Old 02-10-2013, 06:22 PM   #73621
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Doing my 790 kit this week. I bought a pair of ngk CR9EIX from Procycle. These are labeled as the hotter plugs. Did I make the right choice, or should I have gone with the standard plugs?
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 02-10-2013, 07:10 PM   #73622
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,575
Could you document it? I am very curious.
Fatfingering on tapatalk with my groovy iphone of doom.
You looked down here...didn't you.
MeterPig is offline   Reply With Quote
Old 02-10-2013, 07:37 PM   #73623
Jeathrow Bowdean
Oddometer: 458
Me to. 790 is a rocket ship on rails, and Jeathrow Bowdean likes rockets !!!!
Jeathrow Bowdean is offline   Reply With Quote
Old 02-10-2013, 07:41 PM   #73624
planemanx15
Oddometer: 1,009
Here you go!
http://advrider.com/forums/showthread.php?t=860980
Old 02-10-2013, 08:14 PM   #73625
Jeathrow Bowdean
Oddometer: 458
Gooder job planemanx15. This is my kind of unit when I first seen it on the Porcycle web page. Go big or go home is what my dad said.
from Jeathrow Bowdean
Old 02-10-2013, 09:24 PM   #73626
ER70S-2
ER70S-2's Avatar
Oddometer: 6,960
Originally Posted by Carl Childers View Post
Sorry, I should have read that better but it brings up a question I have. I thought I had read some where in the past about a filter in that location but I couldn't find it in the exploded carb diagram, I'm running an external fuel filter in the fuel line so I'd like to get rid the small one in the elbow. What's it take to do this? Also the elbow is stuck in its current position, any suggestions on how to get it off with out breaking it?
You won't be moving the elbow.
More info and pics in the link.
http://www.advrider.com/forums/showp...4&postcount=52
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 02-10-2013, 09:39 PM   #73627
ER70S-2
ER70S-2's Avatar
Oddometer: 6,960
Welcome to the biggest DR650 thread in the universe.
Originally Posted by spotlight View Post
OK so I took my new DR out for it's maiden voyage I had 31 miles on the ODO so I opted to be easy on it for a few.....well not so easy to do on such a fun machine and here in the mountains of east Tennessee.
.......also had to adjust the chain just after one ride.
What's your experience with motorcycles? The last thing you want on a new bike is for your chain to be too tight. I stand on the right side of the bike and lie across the the seat like a deer on the fender. Now I pull on the swing arm with my left hand and check the chain with my right hand; putting as much weight on the bike as I can. Don't pull the bike over on yourself. You can also use a ratchet strap over the seat to compress the suspension (put something over the seat to keep from ruining the cover).
So today I changed the oil and filter at 155 miles and installed the magnetic drain plug.
Good move. The one thing I wish I had done earlier is to put in a magnetic drain plug.
2013 WR250R
ER70S-2 screwed with this post 02-11-2013 at 08:05 AM Reason: )
Old 02-10-2013, 10:10 PM   #73628
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,281
let me add that I looped my fuel line and have run my IMS tank dry with no supply issues.
what is a little hard to see is this whole line package stays inside the tank area and away from my knees because I used a zip-tie on the rear hand-hose clip (just past the filter) that is then looped around the fuel line (near the carb inlet area).
this pulls the line back in and under the tank.
inlet inline filter is gone so i have the 1st filter in the tank with the IMS supplied petcock (works great for me) and then this second filter inline. no crap is getting in the carb, through the gas supply atleast.
i got this whole concept from someone else? and it works great. been using for over 2ys now and I can remove the line and tank fast or do a field change of the filter quickly.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 02-10-2013 at 10:21 PM
Old 02-11-2013, 05:35 AM   #73629
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 867
Holy smokes that filter is tiny! Can't wait to get it out of there. Thanks for all the replies and links regarding its removal and the fuel line routing pix. I just went to the 5 gal. Acerbis tank so the fuel line routing is of interest. I've had to do the"defy gravity loop" on mine too, Makes me wonder when the tank is nearly empty if there is still enough pressure to feed the carburetor?
New Mexico, not really new, not really Mexico.
Carl Childers is offline   Reply With Quote
Old 02-11-2013, 06:07 AM   #73630
kbuckey
Oddometer: 869
Originally Posted by Adv Grifter View Post
That's excellent! I've not used a Tourance on my DR's but have used them on my former Tri Tiger and Vstrom. Longest wearing tire in that class of the 5 or 6 road biased dual sport tires. They cost more but last the longest, work well in rain, good handling. Not much good off road if muddy or deep sand but otherwise great tires.
Yes they are great on pavement and good on (dry) dirt roads - until they get over about 6500 on them and then they aren't so good in the dirt. Just fine on pavement even when the rear gets pretty squared off.
kbuckey is offline   Reply With Quote
Old 02-11-2013, 06:49 AM   #73631
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,799
So maybe I've missed it, but what is the consensus on the inline fuel filter at the elbow?
Doesn't it seem to work?
Is the thinking that it inhibits fuel flow? Has anyone noticed fuel-starved motors working better after removing it?
I'm just not that worried about that much debris getting into it here for running around the USA. If i was a thrid-world traveler, sure, but ... ?
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 02-11-2013, 07:31 AM   #73632
procycle
procycle's Avatar
Oddometer: 2,412
Originally Posted by Mambo Dave View Post
So maybe I've missed it, but what is the consensus on the inline fuel filter at the elbow? Doesn't it seem to work?
The problem is that it takes so little debris to clog it up. Just a few grains of dirt will cause the bike to run poorly. That, coupled with the fact that nobody (especially shop mechanics) knows there's a tiny filter there. A little dirt will cause running problems that defy diagnosis.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 02-11-2013, 07:34 AM   #73633
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,549
I yanked mine and tossed it. I have an inline filter, so it was redundant.
Also, with an inline filter, you can verify if it is clogged very easily. Not so with that little hidden bastard. They sell clear inline filters that have a 90 degree bend in them if you have alignment issues.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 02-11-2013, 08:21 AM   #73634
Speedo66
Transient
Oddometer: 6,865
Looking for a white, right side number plate/side cover for an '05. Anybody have one, or can recommend a place to get an inexpensive aftermarket one or set?
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 02-11-2013, 08:34 AM   #73635
ER70S-2
ER70S-2's Avatar
Oddometer: 6,960
Originally Posted by eakins View Post
Let me add that I looped my fuel line and have run my IMS tank dry with no supply issues.
Yep, it seems some guys have no problem with the loop.
What is a little hard to see is this whole line package stays inside the tank area and away from my knees because I used a zip-tie on the rear hand-hose clip (just past the filter) that is then looped around the fuel line (near the carb inlet area).
That sounds like a good idea.
I just went to the 5 gal. Acerbis tank.......
I just may have to do one of those this summer.........
The important thing is knowing that possibility. Strap a spare gallon on the bike and ride until it quits, then you'll know if the tank is emptying.
2013 WR250R
Times are GMT -7.   It's 10:26 AM.
