Old 03-09-2013, 01:02 PM   #74521
sandwash
sandwash's Avatar
Oddometer: 1,358
I sprayed some lube (lightly,)or something slippery) on the new cush rubbers,they will slid easier into place.That's what I had to do.
97dr650
sandwash is offline   Reply With Quote
Old 03-09-2013, 02:00 PM   #74522
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 163
WD-40 works great for that exact purpose.
VooDooDaddy is offline   Reply With Quote
Old 03-09-2013, 02:12 PM   #74523
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,844
Originally Posted by badweatherbiker View Post
thanks for the numbers but how the beck do you get the wheel back in after a Cush rubber replacement??
when i replaced mine, i also noticed they pushed out more than the compressed old ones. as such, the cush drive sat out farther away from the main hub. i tried over and over to get the cush drive to push in deeper into the hub so I could fit the whole wheel into the swingarm space. no go. i keep thinking i put them in wrong or something like that.
in the end I removed that thin metal spacer on the left side where the shaft goes thru. i then mounted the wheel and snugged it down enough where i could see the cush drive move in deeper into the hub. i let sit like that for a few days then put spacer back on and it all fit then.
no idea how they build the bike from the factory?
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 03-09-2013, 08:32 PM   #74524
squidhunter
suck-squeeze-bang-blow
squidhunter's Avatar
Oddometer: 326
I decided to check my NSU screws today. I have a 2011 that I bought new and have racked up around 6500 miles. I cracked open the case and this is what I found.
I was under the impression the screws were something other than allen heads, considering that's what most people are putting in there??
Anyways, they were tight. While I was in there I put everything back together using loctite. No need to pull the clutch or any of that crap... Even reused the old gasket.
Never underestimate the power of stupid people in large groups.
squidhunter is offline   Reply With Quote
Old 03-10-2013, 01:36 AM   #74525
greer
Oddometer: 3,806
Harbor Freight Transmission Jack
We've had it for years and seems tough as nails. Heaviest bike we've had on it is Doug's KLR, it lifts that thing without a problem and held it several days while he did a 685 kit.
Sarah
Originally Posted by TIGERRIDER007 View Post
Thanks Sarah, that looks great for the garage, is it fairly sturdy?
'08 DR650
greer is offline   Reply With Quote
Old 03-10-2013, 03:16 AM   #74526
dljocky
Oddometer: 863
Thanks for the link, I may try one of the IRC CP-1's. Which size is closest to 120/90-17, the 4.60-17 or the 5.10-17?
Originally Posted by eakins View Post
i've heard the K270 is a little better rear in that aspect.
the lugs are slightly wider and the rubber compound is slightly softer thus grippier.
there is also the IRC GP-1
http://www.motorcycle-superstore.com...Rear-Tire.aspx
Shinko gets all the attention because of the good price and decent tire but IRC (japanese build) is a better tire...at $128 it's a hard sell however and most choose Kenda or Shinko instead.
dljocky is offline   Reply With Quote
Old 03-10-2013, 04:50 AM   #74527
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,557
Originally Posted by squidhunter View Post
I put everything back together using loctite. No need to pull the clutch .
You were able to pull out the allen-head bolts to Loctite them without pulling the clutch?
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 03-10-2013, 06:54 AM   #74528
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 731
That's how I did mine, with the clutch in place although my 07 had phillips head screws that I replaced with allens which by the way were very loose at only 5k miles.
New Mexico, not really new, not really Mexico.
Carl Childers is online now   Reply With Quote
Old 03-10-2013, 07:04 AM   #74529
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,890
Me too. I actually switched, from screws to drilled Allen heads, w/o touching the clutch basket. Then, I safety-wired the Allen head bolts. There's pretty good access to one fastener, the other is harder. I made good use of my offset ratchet and Phillip/Allen head tips.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 03-10-2013, 07:06 AM   #74530
shu
Oddometer: 1,011
Traveling south of the border now. Three 400 mile days of highway riding against a headwind- I've never seen my gas mileage so low: 37 mpg! Now it's back up to my normal near 50 mpg.
Crossing a pass: La Cima de la Muralla south of Monclova in Coahuila state.
Time for breakfast
Turned off the highway and got onto some nice dirt roads on the way to Galeana, Nuevo Leon.
DR's running great. I'm going to put on the 14T sprocket for better dirt riding this morning.
................shu
shu is offline   Reply With Quote
Old 03-10-2013, 07:20 AM   #74531
Carl Childers
Oddometer: 731
GO SHU GO! Man I wish I was doing something like that right now!
Question: What tank pouches are you using? I like'm.
Old 03-10-2013, 08:13 AM   #74532
TRAVELGUY
Old Traveler
Oddometer: 653
I stayed 5 or so days in Galeana in October of 08. Very much enjoyed staying there. People were very friendly and helpful.. The most motorcycle friendly town I have ever traveled to in any country. Hope you have the same experience.
TravelGuy
................shu[/QUOTE]
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 03-10-2013, 08:36 AM   #74533
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Originally Posted by Rusty Rocket View Post
so, as a compromise tire, which gives the the better offroad grip,
Shinko 244 or Kenda 270?
Looking for something that will last longer than a full knobby, but retain as much grip in dirty situations as possible.
Since I have an 18" wheel avail, I'm even thinking about Pirelli MT43.
Dang I want to try the MT43 too, but maybe you can go first and post results.
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 03-10-2013, 10:09 AM   #74534
squidhunter
Oddometer: 326
Yep, it wasn't hard. I used a short Allen wrench small enough to fit under the clutch assembly to break it loose, then a longer one with a ball end to take it the rest of the way out. Assembly is the reverse of disassembly. You can see what you're doing easily enough if you lay the bike on its side. Took me a few maybe 10 minutes to do both screws with time to clean the threads. It might be a bit trickier with a Phillips screw, but it can be done. I've gotten into tighter spots. I don't see any need to pull the clutch for this job.
Old 03-10-2013, 11:18 AM   #74535
CafeRacer
CafeRacer's Avatar
Oddometer: 258
Hi guys - I'm one of the few people who gets to break in a DR motor. Thanks to some factory money and 0% financing, a new 2012 followed me home yesterday.
Can we talk about stock jetting though? The bike runs like crap. It bogs off idle and surges. After riding it to a buddy's house, it had a hard time starting and once running would die with any throttle (it was a little cold out).
I'm currently looking through 5000 pages of DR knowledge, but while I do, anyone have some ideas?
Motorcycles are awesome. Yay motorcycles.
CafeRacer is offline   Reply With Quote
Times are GMT -7.   It's 11:44 PM.
