Old 02-25-2013, 08:03 AM   #74056
maynard911
Oddometer: 142
Originally Posted by Load Clear View Post
Hey All - First, I'd like to say thanks for all the advice and info I've gotten and read here. The best advice I've gotten is a) Buy the DR650 & b) put down the tools and walk away
I am looking for some more. I will be moving back to Very Northern AZ in the summer. I bought my bike here in NY at about 300ft. I will be living closer to 6,000 and riding up to around 10,000+ in Colorado/Utah.
Do I need to change anything on the bike for the altitude? Sand storms are routine; as is heavy wet clay. Anything necessary to protect the motor and whatever else may be harmed by the sand and clay?
I have a 2012, completely stock.
Next week I am going to start asking about farkling it out.
Originally Posted by procycle View Post
The high elevation will transform the 'too lean' factory jetting to 'just about right' jetting.
*1 on what Jeff says.
I'm in southern AZ at about 5200 ft and found the stock jetting to be close with a completely stock bike. After removing the snorkel I did raise the needle with a thin shim and it was about perfect. You will want to pull the plug on the idle mixture screw and get it set properly as described many times here.
I think that you will find that what you are calling 'sand storms' are really dust storms, caused by that same clay that you were concerned with when wet. The clay is made up of very fine particles that being light are prone to going airborne, especially in the high winds of spring, but are also a major concern when riding in groups as the dust will hang in the air for a long time. Regular air filter maintenance is important, and don't even think about K&N, stick with the stock or aftermarket oiled foam filter.
Maynard " Youth is fleeting, immaturity is forever"
maynard911 is offline   Reply With Quote
Old 02-25-2013, 10:26 AM   #74057
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,730
anyone here having trouble finding the SeatConcepts website? I can't find it.
I get a weird redirect that doesn't have M/C seats.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 02-25-2013, 10:53 AM   #74058
wee-twin
Oddometer: 197
I just tried and same thing happened to me. Weird.
wee-twin is offline   Reply With Quote
Old 02-25-2013, 11:12 AM   #74059
Rusty Rocket
Life behind "Bars"
Oddometer: 9,730
On another note, DirtBike Magazine has an article this month about making a DR650 into an adventure bike. (just finished reading it at the supermarket) That will make used examples disappear a bit quicker.
2009 DR650
Old 02-25-2013, 11:28 AM   #74060
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,403
They have a note in the vendor section that their website is currently down. They haven't gone anywhere. - http://www.advrider.com/forums/showt...=seat+concepts
Originally Posted by mxbundy View Post
Hey guys our site is down until mid Monday morning.
Sorry for the inconvenience.
You guys can give us a call at 951-741-0722 or 951-756-1030 and we will be happy to help you guys over the phone.
Bundy
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 02-25-2013, 12:20 PM   #74061
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Harry94025 View Post
Planemanx15,
One last thing... Remember that the metal that used to be part of your piston skirt is now somewhere in the engine. I would check the crank and connecting rod bearings very carefully by rotating them by hand to sense any roughness. Remove the oil filter and cut it apart; hopefully you'll see evidence of the metal trapped there. Drain the oil and see if you see silvery bits of aluminum, then flush things out as best as you can. The oil cooler would also be a good candidate for a flush.
Regards,
Harry
PLUS ONE!!! ++++++++++
Old 02-25-2013, 12:28 PM   #74062
Adv Grifter
Oddometer: 6,128
Stock jetting should be fine ... until you get up over about 10K ft.
For off road Desert riding I'd get some sort of bash plate ... and side case covers. Bark Busters of some sort too to protect hands, levers and Master cylinder.
If the motor gets muddy, don't worry but try to keep the oil cooler clear of mud ... but DO NOT bend delicate fins. Hose off SOON after ride. Don't wait for mud to turn to HARD POTTERY.
You'll need knobbies for Desert riding. Dunlop D606, Conti TKC80 are good to start, but LOTS of tire options. Knobbies make sand easier.
Have fun. TONS of amazing territory in and around Grand Canyon and up into Utah.
Old 02-25-2013, 12:37 PM   #74063
Adv Grifter
Oddometer: 6,128
Originally Posted by frecks View Post
So after suffering a catastrophic engine failure a couple years ago(that can be attributed to me not torquing things down to spec), I'm finally rebuilding my engine. My clutch pack appears to still be in good condition, but some of the aluminum shavings that were coursing through my engine seem to have gotten in the clutch pack. The clutch pack has also been sitting in a box in the garage for the past 2 years.
I'm wondering what the collective wisdom of this thread thinks is the best way to clean it and prep it for re-install.
As for lessons learned; Loctite and torque wrenches are significantly cheaper than crankcases, crankshafts, and clutch baskets.
I would get some professional help on the rebuild. There are SO MANY places to make mistakes ... even for guys with experience.
CLUTCH
Clean plates with oil, wipe off very well. Soak plates in clean oil for 2 - 3 hours before install. DO NOT use synthetic oil in new engine.
