Old 02-11-2013, 07:35 PM   #73831
procycle
procycle's Avatar
Oddometer: 1,597
Originally Posted by Rob.G View Post
You wanna put it in mine? I'm only an hour away. :)
Rob
Black motor... purple frame...
Looks like I need to buy another one. Looking for a good deal (just like many others!).
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 02-11-2013, 07:45 PM   #73832
bluegroove
Motorcycle junkie
bluegroove's Avatar
Oddometer: 376
I've used automotive fuel filters on bikes in the past. Just got to the autoparts store and look for one with the right angle in and outs. And the right diameter for the hose. You can get a MUCH bigger, free flowing filter this way for just a few bucks. I've done this on many bikes in the past with good results.
Former Mechanic in Honda and Kawasaki Dealer (eons ago). 38 yrs. of riding and racing dirt and street.
bluegroove is offline   Reply With Quote
Old 02-11-2013, 07:59 PM   #73833
spotlight
Noob
spotlight's Avatar
Oddometer: 37
Originally Posted by ER70S-2 View Post
Welcome to the biggest DR650 thread in the universe.
What's your experience with motorcycles? The last thing you want on a new bike is for your chain to be too tight. I stand on the right side of the bike and lie across the the seat like a deer on the fender. Now I pull on the swing arm with my left hand and check the chain with my right hand; putting as much weight on the bike as I can. Don't pull the bike over on yourself. You can also use a ratchet strap over the seat to compress the suspension (put something over the seat to keep from ruining the cover).
Good move. The one thing I wish I had done earlier is to put in a magnetic drain plug.
So then your saying check the chain slack with the bike loaded? And I have owned mostly dirt bikes had an XT-250 before this bike....
spotlight is offline   Reply With Quote
Old 02-11-2013, 08:16 PM   #73834
dman
Oddometer: 426
My older carb'd Ducati OEM fuel filter is getting hard to find and not cheap. Turns out that its really just a Denso filter also used on older Mitsubishi 4 cylinder cars (aka Dodge Colt in the US). My local NAPA store had one on the shelf for just a few bucks .... a real Made in Japan OEM part, not even a store-brand clone.
-dman
dman is offline   Reply With Quote
Old 02-11-2013, 08:58 PM   #73835
Sierra Thumper
Oddometer: 641
Originally Posted by Speedo66 View Post
OMG!!!
Just checked Procycycle and 2 pieces of plastic, PLASTIC, are $190 for a pair of F'n sidecovers!
The search continues.......
I think I payed about 40 bucks shipped for each of my xrl sidecovers with a forum member discount from another forum. Even without the discount they weren't much more. I wonder why suzuki charges so much for the DR parts?....prolly the same reason they charge so much for the busa parts.....because its a suzuki ........I'm very careful with my busa
My Kawi's always seemed fairly cheap considering as well.....
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 02-11-2013, 09:06 PM   #73836
ER70S-2
ER70S-2's Avatar
Oddometer: 2,542
If your chain is properly adjusted, it will be on the same adjustment notch; loaded or unloaded. Mid-travel is where the chain is tightest and is where I make sure there is some slack (lying across the seat). It won't be the 1-1/2"(?) stated in the manual, when loaded.
More clear?
Ok, I was just trying to keep a new rider from over tightening his chain, this wouldn't be you.
2004 DR650: 46,358 miles of
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 02-11-2013, 10:23 PM   #73837
Spirtwolf15x
Spirtwolf15x's Avatar
Oddometer: 8
110km now, running good just a question, as this is my first DR650 and my first "new" bike ever, I can hear my timing chain, it's not "loud", in fact I only hear it if I try to listen to it. I'm wondering what "normal" engine noise is for a DR.
Thanks.
Spirtwolf15x is offline   Reply With Quote
Old 02-12-2013, 05:43 AM   #73838
phreakingeek
phreakingeek's Avatar
Oddometer: 69
Dirtbagz in the flea market
Price dropped to $150 shipped.
http://advrider.com/forums/showthread.php?t=858510
phreakingeek is offline   Reply With Quote
Old 02-12-2013, 06:52 AM   #73839
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 2,043
Thanks...
Probably one of the easiest fixes in the interwebs. You need to wear earplugs when you ride.
http://breakingbooks.wordpress.com
http://www.kenmarshallmetalworks.com/
2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
acesandeights is offline   Reply With Quote
Old 02-12-2013, 07:45 AM   #73840
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 6,242
The chain will be tightest when the three pivots line up in a straight line
The countershaft, the swingarm shaft and the rear axle. If you can compress your suspension to that point and verify there is still a bit of slack you'll know you have it right. Then release the suspension and see what it needs to be when the suspension is unloaded and make a mental note or take measurements
1 First of all, the chain must be placed at its maximum tension condition. This condition will occur whenever the engine and wheel sprockets are at the maximum distance from each other.
To obtain this, it is generally necessary to load the back wheel (for example placing a person on the motorcycle) until the centers of the engine sprocket, the swingarm pivot and the rear wheel axle have been positioned on the same axis. The swinging arm will be parallel to the ground.
http://www.reginachain.it/eng/use_an...how_to05.shtml
1996 DR 650 (a big girl that likes it dirty)
1973 Penton Six-Days (mint)
1971 Suzuki TS185 (needs restoration)
2005 KTM 400exc w/ BajaDesigns D/S light kit
Rusty Rocket is offline   Reply With Quote
Old 02-12-2013, 07:55 AM   #73841
doug s.
Oddometer: 1,166
dr650 plastics/side panels
i emailed acerbis about side panels for the dr650:
hi!
when are you going to carry plastics for the dr650? you could sell a lot. especially side panels! ;~) suzuki has made the same model since 1996 - you would only need one set of molds... :>)
thanks,
doug s.
here's the answer i got:
Hello,
We do not get requests for plastics for that bike. We would have to have about 1500 request in order to start the project on making plastics for that bike. I can mention it to the higher ups but you are the only request I have had for a while sorry.
Thanks,
Brian
doug s.
doug s. is offline   Reply With Quote
Old 02-12-2013, 07:56 AM   #73842
Speedo66
Oddometer: 4,585
Originally Posted by vfr870 View Post
When the snow melts and I can get into my shed, I'll check to see if I have one for ya.
Thanks Steve!
'01 Kawasaki W650
'05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 02-12-2013, 08:37 AM   #73843
Spirtwolf15x
Oddometer: 8
I guess I'm just being paranoid, first break in and all. I want my bike to last and run well while it does.
Old 02-12-2013, 08:50 AM   #73844
neo1piv014
ADV in training
Oddometer: 610
The DR is definitely one of the noisier bikes I've ridden. Once you get used to it, it's all just part of the fun.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 02-12-2013, 09:10 AM   #73845
ER70S-2
ER70S-2's Avatar
Oddometer: 2,542
Thumb
You could add this to the DR650 index, it comes up regularly.
Times are GMT -7.   It's 11:59 PM.
