Old 02-11-2013, 09:21 AM   #73636
Speedo66
Transient
Oddometer: 6,680
Looking for a white, right side number plate/side cover for an '05. Anybody have one, or can recommend a place to get an inexpensive aftermarket one or set?
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 02-11-2013, 09:34 AM   #73637
ER70S-2
ER70S-2's Avatar
Oddometer: 6,085
Originally Posted by eakins View Post
Let me add that I looped my fuel line and have run my IMS tank dry with no supply issues.
Yep, it seems some guys have no problem with the loop.
What is a little hard to see is this whole line package stays inside the tank area and away from my knees because I used a zip-tie on the rear hand-hose clip (just past the filter) that is then looped around the fuel line (near the carb inlet area).
this pulls the line back in and under the tank.
That sounds like a good idea.
Originally Posted by Carl Childers View Post
I just went to the 5 gal. Acerbis tank.......
I just may have to do one of those this summer.........
the"defy gravity loop"
Makes me wonder when the tank is nearly empty if there is still enough pressure to feed the carburetor?
The important thing is knowing that possibility. Strap a spare gallon on the bike and ride until it quits, then you'll know if the tank is emptying.
Originally Posted by procycle View Post
The problem is that it takes so little debris to clog it up. Just a few grains of dirt will cause the bike to run poorly. That, coupled with the fact that nobody (especially shop mechanics) knows there's a tiny filter there.
A little dirt will cause running problems that defy diagnosis.
2004 DR650: 62,400 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 02-11-2013, 09:58 AM   #73638
1989THEARK
1989THEARK's Avatar
Oddometer: 324
Originally Posted by Emmbeedee View Post
This is my current setup.
I gave up trying to make non-waterproof units into things they're not.
you might have a point if whatever i buy fails. im out a 300 dollar phone.
and still have to pay my 100 for a replacement and it will probably a refurbished phone.
if you dont mind i've bin looking for a tail bag as well to carry not so large objects in.
tried the tank bag option.
it always got in the way.
suggestions?
comments?
concerns?
1989THEARK is offline   Reply With Quote
Old 02-11-2013, 09:58 AM   #73639
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,164
Holy smokes that filter is tiny! Can't wait to get it out of there. Thanks for all the replies and links regarding its removal and the fuel line routing pix. I just went to the 5 gal. Acerbis tank so the fuel line routing is of interest. I've had to do the"defy gravity loop" on mine too, Makes me wonder when the tank is nearly empty if there is still enough pressure to feed the carburetor?
i emptied my IMS tank dry. the engine died as i coasted into the gas station (i was lucky as hell!), with my loop above. when i looked into the tank to see if it drained dry or stopped moving fuel because of the loop i saw a dry tank. there was no fuel left in the petcock area (except for gas wetness on the tank surface) and even the fuel from the right side of the IMS tank moved over by itself to the left side (no bike tipping to the left involved, just riding). even with a loop like mine, it drains all the fuel. i would replicate my setup on another DR in a heartbeat with no concerns. don't worry about.
Alaska
AZ map COBDR AZBDR IDBDR South East map
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 02-11-2013 at 10:08 AM
Old 02-11-2013, 10:23 AM   #73640
neo1piv014
ADV in training
Oddometer: 619
Procycle sells brand new plastics, and I think they actually sell the side panels separately from the other plastics. You might be able to find them cheaper used, but for new kit, they're solid.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 02-11-2013, 10:30 AM   #73641
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,339
There are no inexpensive side covers for the DR, damn things cost as much as a whole set of plastics for other bikes.
Old 02-11-2013, 10:31 AM   #73642
neo1piv014
ADV in training
Oddometer: 619
The problem is that it takes so little debris to clog it up. Just a few grains of dirt will cause the bike to run poorly. That, coupled with the fact that nobody (especially shop mechanics) knows there's a tiny filter there. A little dirt will cause running problems that defy diagnosis.
