Tourance: 8997
Tourance: 9773
That's excellent! I've not used a Tourance on my DR's but have used them on my former Tri Tiger and Vstrom. Longest wearing tire in that class of the 5 or 6 road biased dual sport tires. They cost more but last the longest, work well in rain, good handling. Not much good off road if muddy or deep sand but otherwise great tires.
Old 02-10-2013, 11:53 AM   #73605
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,948
Tourance: 8997
Tourance: 9773
Wow, I used to be lucky to get 3K miles out of a Tourance. That was on a DL 650 though.
Times are GMT -7.   It's 07:57 AM.
