Old 03-08-2013, 02:27 PM   #74476
greer
Oddometer: 3,859
We use this transmission jack from Harbor Freight:
http://www.harborfreight.com/450-lb-...ack-39178.html
Raise it just a tad to let the bike sit level or go on up to get one or both wheels off the ground. Use a 1/2" drive ratchet to crank it.
Sarah
Originally Posted by TIGERRIDER007 View Post
Kind of a noob when it comes to the DR, and I'm trying to get the bike on some kind of stand to take off the front wheel....any recommendations?
I also use a car jack and tie straps to my garage ceiling to stabilize the bike, what are folks using without a center stand to put the bike up on to change wheels?
'08 DR650, '13 TU250X
greer is offline   Reply With Quote
Old 03-08-2013, 02:30 PM   #74477
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,739
Originally Posted by TeeVee View Post
Hi folks, been about a year since I was here, since I've been and still am recovering from the broken ankle.
Well, decided to take El Monstro out for basically the first ride in a year, although a fellow inmate rode her back to my house in November and said she ran fine.
So I start her up, it's 90+ degrees so no choke. started up super rough and belching all sorts of shit out of his ass. won't stay running without the throttle cracked even though I got the engine up to operating temp by holding the throttle open. tried raising the idle speed to max and that will barely keep 'em running.
it's also blowing all sorts of smoke which it never did before, even on the ride m buddy did in november.
so, thoughts and advice from the collective genius?
Welcome back T
First, get rid of any fuel that was in the bike when you put it away. Put SeaFoam or StarTron in the new fuel.
Next get a new pilot jet. Don't waste your time trying to save the $4 by attempting to clean the old one.
Lastly service the air cleaner.
Ride
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 03-08-2013, 02:55 PM   #74478
procycle
procycle's Avatar
Oddometer: 2,463
Originally Posted by B.E. Coyote View Post
Do you think aluminum links would hold my fat ass?
The stock links are aluminum.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 03-08-2013, 03:13 PM   #74479
thump!
thump!'s Avatar
Oddometer: 1,648
Lowering links for a big guy.
With my luggage I am around 300#
I'm 5'10 which I know is tall enough to handle the stock height of the bike which in the tall setting is supposed to be 34.8 inches.
After a cogent shock rebuild, a custom seat and a DR350 rear 18" wheel my seat height is a hair over 37" I'd like to get it closer to stock height without losing my farkles.
I see some lowering links from Procycle, Moose etc. Most seem to be aluminum.
Do you think aluminum links would hold my fat ass? Hitting the entire TAT in a few months and I would be more confident on a lower bike, but don't want to get into a jam because a part didn't hold up.
300 lbs is no big deal. I've ridden mine a lot of miles with 270-280 on board and that's with the OEM shock. I'd be more concerned about cracking the swing arm than with the dogbones. That has happened more than once. I haven't searched here but there are threads on DRRiders.com about this potential failure point.
Jim Randall
thump! is online now   Reply With Quote
Old 03-08-2013, 03:30 PM   #74480
! Danimal !
--Dan--
! Danimal !'s Avatar
Oddometer: 135
I had my shock lowered by Cogent to match the factory "low"setting Now the bike sits just .25" lower than the standard version unloaded. It is perfect for me.
So options:
1.) Lowering links--sacrifice some of what you gained by reworking your shock.
2.) Call Cogent and talk to them, they are wonderful as you probably know and that mod would involve little more work than a standard shock service--may be a reasonable option. (forks follow the factory option-no new parts needed)
3.) And this is what I would personally do if I were you (and I did myself because I am short as F***) Order the low-seat from seat concepts! This brings your seat height back down to within a quarter inch of stock. You keep your farkels and get another one in the process .....*the only catch is it may make you want to lower your footpegs depending on you inseam ...me it wasn't an issue.