If you're just running regular old USA pump gas, how necessary is that little filter? Not that I'm too cheap to spend the five bucks or whatever for an inline filter, but I was thinking about just pulling that one out of the elbow to see how much of a difference it makes. My bike is a 2001, and I have a feeling that this was never touched by the previous owners.
Ride videos
'01 DR650
Old 02-11-2013, 10:38 AM   #73643
ER70S-2
ER70S-2's Avatar
Oddometer: 6,085
Mine at 28,000 miles, no aux filter, Colorado gas.
2013 WR250R
Old 02-11-2013, 10:45 AM   #73644
procycle
procycle's Avatar
Oddometer: 2,247
It only make s a difference if it gets clogged up. The biggest source of debris in the filter would be rust particles from the stock steel tank or plastic particles (from manufacturing) in an aftermarket tank. Of course you don't know the condition of the internal parts of the gas pumps where you fill up. I would not expect to get pure clean fuel at every podunk little gas station out where I like to ride.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 02-11-2013, 11:33 AM   #73645
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 8,983
I wrote my name and phone # on the inside of both my side covers. Hope I don't lose one in a "sensitive" area.
But if I lose it at an event, the organizer knows how to get it to me, and if I lose it somewhere else, hopefully a good Samaritan calls me.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 02-11-2013, 11:35 AM   #73646
Rusty Rocket
Life behind "Bars"
Oddometer: 8,983
Geesh, your fingers are dirtier, how many miles on them?
That wasn't what I found when I pulled mine at about 10,000 miles, it was a lot worse. Glad to have it gone.
2009 DR650
Old 02-11-2013, 12:05 PM   #73647
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
IMHO, 10,000 is too long to go between filter cleanings ... regardless of which filter you're using. Remember folks ... we've also got the internal filter screen on the Petcock stem. I am now pulling my petcock out about once a year and cleaning that filter and flushing tank. Seems to help the little filter stay cleaner. YMMV. No prob with in line filter as long as it's not impeding fuel flow and allowing use of most of the fuel remaining in the tank.
Here is my petcock after 20K miles without a clean:
There was more grit, rust and sand in the tank. The screen was a bit clogged. Tooth brush and Carb cleaner put it right. Paint is overspray from painting tank. (I am not a professional )
If you ride Mexico you may pick up stuff like this from time to time and your luck. I got gas several times from 55 gallon drums. Use a filter if you're concerned. (Rayon T shirt works well)
Old 02-11-2013, 12:28 PM   #73648
Rusty Rocket
Life behind "Bars"
Oddometer: 8,983
Grifter, I know you weren't spanking me, but just making a general statement for everyone, but in my defense I would like to say, I bought my DR650 with 9800 miles on it.
2009 DR650
Old 02-11-2013, 12:50 PM   #73649
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,164
i don't think it matters the gas location or type. this is about being prepared for that 1 bad/dirty gas station that could clog your bike no matter where you are in the world.
if you stay on top of checking that inline filter it works just fine and flows plenty of gas to run the bike. the problem appears when people do not know it's there or ignore it if they do and it clogs up easily if dirt is coming your way.
i'd guess most DRs in use just rely on this one. where it rears it's ugly head is when you've got carb/running issues and you fail to take this filter into consideration. by knowing it's there and checking it regularly you're filtered.
if your filter is clean when you pull it, don't expect your bike to run any better nor worse.
Alaska
Old 02-11-2013, 01:25 PM   #73650
shu
Oddometer: 996
And also.... when you're filling up in some station on the edge of some small town and the wind whips up a little cloud of dust from the fields next door, some of that crud is going to end up dropping into your tank through the open filler hole. I can see the grit clearly in my IMS 'clear' tank. It sits in the low spots of the forward lobes of the tank.
If you've ever tried to look through the hole in your pilot jet you know it wouldn't take much of a speck of dirt to clog it.
.............shu
shu is online now   Reply With Quote
Times are GMT -7.   It's 08:54 PM.
