Old 02-25-2013, 08:24 PM   #74236
dman
Oddometer: 426
Originally Posted by buckrut1972 View Post
What is that mini-tankbag? Thanks.
-dman
dman is offline   Reply With Quote
Old 02-25-2013, 08:26 PM   #74237
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,175
DR650 Chain guard
Originally Posted by badweatherbiker View Post
anyone have an upper chain guard you want to part with? I figure since replacing everything else why not put the missing guard on there...
Broke my chain guard and found a CB550 Honda chain guard fits great but is a little long. Tin snips cut it to length and got it cheap at a bike wrecking yard. Much heavier duty plastic and metal lined and the mounting holes lined up perfectly.
Dave
smilin jack is offline   Reply With Quote
Old 02-25-2013, 09:04 PM   #74238
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 8,077
Didnt search the whole thread...duh...
Search engine didn't help...duhh...
What are you guys using for Fork leg cover after you factory lower the front?
Squashing in the OEM gaiters?
Dirt Skins? Any good?
or what?
I am not intimidated by the DMV
James and Colleen Tucker.
Real Cafe Racers drink tea.
Aut viam inveniam aut faciam
TUCKERS is offline   Reply With Quote
Old 02-25-2013, 09:25 PM   #74239
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 2,061
The factory gaiters work fine.
http://breakingbooks.wordpress.com
http://www.kenmarshallmetalworks.com/
2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
acesandeights is offline   Reply With Quote
Old 02-25-2013, 09:49 PM   #74240
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 8,077
Anybody use dirtskins?
Old 02-25-2013, 09:49 PM   #74241
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 8,077
even with the permanent 2" squash?
Old 02-26-2013, 12:19 AM   #74242
Magnum Noel
Magnum Noel's Avatar
Oddometer: 149
Yep when i lowered mine the standard gaiters worked fine. Later put on seal savers just for asthetics.
Magnum Noel is offline   Reply With Quote
Old 02-26-2013, 03:43 AM   #74243
greer
Oddometer: 3,495
Factory gaiters are the ticket, in my opinion. I used skins on another bike and they are plenty nice, but you have to take care to install them securely in order to keep them in place and check them frequently to make sure they haven't slipped. With factory gaiters you're good to go.
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 02-26-2013, 05:28 AM   #74244
buckrut1972
H.R. Nightmare
buckrut1972's Avatar
Oddometer: 80
Had one of those ATV wrap around tank bags I cut up and stapled to the back side of the seat. Works perfect for wallet, cell and camera type stuff.
-dman
"Never argue with stupid people, they will drag you down to their level and then beat you with experience" Mark Twain
buckrut1972 is offline   Reply With Quote
Old 02-26-2013, 06:31 AM   #74245
acesandeights
Asperger
Oddometer: 2,061
Yes.
Old 02-26-2013, 06:33 AM   #74246
frecks
frecks's Avatar
Oddometer: 143
Originally Posted by Adv Grifter View Post
I would get some professional help on the rebuild. There are SO MANY places to make mistakes ... even for guys with experience.
CLUTCH
Clean plates with oil, wipe off very well. Soak plates in clean oil for 2 - 3 hours before install. DO NOT use synthetic oil in new engine.
I would be more worried about metal bits still inside the engine, oil lines, Oil pump, oil cooler/hoses. Flush it all out a couple times with cheap oil or oil and Kerosene mix before running. Do an Engine oil and filter change after 20 miles. (to be safe). Another at 200 miles. Best of luck ... but luck won't help really. Get a pro to help out.
Thanks for the advice! I actually got an entire bottom end from someone who was parting out their bike. I'm just swapping my cylinder, piston, head, and clutch onto the new bottom end. Much easier since I don't have to split the cases or worry about the metal bits still in the bottom end. I will be taking your advice regarding oil/filter changes anyway though. I've got a couple of very experienced inmates that are helping me out with this project. It's already stripped down and we will be starting to put it back together as soon as my wrist pin and rings get here.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
frecks is online now   Reply With Quote
Old 02-26-2013, 07:21 AM   #74247
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 1,720
I have a set of these I just got from ProCycle. They work fine. I'll admit I preferred the previous ones I got from them that were one-piece (you had to remove the fork tubes to install them)... these have velcro, so it takes a little patience to get them just right. Then secure with zipties.
Rob
'96 Suzuki DR650, '10 Kawasaki KLX250S, '01 Yamaha FZ1
The Lane Sharing Works Blog | My SPOT Page
Rob.G is offline   Reply With Quote
Old 02-26-2013, 10:09 AM   #74248
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 2,908
Send a message via AIM to Bronco638 Send a message via Yahoo to Bronco638
I am too.
Sarah
My gaiters looked funky because they're used to being a certain length and are now "squashed". The DR came without lower clamps and the p.o. had secured them with Zip Ties. That seemed to work OK. With the DirtSkinz, they're long enough to push them past the thickest diameter of the lower fork leg. I secure them with Zip Ties just below where the fork seals reside. They can't move upwards at all. But, Sarah brings up a good point, check to make sure they're secure and have not slipped and you should be fine.
Rob
Yeah, the Velcro can be a little touchy to get just right.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 02-26-2013, 10:26 AM   #74249
ER70S-2
ER70S-2's Avatar
Oddometer: 2,566
There is a front and rear on the stock boots. The bottom pleat has a series of holes to vent, these go to the rear. If they're in the front, they'll act like scoops for dust and water. The cast line on the boot (2 per boot), goes to the outside as an alignment guide.
2004 DR650: 46,358 miles of
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 02-26-2013, 12:07 PM   #74250
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,400
Sarah
I like factory gaiters too ... but I don't believe they are maintenance free. If you dirt ride, rain ride or ride in mud ... it's best to loosen clamps and clean dirt/mud out from around fork seal. It collects there and will eventually cause a seal failure. Otherwise, they are great.
(remember, the stock gaiters have little vent/drain holes ... and that is how the water and dirt gets in)
Times are GMT -7.   It's 02:07 AM.