Hope this helps,
Dan
! Danimal ! is offline   Reply With Quote
Old 03-08-2013, 04:25 PM   #74481
neo1piv014
ADV in training
Oddometer: 627
Originally Posted by greener556 View Post
I've got a Vapor with the LED dash and the light are nearly impossible to see. Is there any solution for this, do I need to add a diode?
Superbrightleds.com is where I got my replacement bulbs for my dash. They sell some regular ones for fairly cheap, or for a little bit more, you can get the high output ones. I've used those on cars and bikes a decent amount.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 03-08-2013, 04:45 PM   #74482
greener556
Oddometer: 115
Cool, these look ideal.
http://www.superbrightleds.com/morei...-12vdc-led/55/
greener556 is offline   Reply With Quote
Old 03-08-2013, 05:19 PM   #74483
BombayG
Oddometer: 6
Did any of you guys weld new supports / gussets for your Dr650? I hear if oyu load up a bit of gear and go on long trips the frame (near the luggage area) is prone to cracking?
BombayG is offline   Reply With Quote
Old 03-08-2013, 05:28 PM   #74484
B.E. Coyote
(Super-Genius)
B.E. Coyote's Avatar
Oddometer: 5,610
Thanks for the responses.
I emailed Rick at Cogent earlier today. Haven't heard back yet, but that is my first option if it is economical.
2nd option will be procycles 1" lowering links.
My seat is staying. Russell Day Long rocks.
I know most will think it an abomonation but I like it, narrow enough up front for standing but plenty wide for long days.
B.E. Coyote is offline   Reply With Quote
Old 03-08-2013, 05:29 PM   #74485
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,711
Originally Posted by Tex76 View Post
Hey guys, just put in new sparks plugs. They are the ngk cr10eix, which I thought were a direct replacement but the head on this spark plug won't mate with the spark plug wires. Are these the wrong plugs?
Make sure they are. If they are too long in the head, they might hit the piston and cause all sorts of damage. If they are right, just change the tops over from your old plugs.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 03-08-2013, 06:40 PM   #74486
dman
Oddometer: 645
Originally Posted by eakins View Post
every Big Block owner I talked to said no way would they would ever use that tire again.
the said the grip was on par with others, but the mileage is a joke, even on lighter bikes.
Recent issue of Dirt Rider magazine with some dual sport articles (including DR650) makes vague comments about a new and/or improved Big Block. There were no details, but maybe Kenda is learning. Kenda mountain bike tires are great.
dman is offline   Reply With Quote
Old 03-08-2013, 06:43 PM   #74487
dman
Oddometer: 645
Originally Posted by saddlsor View Post
have you seen this? maybe it will give you some idea's.
http://advrider.com/forums/showthread.php?t=667646
Thanks saddlsor .... replacing the slider with rollers never occurred to me. Since doing so would reuse the parts I have and replace the parts I'm missing, it could be an economical as well as maybe functionally superior solution.
-dman
Old 03-08-2013, 07:34 PM   #74488
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Not generally true. Hundreds of DR owners have over loaded their DR's and done rough ON and OFF road riding. Most make it through no problem.
A few have cracked ... but mostly in extreme cases like Jammin Jay (see Ride Reports)
The Suzuki is strongest among most of it's 650 Dual Sport competition .. including: KLR, XR650L, XT600/660, BMW F650 and KTM 640.
Welding up some Gussets and supports is not a bad idea .. but you will have to be riding on very knarly tracks with a very heavy load to break the stock sub frame on the DR.
Old 03-08-2013, 07:37 PM   #74489
Adv Grifter
Oddometer: 6,128
True ... and many other Kenda tires have proved to be long wearing ...
look at the K270. Its famous. Not sure what they did wrong on the BIG BLOCK ... but it's for sure a bust for them. No Worries ... they'll be back with something better.
Old 03-08-2013, 08:04 PM   #74490
! Danimal !
--Dan--
Oddometer: 135
Unscrew the top part on the spark plug ( where u can see the threads in your pic) then the boot will fit fine... And yes it really does just simply unscrew
Times are GMT -7.   It's 02:47 PM.
