Old 03-07-2013, 09:03 PM   #74431
dman
Oddometer: 605
Bump - Lower rear chain guide
Originally Posted by dman View Post
Hi - my DR is missing the horizontal "block" part of the rear chain guide (vertical plates are OK). Only a complete assembly seems to be available, either OEM plastic parts or Moose or other aluminum aftermarket guides. Cost is about the same .... any recommendations? If you have gone aftermarket and have the stock part and screws that you want to get rid of PM me.
Thanks - dman
Any inputs??
Thanks - dman
dman is offline   Reply With Quote
Old 03-07-2013, 09:03 PM   #74432
YankeeCajun
Oddometer: 22
Thumb
Originally Posted by Escaped View Post
I don't think any damage was done running the motor briefly with out oil. The bearings still had oil on them and the motor did not heat up and no load was on it. I would not worry.
Long long time ago, a buddy and I wanted to see how long a 1970 something Toyota would run with out oil (the car was destined for the wrecker). We drained the oil, started the car and put a brick on the accelerator pedal .... It kept running and running, the rpm's would drift because of valve float but it keep going! Then after like a half an hour, we turned it off, drained the coolent and started it up again. It lasted 10 min after that!
I hope you're right about not damaging my motor . I really only ran it for like a minute and quickly shut it off. I like your Toyota story. Sounds like a guy I know that tried to rev up and do burnouts all the time in an attempt to kill the motor in his old GS 1100. He never succeeded!!!
YankeeCajun is offline   Reply With Quote
Old 03-07-2013, 09:40 PM   #74433
saddlsor
my butt hurts
saddlsor's Avatar
Oddometer: 334
Any inputs??
Thanks - dman
have you seen this? maybe it will give you some idea's.
http://advrider.com/forums/showthread.php?t=667646
I don't know where I'm going, not sure where I've been.
-john denver
99 dr350
78 r80
saddlsor is offline   Reply With Quote
Old 03-07-2013, 09:48 PM   #74434
Hesaid
Hesaid's Avatar
Oddometer: 1,369
Quick question:
I've searched and come up empty, is there a list of all factory DR colors (or colours if you're into that sort of thing...)? It'd be really handy if such a list included color codes and/or years available. You know, in case one wants to order body parts in other colors or some such. Off the top of my head I can think of:
Grey
Black
White
Yellow
Blue
MV
Hesaid is offline   Reply With Quote
Old 03-07-2013, 10:27 PM   #74435
kano650
more cowbell
kano650's Avatar
Oddometer: 217
Originally Posted by TEZZA View Post
Hi all , i am looking at a 2004 DR650 with 54,000 kms ,
What would be the the most kms would you get out of the Suzuki motor , would it get a lot more out of this motor or would it be looking at a rebuild soon.
Thanks Tezza.
I've got an 03 with 48,000km on it and its still going strong. A mate had one the same and it blew up at about 85,000km. Its anyone's guess but if you look after it, change the oil and clean the filter regularly i would think 100,000 + would be attainable. I might consider tearing the engine down on mine at about 80,000 and a freshening it up before it dies.
kano650 is offline   Reply With Quote
Old 03-08-2013, 12:02 AM   #74436
LexTalionis
Inciteful
LexTalionis's Avatar
Oddometer: 441
Originally Posted by Adv Grifter View Post
I first tried the Cramp Buster ... and similar devices 25 years ago. On a long, straight, boring stretch of endless pavement they are fine ... but very distracting in a any sort of riding where you are working the bike and throttle. Constantly gets in the way ... almost dangerous ... IMO.
But the MAIN THING IS ... the Cramp Buster does not solve the problem of a TOO STIFF return spring and still requires more force than it should. You can't do fine motor control on the throttle using the Buster. The palm of your hand is not good for accurate throttle control. Fine for steady state droning ... but nothing more, IMO.
The FCR Keihin Carb is much better. Light and easy ... and that is probably why most major dirt bike OEM's used the FCR over the TM. (now most are F.I.)
For only the second time in four years do I disagree with you. I've had these devices - the "fat" variant - on all my four bikes (cruiser/sportbike/dualsport) for the past decade, and would not ride any of my bikes anywhere without them.
Lex
The older I get, the better I was.
LexTalionis is offline   Reply With Quote
Old 03-08-2013, 12:10 AM   #74437
Chill
Chill's Avatar
Oddometer: 323
Originally Posted by Hesaid View Post
Quick question:
Grey
Black
White
Yellow
Blue
MV
There have also been silver and red I believe. Have a look here http://dr650.zenseeker.net/DR650History.htm
Chill is offline   Reply With Quote
Old 03-08-2013, 12:29 AM   #74438
Chill
Chill's Avatar
Oddometer: 323
Thanks Tezza.
It should be good for many many more kms than that if it's been looked after. There was one at Team Moto recently with about 96,000km. It was a yellow 2001 model. I just searched and what a coincidence they have *another* yellow 2001 model but this one has only 34,000km so I'm sure that it can't be the same one.
http://www.teammoto.com.au/used_bike...tock_id=805724
Old 03-08-2013, 03:31 AM   #74439
Thumper Dan
Oddometer: 328
Its funny how this bike has been rebuilt with only the 34, 000km on it.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 03-08-2013, 04:39 AM   #74440
wee-twin
Oddometer: 199
Originally Posted by Mambo Dave View Post
Old bars / new bars comparison.
Protaper ADV mid I just installed.
wee-twin is offline   Reply With Quote
Old 03-08-2013, 05:20 AM   #74441
Kommando
Kommando's Avatar
Oddometer: 7,389
Quick question:
Grey
Black
White
Yellow
Blue
MV
You can order several different colors from Procycle. I also use fenders for other bikes. My $5 blue Polisport front fender from Motorcycle Superstore is for a YZ450F.
Kommando is offline   Reply With Quote
Old 03-08-2013, 06:00 AM   #74442
barko1
barko1
barko1's Avatar
Oddometer: 3,386
For sale is my FMF Q4 and big header. New retail is $490 + shipping http://www.procycle.us/bikepages/dr650.html#exhaust
How about $275 plus shipping. I have had it on the DR for a few thousand miles, street dirt, water crossings, not new but in very good shape, no dents, can excellent, all fits well and that big head pipe looks so much better than that skinny stocker
FMF bracket and little spacer included.
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 03-08-2013, 07:07 AM   #74443
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,723
Why, I wouldn't be surprised if mine will need a rebuild at that mileage. A lot of wear depends on how hard you ride.
Old 03-08-2013, 07:11 AM   #74444
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 1,017
stand
Kind of a noob when it comes to the DR, and I'm trying to get the bike on some kind of stand to take off the front wheel....any recommendations?
I also use a car jack and tie straps to my garage ceiling to stabilize the bike, what are folks using without a center stand to put the bike up on to change wheels?
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is online now   Reply With Quote
Old 03-08-2013, 07:12 AM   #74445
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,433
Quick question:
Grey
Black
White
Yellow
Blue
MV
does this help?
http://www.colorrite.com/department/suzuki-10023.cfm
I can'tfind the purple frame paint
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket screwed with this post 03-08-2013 at 07:22 AM
Rusty Rocket is offline   Reply With Quote
Times are GMT -7.   It's 10:41 AM.