I would be more worried about metal bits still inside the engine, oil lines, Oil pump, oil cooler/hoses. Flush it all out a couple times with cheap oil or oil and Kerosene mix before running. Do an Engine oil and filter change after 20 miles. (to be safe). Another at 200 miles. Best of luck ... but luck won't help really. Get a pro to help out.
Old 02-25-2013, 01:59 PM   #74064
Rusty Rocket
Life behind "Bars"
Oddometer: 9,730
Thanks.
2009 DR650
Old 02-25-2013, 03:15 PM   #74065
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,276
Originally Posted by doug s. View Post
a little ot, but have you had any experience w/totalseal rings? comments?
thanks,
doug s.
ps - about your tag line - do you really think the guy who invented the 1st wheel and the 2nd wheel were different guys?
I have tried them in two motors because the customer wanted to try them. They both sucked and I ended up putting in a standard style ring. The biggest problem with them is they don't ever seem to "break in". The leak down numbers are awsome...the actual running is less then desirable. Was burning so much oil it was putting the plugs out. We even took the one motor back apart- re-honed to Total Seal's specs, ran the oil they reccommended and broke it in like they said. Still no luck. Their tech people said we must be doing something wrong.... Yeh right. We put in a set that cost 1/2 the price and picked up 15 HP and no oil burn issues. That was all the proof I needed to never run them.
Total Seal makes a standard gap ring set- I think they call it "classic ring pack". I have run those with no problems.
If anyone cares:
I can tell you from experience that rings start touching each other and causing damage at around .010" gap. In trying to get some HP on dirt track motors we kept narrowing the gap... bad stuff below .011" The other thing we found is ring gap doesn't make that much diffrence between .015" and .025" in HP (less then 1/2 HP) We now run .020-.024 top and .022-.025 2nd on 90% of our setups.
Mongle is offline   Reply With Quote
Old 02-25-2013, 03:36 PM   #74066
procycle
procycle's Avatar
Oddometer: 2,462
If anyone cares:
Good info Mongle! Nice to hear from someone who has actually done the testing.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 02-25-2013, 04:14 PM   #74067
gofast1320
gofast1320's Avatar
Oddometer: 752
14 tooth front
Got some stuff from procyle the other day and found time to get outside and play with the DR650. Put the 14 tooth front sprocket on and while in there put that seal retainer thing on it too. Even used locktite blue like I was supposed to. Adjusted the chain and fired it up. REMIND SELF TO GET NEW BATTERY. Its on its last legs even on trickle charger.
Took the bike for about a 5 mile run out back through the garden across the pasture through the woods across the creek and back. Absolutely love the difference in the way the bike runs with the 14t sprocket. Doesn't lug down at slow speed in first gear and is way easier to manage.
Soon as I get my mid pipe from Klientech I'll be posting about the X40FO hook up. Hope to see that before the week is out.
gofast1320 is offline   Reply With Quote
Old 02-25-2013, 04:26 PM   #74068
buckrut1972
H.R. Nightmare
buckrut1972's Avatar
Oddometer: 112
Loved every minute of it.
Got an opportunity to get a bigger bike and a friends dad make me an offer I can't pass up. So I'm sorry to see her go after a short time together here it goes.
09 DR650
SW Center Stand, Cycra Handguards, MRA Windshield, Epic Panniers, Hyper Lites, Renthal Bars, Acewell Digital Speedo, Seat Concepts upgrade, Smash Plate, Pelican Top Box (maybe), EBC pads, FMF exhaust, thousands of miles left on tires, recent oil and filter change. To much more to mention but you get the concept. Right at 8800 miles. Pics to follow.....located in West Point, Virginia, 30 miles east of Richmond. Got it out there on CL for $4700 but I'll give an inmate discount!! PM for any interest.
"Never argue with stupid people, they will drag you down to their level and then beat you with experience" Mark Twain
buckrut1972 is offline   Reply With Quote
Old 02-25-2013, 05:54 PM   #74069
SoPaRider
Location: South Central PA/Michaux State Forest/Lincoln Hwy.
Oddometer: 300
Searching for a source for '96 DR650SE purple frame touch-up paint?
Does anyone know of a source for the purple frame paint used on the 1996 Suzuki DR650SE and other models of that era? ColorRite.com only shows Code 30H-Special White-4037 available for the 1996 model, which would have been for the white fuel tank, rear rack, etc..
P.M. me for copies of my 15 Michaux State Forest Dual Sport Routes and check the Trip Planning/Tent Space Sign-Up Thread dated 8-22-11 for more info.
SoPaRider is offline   Reply With Quote
Old 02-25-2013, 06:25 PM   #74070
805gregg
Just Stroming along
Oddometer: 1,594
Just go to Sargent, they will be there
805gregg is offline   Reply With Quote
Times are GMT -7.   It's 01:57 AM.
