02-23-2013, 08:08 PM
#74206 | |
Oddometer: 1,169
thanks, doug s. ps - about your tag line - do you really think the guy who invented the 1st wheel and the 2nd wheel were different guys?
02-23-2013, 08:55 PM
#74207 | |
Oddometer: 172
Harry |
02-24-2013, 02:43 AM
#74208 | |
Oddometer: 214
Perhaps the first guy liked to ride a unicycle
Currently riding DR650 (2011) Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks
02-24-2013, 07:04 AM
#74209 |
Oddometer: 1,607
I have not had any personal experience with Total Seal rings but I did look into them for the 790 kits. They don't offer 'off the shelf' rings in the correct size but there are some for a .002" bigger bore that could probably be used. Total seal rings still have to be gapped before installation. Total Seal calls for a bigger gap spec - .0065" or more per inch of bore. That would be .028" on the 790. The feature that makes them 'gapless' is an insert that fits under the ring that bridges the gap in the main ring.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup |
02-24-2013, 08:27 PM
#74210 | |
Oddometer: 172
One last thing... Remember that the metal that used to be part of your piston skirt is now somewhere in the engine. I would check the crank and connecting rod bearings very carefully by rotating them by hand to sense any roughness. Remove the oil filter and cut it apart; hopefully you'll see evidence of the metal trapped there. Drain the oil and see if you see silvery bits of aluminum, then flush things out as best as you can. The oil cooler would also be a good candidate for a flush. Regards, Harry |
#74211 |
recycle crime scene tape
Oddometer: 399
Owners Manual
DR 650SE 1st. Generation Owners Manual (1994 printing)
Free! PM me, pay for postage and it's yours (USA only) not a shop manual very good condition Owners Manual 1st person to contact me gets it
~DR 650~ Upgrades: 1. dented tank |
02-24-2013, 08:34 PM
#74212 | |
Oddometer: 739
2000 Suzuki DR650 - 790cc Big bore kit, V-Strom seat, Warp 9 Supermoto rims, TM-40 carb. 1985 Yamaha CA50 - My Hot Rod 2009 Piaggio BV-250 - Escusi, Babba be bo-bee |
02-24-2013, 09:37 PM
#74213 | |
Engineering student
Oddometer: 266
__________________ Across the country on the kindness of strangers and the strangeness of friends (and a DR650). My LinkedIn Profile |
02-25-2013, 01:59 AM
#74214 |
Oddometer: 25
High Elevation
Hey All - First, I'd like to say thanks for all the advice and info I've gotten and read here. The best advice I've gotten is a) Buy the DR650 & b) put down the tools and walk away
![]() I am looking for some more. I will be moving back to Very Northern AZ in the summer. I bought my bike here in NY at about 300ft. I will be living closer to 6,000 and riding up to around 10,000+ in Colorado/Utah. Do I need to change anything on the bike for the altitude? Sand storms are routine; as is heavy wet clay. Anything necessary to protect the motor and whatever else may be harmed by the sand and clay? I have a 2012, completely stock. Next week I am going to start asking about farkling it out. Thanks |
02-25-2013, 02:41 AM
#74215 |
Oddometer: 3,503
Shameless Plug
Just posted a tank and skid plate in the Flea Market:
http://advrider.com/forums/showthread.php?t=865833 Sarah
'08 DR650 |
02-25-2013, 07:12 AM
#74216 | |
Oddometer: 1,607
02-25-2013, 07:54 AM
#74217 |
Oddometer: 143
So after suffering a catastrophic engine failure a couple years ago(that can be attributed to me not torquing things down to spec), I'm finally rebuilding my engine. My clutch pack appears to still be in good condition, but some of the aluminum shavings that were coursing through my engine seem to have gotten in the clutch pack. The clutch pack has also been sitting in a box in the garage for the past 2 years.
I'm wondering what the collective wisdom of this thread thinks is the best way to clean it and prep it for re-install. As for lessons learned; Loctite and torque wrenches are significantly cheaper than crankcases, crankshafts, and clutch baskets.
02-25-2013, 08:03 AM
#74218 | ||
Oddometer: 137
I'm in southern AZ at about 5200 ft and found the stock jetting to be close with a completely stock bike. After removing the snorkel I did raise the needle with a thin shim and it was about perfect. You will want to pull the plug on the idle mixture screw and get it set properly as described many times here. I think that you will find that what you are calling 'sand storms' are really dust storms, caused by that same clay that you were concerned with when wet. The clay is made up of very fine particles that being light are prone to going airborne, especially in the high winds of spring, but are also a major concern when riding in groups as the dust will hang in the air for a long time. Regular air filter maintenance is important, and don't even think about K&N, stick with the stock or aftermarket oiled foam filter.
Maynard " Youth is fleeting, immaturity is forever" |
02-25-2013, 10:26 AM
#74219 |
Life behind "Bars"
Oddometer: 6,252
anyone here having trouble finding the SeatConcepts website? I can't find it.
I get a weird redirect that doesn't have M/C seats.
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
02-25-2013, 10:53 AM
#74220 |
Oddometer: 141
