Old 03-08-2013, 07:37 PM   #74491
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by dman View Post
Recent issue of Dirt Rider magazine with some dual sport articles (including DR650) makes vague comments about a new and/or improved Big Block. There were no details, but maybe Kenda is learning. Kenda mountain bike tires are great.
True ... and many other Kenda tires have proved to be long wearing ...
look at the K270. Its famous. Not sure what they did wrong on the BIG BLOCK ... but it's for sure a bust for them. No Worries ... they'll be back with something better.
Old 03-08-2013, 08:04 PM   #74492
! Danimal !
--Dan--
! Danimal !'s Avatar
Oddometer: 134
Originally Posted by kezzajohnson View Post
Make sure they are. If they are too long in the head, they might hit the piston and cause all sorts of damage. If they are right, just change the tops over from your old plugs.
Unscrew the top part on the spark plug ( where u can see the threads in your pic) then the boot will fit fine... And yes it really does just simply unscrew
! Danimal ! is offline   Reply With Quote
Old 03-08-2013, 10:01 PM   #74493
Carbster
Carbster's Avatar
Oddometer: 77
grab the nipple with a vice grip and unscrew...
Carbster is offline   Reply With Quote
Old 03-08-2013, 10:16 PM   #74494
Kommando
Kommando's Avatar
Oddometer: 7,389
Originally Posted by Adv Grifter View Post
True... and many other Kenda tires have proved to be long wearing ...
Double-true.
I got twice the mileage out of Kenda's K761 compared to the stock TW42.
Kommando is offline   Reply With Quote
Old 03-08-2013, 11:29 PM   #74495
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Thanks saddlsor .... replacing the slider with rollers never occurred to me. Since doing so would reuse the parts I have and replace the parts I'm missing, it could be an economical as well as maybe functionally superior solution.
-dman
Keep an eye on the bearings though. Mine died within 3 months.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 03-08-2013, 11:37 PM   #74496
Tex76
Motersykle Advntyers
Tex76's Avatar
Oddometer: 870
Originally Posted by Rob.G View Post
Okay, since tires have come up once again, I'll go ahead and ask... has anybody here run the Kenda Big Block on the DR650? I know people like it on bigger bikes like the KTM 990 Adventure, but I'm curious if it works well/wears well on the lighter DR?
Rob
I've got a big block front and a tkc rear right now in big bend. Can't say enough about the setup, handles the sand out here really well. Can't speak to wear but it's making me smile a lot :)
"We act as though comfort and luxury are the chief requirements of life, when all that we need to make us happy is something to be enthusiastic about."
2007 BMW R1200 GSA, 2009 DL1000, 2005 DR650
30:Unemployed and Homeless (2 months and 10,000 miles)
The Lost Texan, Wanders East
Tex76 is offline   Reply With Quote
Old 03-09-2013, 01:25 AM   #74497
dopra
dopra's Avatar
Oddometer: 197
My bike it is ready to race :)
dopra bike and ride - thread http://www.advrider.com/forums/showthread.php?t=855584
dopra is offline   Reply With Quote
Old 03-09-2013, 03:38 AM   #74498
TrophyHunter
Oddometer: 2,254
Looks well set up, dopra. I'd fasten down that front brake line so you don't lose it on the first bush. Are those frame protectors a manufactured item or home built? They look great and would be a good addition to my bike if you have a source.
Thx for the pics. Always a benefit of the DR....the ability to make it your own.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 03-09-2013, 03:42 AM   #74499
dopra
dopra's Avatar
Oddometer: 197
Yes, I will install front brake line, frame protector it is home made production, not mine.
Old 03-09-2013, 04:29 AM   #74500
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 1,022
thanks
That looks fairly simple, is the trick just getting good balance on a hard surface?
Where might one find one of these?
Thank you good sir.
Not that complicated. This will even work on the side of the road.
Alu tri pod arm.
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is offline   Reply With Quote
Old 03-09-2013, 04:32 AM   #74501
TIGERRIDER007
Oddometer: 1,022
thanks
Thanks Sarah, that looks great for the garage, is it fairly sturdy?
Originally Posted by greer View Post
We use this transmission jack from Harbor Freight:
http://www.harborfreight.com/450-lb-...ack-39178.html
Raise it just a tad to let the bike sit level or go on up to get one or both wheels off the ground. Use a 1/2" drive ratchet to crank it.
Sarah
Scott
Old 03-09-2013, 04:52 AM   #74502
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,773
Thank you good sir.
I bought a few of these Trail Stands from an inmate in the Vendor forums. They are very compact and at less than $30, a bargain.
They work really well for removing wheels, or lubing the chain, which is what I'm doing in the picture.
Emmbeedee screwed with this post 03-09-2013 at 05:30 AM
Old 03-09-2013, 05:29 AM   #74503
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,552
Hi - my DR is missing the horizontal "block" part of the rear chain guide (vertical plates are OK). Only a complete assembly seems to be available, either OEM plastic parts or Moose or other aluminum aftermarket guides. Cost is about the same .... any recommendations? If you have gone aftermarket and have the stock part and screws that you want to get rid of PM me.
Thanks - dman
I had one where it was removed due to being noisy at speed. When I got my newer dr, it really was. I ran full speed up and down the mountains with no chain guide and it was unnerving to hear the chain hit the swing arm.
Pro cycle and keintech sell an upgraded version.
You looked down here...didn't you.
MeterPig is offline   Reply With Quote
Old 03-09-2013, 06:21 AM   #74504
greener556
Oddometer: 115
I see Keintech also has a "simple stand", works on the front or back. I think it's ~$30 or so.
greener556 is offline   Reply With Quote
Old 03-09-2013, 07:08 AM   #74505
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
Originally Posted by BombayG View Post
Did any of you guys weld new supports / gussets for your Dr650? I hear if oyu load up a bit of gear and go on long trips the frame (near the luggage area) is prone to cracking?
A bit of gear should be no issue. Reports of DR frame cracking are very rare from what I've seen. The 1st gen KLR650's had the bad reputation for this problem, iirc. It you're really, really going to be heavily loaded for long distances on hammeringly rough roads, you might find some inspiration here: http://www.advrider.com/forums/showthread.php?t=712386
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Times are GMT -7.   It's 04:51 PM.
