Old 02-23-2013, 01:46 AM   #74011
shaddix
Oddometer: 647
Originally Posted by FlowBee View Post
You might also try disconnecting the sidestand immobilizer switch to see if that helps. Your nanny government in cooperation with personal injury lawyers mandated these to protect you from yourself. Once disconnected you will discover the freedom to start the bike and let it idle on the sidestand.
I think I figured out it is the clutch so I'm going to do that little wiring change tomorrow to disable safety feature. I think the dr will let you start it with the side stand down as long as it is in neutral, or am I wrong abut that? I know I let it idle on the stand sometimes but maybe that's after I started it with the stand up first.
shaddix is offline   Reply With Quote
Old 02-23-2013, 03:03 AM   #74012
SoPaRider
Location: South Central PA/Michaux State Forest/Lincoln Hwy.
Oddometer: 296
Will any year Hayabusa muffler work with Jesse's (Kientech) mid-pipe adapter kit, there was a set of 'busa mufflers for sale on ebay that stated they would only fit 1999-2007 model 'busa's? There seems to be quite a range of prices for the 'busa mufflers out there, used ones for as little as $71.00 for a pair ($35.50 a piece), up to $100 or more for a new one.
Jeff (SoPaRider)
Third owner of a nearly new '09 DR650SE (I'm workin' on a buildin'!)
P.M. me for copies of my 15 Michaux State Forest Dual Sport Routes and check the Trip Planning/Tent Space Sign-Up Thread dated 8-22-11 for more info.
SoPaRider is offline   Reply With Quote
Old 02-23-2013, 04:01 AM   #74013
SCExpat
Ex-expat
SCExpat's Avatar
Oddometer: 634
The first one sold for $54.95 and free shipping. The second pair sold for $71 plus $40 shipping = $55.50 each! Good deals.
Thanks for the info. I'll be searching flea bay.
SCExpat is offline   Reply With Quote
Old 02-23-2013, 04:14 AM   #74014
SCExpat
Ex-expat
SCExpat's Avatar
Oddometer: 634
Jeff (SoPaRider)
The Kientech site lists part # 24FO http://kientech.com/DR650GSXRExaust.htm so that is what I would be looking for.
Just got a 2009 myself. Best year right
Old 02-23-2013, 06:38 AM   #74015
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,818
Jeff (SoPaRider)
99-07 is the first gen and should be fine. 08 on up the mufflers changed.
Old 02-23-2013, 06:55 AM   #74016
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Originally Posted by planemanx15 View Post
It does sound very poor, but has no problem revving. I'm 90% sure it's the top end. What should be done if the valve is touching the piston?
Does the exhaust sound bad? Like if you ignore the engine noise and just listen right at the muffler does it sound like it should or is it missing/sounding wierd? I dont know why a valve would have hit the piston other than being miss adjusted (unlikely as it weas riding just fine before) or the valve adjustment lock nut came loose and allowing the valve to move.
Either way if the valve has contacted the piston chances are you will be replaceing the valves (and valve springs as that could be another culprit). A weak valve spring combined with your new monstor motor could have caused this problem... How many miles on the bike again?
jessepitt is offline   Reply With Quote
Old 02-23-2013, 06:57 AM   #74017
planemanx15
planemanx15's Avatar
Oddometer: 1,009
The exhaust sounds fine, its just the valves, as if I adjusted then on the wrong TDC. But like you said the bike was fine right before and only started this under a highway load. Im 100% sure I did the valves on the correct TDC.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 02-23-2013, 07:03 AM   #74018
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
It would not have run if you had adjusted them on the wrong cycle. Maybe start by just pulling the valve covers and checking your settings before removeing the head, that way you will know if anything has moved and have a better idea what the cause may be.
Old 02-23-2013, 07:05 AM   #74019
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Kinda suprised Jeff hasnt chimed in on this but he may have missed your post on fri. and I think they are closed weekends. You may want to give them a call on monday if you havent found the problem.
Old 02-23-2013, 07:06 AM   #74020
planemanx15
Oddometer: 1,009
Strange part is I've done that, and there is no noise at all. Its only when running that I hear it. I would think that I would hear some sort of "Clink" when turning the motor by hand
Old 02-23-2013, 07:06 AM   #74021
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,799
I, on the other hand, did NOT do the valves on the correct TDC. Mine sounded close to that (CLACK CLACK CLACK CLACK CLACK ...), but I had only done the intakes (completely wrong), and shut it off pretty fast. I certainly didn't try to rev it, but... yeah - they're only little covers... take them off and see if you don't have gobs of space between the valves and the rockers now (like I did).
I mean, that would be the easiest thing to check first before even taking off the clutch cover... but then you're the one who is there, and if you're sure the sound is coming from the clutch, then so be it.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 02-23-2013, 07:11 AM   #74022
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
I dont think you would necesarilly hear it turning the engine over by hand.It could be that they dont touch unless they are running due to the high speeds and tight tolerances we are talking about with the valve train.
Old 02-23-2013, 07:12 AM   #74023
planemanx15
Oddometer: 1,009
Thats what I sounds like, But Im sure I did the valves fine. The bike ran good for 50 miles before any of this noise started. When i checked it last night, the space between the rockers and the valves were minimal. I have a strong feeling I have a bent valve.
Old 02-23-2013, 07:14 AM   #74024
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Yeah, me too. Could you get a feeler gauge in there or are they tight tight?
Old 02-23-2013, 08:06 AM   #74025
Harry94025
Oddometer: 294
If the valve is bent, I am curious how it would still have enough compression to start...
Harry94025 is offline   Reply With Quote
Times are GMT -7.   It's 10:22 AM.
