Old 02-23-2013, 08:14 AM   #74026
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Yeah, me too. Could you get a feeler gauge in there or are they tight tight?
jessepitt is offline   Reply With Quote
Old 02-23-2013, 09:06 AM   #74027
Harry94025
Oddometer: 273
Originally Posted by planemanx15 View Post
It does sound very poor, but has no problem revving. I'm 90% sure it's the top end. What should be done if the valve is touching the piston?
If the valve is bent, I am curious how it would still have enough compression to start...
Harry94025 is offline   Reply With Quote
Old 02-23-2013, 09:10 AM   #74028
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
It may not be very far off and has hammered itself to shape so that it runs. Planemanx said it died when he first pulled over but it would idle by the time he got home. He may have riden it far enough to make it semi-reseat. IDK just thinking out loud, the tear down will tell the tail.
Old 02-23-2013, 09:19 AM   #74029
sandwash
sandwash's Avatar
Oddometer: 1,333
Long shot here,auto comp messed up?
97dr650
sandwash is online now   Reply With Quote
Old 02-23-2013, 09:22 AM   #74030
procycle
procycle's Avatar
Oddometer: 2,247
Thats what I sounds like, But Im sure I did the valves fine. The bike ran good for 50 miles before any of this noise started. When i checked it last night, the space between the rockers and the valves were minimal. I have a strong feeling I have a bent valve.
Correct, it would not run (or even start) with a bent valve. Besides that there is a ton of clearance designed into the 790 piston. It would take some unusual circumstance for a valve to contact the piston.
I would not start it again. It will have to be disassembled to find the source of the noise. I read back through the install thread and did not see any mention of checking/adjusting the ring end gaps. Did you check the gaps?
Any guesswork done from listening to the noise is just that - guesswork.
It's a bummer to have to tear it apart but like Rob said it is easier and goes faster the second time.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 02-23-2013, 09:39 AM   #74031
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 163
This was also a question I posed to Planemanx in his build-up thread. This was my guess as well. Ran the bike long enough to get it completely up to temp on a cold day, rings expanded without enough gap, possibly broke due to expansion?
VooDooDaddy is offline   Reply With Quote
Old 02-23-2013, 11:08 AM   #74032
planemanx15
planemanx15's Avatar
Oddometer: 1,007
Thanks for all the suggestions everybody, I opened everything thing up and found the issue:
The valves were completely fine.
As you can imagine I'm pretty disturbed. Everything ran fine, even on the highway going out to the twistys. On the ride back i assume the rings expanded too much and this happened. As I said in my build thread, I did not measure the end gap. I assume had I done this, I could be riding today.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 02-23-2013, 11:18 AM   #74033
planemanx15
Oddometer: 1,007
Could I just get new rings and fix this?
Old 02-23-2013, 11:19 AM   #74034
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Yes ... I remember from your build thread that you had trouble getting the piston into the bore and trouble compressing the rings. I remember you mentioned it was a "TIGHT FIT". To me that is a Red Flag. Either you were given incorrect rings or out of spec cylinder or incorrect piston. (???)
Did you measure each piece before assembly?
Perhaps the ring gaps were not positioned correctly? And of course measuring ring end gap is part of the process.
When you do this again ... try to organize your work area a little better.
Take your time, go step by step, check everything along the way.
New sleeve (or barrel), piston & rings?
Good luck, let us know what you find after measurements ... maybe you've got a refund due you?
No way. The Piston an cylinder are badly scuffed ... They look finished to me. Bummer.
Old 02-23-2013, 11:37 AM   #74035
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,292
The exhaust sounds fine, its just the valves, as if I adjusted then on the wrong TDC. But like you said the bike was fine right before and only started this under a highway load. Im 100% sure I did the valves on the correct TDC.
Obviously the scoring you found is a problem....
I'm suffering through a safety seminar today and unable to listen to your video at the moment; just wanted to share that my high compression piston upgrade also introduced nasty noises that progressively got worse. I replaced the spring loaded cam chain tensioner with the manual one I bought from Procycle and she's smooth as silk again.
I would recommend getting one on order to install once you've corrected the scoring problem.
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 02-23-2013, 11:42 AM   #74036
procycle
procycle's Avatar
Oddometer: 2,247
The first step would be to hone the damage out of the cylinder. This must be done with a rigid hone not a spring loaded or ball hone. Then measure to see if the bore will still be within spec. If you're lucky it may still be usable. It just depends on how deep the scores are in the cylinder wall.
You'll need at minimum a piston and rings. And of course check the ring gaps and file them as necessary to avoid a repeat.
The ring instructions call for .0045" of gap per inch of bore for the top ring. This works out to .020" Because DR650s do such good job of cooling the piston and have an air cooled cylinder I fudge this spec down to .018". The second ring should have a .004"-.008" larger gap. The oil control rings should have a minimum of .015" gap.
Old 02-23-2013, 11:50 AM   #74037
planemanx15
Oddometer: 1,007
Alright, sounds good, thank you for the weekend help .
Please PM\email me when you get a chance about the cost of a new piston and rings and a possible cylinder exchange.
I just went to look at it again, and the cylinder seems fine, it suffered very minimum damage compared to the piston. How can I tell for sure if its okay?
Top ring: .020"
2nd ring: .024-.028"
Oil ring: .015"
Old 02-23-2013, 02:12 PM   #74038
TrophyHunter
Oddometer: 2,166
So sorry for the results, PM. The school of hard knocks has taught me to read instructions twice, go slow & follow the step by step. I still get caught occasionally being a guy....and then going back to do it right.
I'm sure with some measurements, PC will be able to tell you if it's recoverable with a hone, new piston & rings.
Best of luck with the fix.
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 02-23-2013, 03:04 PM   #74039
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 584
By honing out all the visible scrape marks and then checking to see if the cylinder is still in spec. The shade tree way to do that is to push a piston ring into the bore squarely with an upside down piston and check it's gap at the top, the middle and the bottom of the cylinder with a feeler gauge. the gaps should be the same and consistent with the correct specified ring gap. A set of bore mic's are better but this method has worked well for more than a century.
New Mexico, not really new, not really Mexico.
Carl Childers is offline   Reply With Quote
Old 02-23-2013, 06:30 PM   #74040
Harry94025
Oddometer: 273
That kind of scoring happens when the oil film fails. Not sure how much engine experience you have, but are the rings positioned correctly? The compression rings are usually directional; they have a top indicated with a dot or other mark. If they were upside down, the blow-by would cause the oil film to fail.
Regards,
Harry
Times are GMT -7.   It's 09:58 AM.
