Old 03-09-2013, 09:29 AM   #74506
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
Originally Posted by Kommando View Post
Double-true.
I got twice the mileage out of Kenda's K761 compared to the stock TW42.
Kenda has gotten some good mileage out of the K761 rear because they designed in a center rear bar (like Heidenau does with 140 & 150 K60) that provide long life right down the middle.
You can see it here on the left tire pic.
http://www.google.com/imgres?imgurl=...9QEwBg&dur=516.
The Big Block was all knobs and shorter ones at that.
To fix their fast wear problems they'll either need better rubber (but I doubt if they have the technology as were talking Chinese cheap here) or just add a center rubber wear strip (the cheap fix).
If you start studying a K761 and a Heidenau K60 you see they are using the same general tread design idea.
The K761 would make a good rear tire for a mullet combo, but I'd still put $ on this one if you need to go the distance on a long tour:
http://www.motorcycle-superstore.com...Rear-Tire.aspx
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 03-09-2013, 09:31 AM   #74507
racer
racer's Avatar
Oddometer: 1,621
I like the DR because its aircooled and no doohickey to fix unlike the KLR. I like the KLR because it is big and roomy with a 6 gallon gas tank. Has anyone ever put a DR motor in a KLR frame? Best of both worlds me thinks and it would lighten the KLR too.
Every bike I ever owned, was the best bike I ever owned when I owned it. Well, except for that one Harley
racer is offline   Reply With Quote
Old 03-09-2013, 09:39 AM   #74508
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
Originally Posted by Rusty Rocket View Post
so, as a compromise tire, which gives the the better offroad grip,
Shinko 244 or Kenda 270?
Looking for something that will last longer than a full knobby, but retain as much grip in dirty situations as possible.
Since I have an 18" wheel avail, I'm even thinking about Pirelli MT43.
i've heard the K270 is a little better rear in that aspect.
the lugs are slightly wider and the rubber compound is slightly softer thus grippier.
there is also the IRC GP-1
Shinko gets all the attention because of the good price and decent tire but IRC (japanese build) is a better tire...at $128 it's a hard sell however and most choose Kenda or Shinko instead.
Alaska
Old 03-09-2013, 09:40 AM   #74509
doug s.
Oddometer: 1,354
yust take a dr650 & put on a bigger tank, better seat, and lowered pegs/different bars. seems a much simpler solution, imo.
doug s.
doug s. is offline   Reply With Quote
Old 03-09-2013, 09:44 AM   #74510
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
No! The DR frame is better IMO & the KLR suspension is bad.
I had a KLR and understand what to talk of.
I got that KLR opened-up comfort & felling with a big tank, windscreen, taller bars (atv mid) and dropped foot pegs (ProCycle).
Alaska
Old 03-09-2013, 09:49 AM   #74511
badweatherbiker
badweatherbiker's Avatar
Oddometer: 708
hi guys, putting everything back together on the dr and needed to know the torque specs on the front and rear sprockets.
1996 Kawasaki KZ1000P (currently being rebuilt)
World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements!
Earn extra income, become a distributor or just purchase:
Advocare products-www.advocare.com/12084065
badweatherbiker is offline   Reply With Quote
Old 03-09-2013, 09:58 AM   #74512
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
Counter sprocket bolts - 4.5 ft lbs (shoulder/raised area goes in towards engine)
Rear Sprocket – 19.5 ftlbs
http://www.advrider.com/forums/showp...6&postcount=20
Alaska
Old 03-09-2013, 10:09 AM   #74513
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,741
No, but I seriously considered putting my DR motor in my 2000 KTM frame before I ended up selling it.( the KTM that is).
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 03-09-2013, 10:56 AM   #74514
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by TIGERRIDER007 View Post
That looks fairly simple, is the trick just getting good balance on a hard surface?
Where might one find one of these?
Thank you good sir.
You can improvise just about anything to do this job. Yes ... balance point.
It's not terribly stable but if you work carefully when removing front wheel you will have no problem.
Put bike IN GEAR and BLOCK rear tire. Find suitable place to position prop stand ... even under header pipe works ... Helps to have help hoiking the DR up into position while assistant inserts prop stand. I can do it solo ... but I'm a world class Bodger. A few folks sell adjustable prob stands. Not sure of links, but they are around. But a piece 2X4 can work just as well.
Old 03-09-2013, 11:37 AM   #74515
badweatherbiker
Oddometer: 708
thanks for the numbers but how the beck do you get the wheel back in after a Cush rubber replacement??
Rear Sprocket 19.5 ftlbs
Old 03-09-2013, 12:07 PM   #74516
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,946
Originally Posted by Adv Grifter View Post
Not generally true. Hundreds of DR owners have over loaded their DR's and done rough ON and OFF road riding. Most make it through no problem.
A few have cracked ... but mostly in extreme cases like Jammin Jay (see Ride Reports)
The Suzuki is strongest among most of it's 650 Dual Sport competition .. including: KLR, XR650L, XT600/660, BMW F650 and KTM 640.
Welding up some Gussets and supports is not a bad idea .. but you will have to be riding on very knarly tracks with a very heavy load to break the stock sub frame on the DR.
Sad to say, I'm one of the few.
Old 03-09-2013, 12:13 PM   #74517
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,946
Originally Posted by dopra View Post
My bike it is ready to race :)
Not with that front brake line hanging out in the wind!
Old 03-09-2013, 01:02 PM   #74518
sandwash
sandwash's Avatar
Oddometer: 1,371
I sprayed some lube (lightly,)or something slippery) on the new cush rubbers,they will slid easier into place.That's what I had to do.
97dr650
sandwash is offline   Reply With Quote
Old 03-09-2013, 02:00 PM   #74519
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 163
WD-40 works great for that exact purpose.
VooDooDaddy is offline   Reply With Quote
Old 03-09-2013, 02:12 PM   #74520
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
when i replaced mine, i also noticed they pushed out more than the compressed old ones. as such, the cush drive sat out farther away from the main hub. i tried over and over to get the cush drive to push in deeper into the hub so I could fit the whole wheel into the swingarm space. no go. i keep thinking i put them in wrong or something like that.
in the end I removed that thin metal spacer on the left side where the shaft goes thru. i then mounted the wheel and snugged it down enough where i could see the cush drive move in deeper into the hub. i let sit like that for a few days then put spacer back on and it all fit then.
no idea how they build the bike from the factory?
Alaska
Times are GMT -7.   It's 06:13 PM.
