Old 02-16-2013, 03:58 AM   #73801
dljocky
Oddometer: 864
I got 21,000 + miles out of my origianl chain/sprockets. I do change out the CS at about 8-10,000 miles though(Thankd ADV Grifter). Currently I'm sitting at right under 18,000 miles on this set up. I bought the OEM D.I.D. chain/sprockets. I also changed out my cush bumpers at the same time. I look at the EK chain, cush bumpers, sprocket kit that is sold by a popluar vender here, and I'm sure it's a good set up, but I wonder if I can get the same type of life with it vs the OEM stuff? It is a bit cheaper, but not by that much, especially if I can get more life out of the OEM stuff. This drive train isn't going to make it to 21,000 miles like the last one, so I'm getting ready to order something. Thoughts?
Originally Posted by biker128pedal View Post
I have been looking around at DR thumpers and was wonder how long the chains and sprockets last. I got 35k miles on the Vstrom but it is a twin. So for 80 to 90 percent road how much worse would it be? Also the Vstrom cush bumpers were in good shape. How do the DRs hold up? I found a little info searching but see what the latest opinions are.
650s rule.
dljocky is offline   Reply With Quote
Old 02-16-2013, 05:04 PM   #73802
refokus
Just Learning
refokus's Avatar
Oddometer: 2,487
Miles averaged
How many miles should a 650 get with regular oil changes. The regular maintenance?
Looking at an 07 with 18K on it.
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 02-16-2013, 05:26 PM   #73803
805gregg
Just Stroming along
Oddometer: 1,571
You can ride from Chicago to the tip of South America then all of Africa, then India.
805gregg is offline   Reply With Quote
Old 02-16-2013, 05:29 PM   #73804
shu
Oddometer: 1,028
Mine's an '08 with 54,800 on it now. Runs fine, sounds good, doesn't use any oil. I don't think that would be unusual for any well treated DR650. I use it for what it was designed: I don't baby it but I don't abuse it either.
I follow the Suzuki maintenance chart with oil changes and some kind of service every 3000-3500 miles. Servicing this bike is easy.
18,000 is not a lot of miles..... if the bike has been cared for.
............shu
shu is offline   Reply With Quote
Old 02-16-2013, 05:52 PM   #73805
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,521
Mine did eat 3rd gear at around 9,000 miles on the odo, i fixed it, about 10 miles from where i live there is a DR650 that is stock with over 100,000 miles on it, the guy rides it to work almost every day, i drive by his work place on my way to Tellico Plains.
ChromeSux is offline   Reply With Quote
Old 02-16-2013, 05:58 PM   #73806
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,005
Hey B. if i use AMS oil (when the the coins are good) i don't even touch it till after 5k and when i do change it, the viscosity is still good and oil is clear. Does it have any after market stuff?? Major mods? Pm a picture of it if u can.
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 02-16-2013, 06:03 PM   #73807
refokus
Just Learning
refokus's Avatar
Oddometer: 2,487
Thanks for all the replies to all.
Eddy, I don't have any pics, but will probably look at it tomorrow.
Old 02-16-2013, 06:34 PM   #73808
procycle
procycle's Avatar
Oddometer: 2,375
If you read thoroughly through the DR650 related forums you won't find anyone who has actually worn out a DR650 motor. There are plenty around with 50K+ miles and several in the 80K to 100K range still running along.
So, if it seems to run good don't sweat 18K miles. At that mileage it could need plenty of chassis related stuff - wheel bearings, fork seals, sprockets, brakes, suspension, etc. All pretty easy to check out and all pretty easy to address.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 02-16-2013, 07:08 PM   #73809
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,005
If u need me to to join u for the check up lemme know i have some free time noonish or in the evening. Either way good luck and lemme know if u need anything. I have some spare parts too in case u need any. I'll pm u my phone #...
Old 02-16-2013, 07:27 PM   #73810
Sierra Thumper
Oddometer: 641
Originally Posted by VooDooDaddy View Post
Been there, broke that.....
You guys are animals ......contrary to popular belief, a chisel ISN'T mans best friend
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 02-16-2013, 07:34 PM   #73811
LeDakaR!
LeDakaR!'s Avatar
Oddometer: 442
Ran some errands
Put these on
Went for wheely ride!!!
RIP Benjava, I finally did Alaska, thanks to you
www.route66moto.com
moto rental/sales and tours, location et vente moto, import-export
LeDakaR! is offline   Reply With Quote
Old 02-16-2013, 07:38 PM   #73812
ER70S-2
ER70S-2's Avatar
Oddometer: 6,713
44,118 today. Chains (2), some sprockets, lotsa tires, lotsa gas.
............shu
Full synthetic, magnetic drain plug.
Refokus, do not go here, do not click on this link.
http://www.procycle.us/bikepages/dr650.html
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 02-16-2013, 08:49 PM   #73813
refokus
Just Learning
refokus's Avatar
Oddometer: 2,487
Damnit, I couldn't resist. Spent 45 minutes looking at everything.
Old 02-16-2013, 09:01 PM   #73814
ER70S-2
ER70S-2's Avatar
Oddometer: 6,713
You're welcome.
2013 WR250R
Old 02-16-2013, 09:53 PM   #73815
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
damn it all i always spend time staring at that page wishing i lived in the states. the issue is postage to get something across the border. My upstairs neighbor has a time share in L.V. next time he goes down I will order parts and get em shipped to his place and he will bring em up for me !!
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Times are GMT -7.   It's 05:08 AM.
