Old 03-10-2013, 02:11 PM   #74551
motolab
motolab's Avatar
Oddometer: 2,708
Originally Posted by greener556 View Post
Bike surges at lower RPM's is the main issue.
Put some tape on the throttle housing and the edge of the grip. Mark zero throttle with a sharpie. This is best done with the engine idling, so you can tell when the slack in the cable has just been taken up. Turn off the engine and mark wide open. Now take a tape measure (metric works best in my opinion) and measure the length of the arc. Put a mark at the mid point. Duplicate this procedure to mark the mid-point between here and zero throttle opening to get 1/4 open. Repeat for 1/8 and 1/16 openings. With the help of the marks, determine precisely during what throttle opening(s) it misbehaves. Don't have an accident trying to look at the marks while riding. If you do, I'm not responsible! Report back with results. This will help us determine what circuit(s) are responsible.
Bike is really cold blooded, not sure if that can be fixed.
That should be curable with jetting/mixture adjustments.
Snorkel has been removed, GSXR muffler mod in the works.
I would start with the installation of a non-USA adjustable jet needle.
Leaning towards this guys solution: http://www.advrider.com/forums/showp...5&postcount=71
As I said, shimming the needle clip richens the mixture by lowering the slide rather than by raising the needle (except when the slide is against either stop), as the shim increases the preload on the slide spring. Unless the intention is actually to lower the slide for a given intersection of throttle position and rpm (except when against the stops), I would recommend installing an adjustable needle instead.
An extended fuel screw is only required when the bike will be ridden at radically varying altitudes. If not, there should be no need to fiddle with the fuel screw constantly, negating the need.
Regards,
Derek
motolab is offline   Reply With Quote
Old 03-10-2013, 04:54 PM   #74552
shu
Oddometer: 1,026
Originally Posted by Carl Childers View Post
GO SHU GO! Man I wish I was doing something like that right now!
Question: What tank pouches are you using? I like'm.
Those are the easily modified, cheap procycle bags:
http://www.procycle.us/bikepages/dr650.html (all the way at the bottom)
modifications:
http://www.advrider.com/forums/showt...=636483&page=3
They're pretty stout bags.
................shu
shu is offline   Reply With Quote
Old 03-10-2013, 06:19 PM   #74553
ER70S-2
ER70S-2's Avatar
Oddometer: 6,671
Cool2
Originally Posted by shu View Post
Traveling south of the border now. Time for breakfast
DR's running great. I'm going to put on the 14T sprocket for better dirt riding this morning.
................shu
Don't be afraid to post an occassional photo (or 6).
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 03-10-2013, 06:44 PM   #74554
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,191
modifications:
I have 'em and love 'em. I want to do this to them:
http://lifehacker.com/5972434/waterp...s-bag-with-wax
Since their one downside is they aren't waterproof.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 03-10-2013, 06:51 PM   #74555
Rumlover
Ed
Oddometer: 707
Originally Posted by motolab View Post
Shimming the needle clip richens the mixture by lowering the slide rather than by raising the needle (except when the slide is against either stop), as the shim increases the preload on the slide spring. Unless the intention is actually to lower the slide for a given intersection of throttle position and rpm (except when against the stops), I would recommend installing an adjustable needle instead.
I would think the weight of the shim could also have an affect on slide movement (argued once before I believe). Both points seem like hair splitting to the nth degree.
I think it safe to say that the shim (usually .02 to .04) also moves the needle higher in the needle jet for any given slide height.
Whatever the reason a SHIM under the stock needle usually corrects the problem 99% of the time.
Also I think your suggestion that riders mark off the throttle in 1/16 increments , and note precisely what is going on, is a little too precise for the street -- your going to get somebody injured or killed.
Rumlover screwed with this post 03-10-2013 at 06:58 PM
Rumlover is offline   Reply With Quote
Old 03-10-2013, 08:03 PM   #74556
TRAVELGUY
Old Traveler
Oddometer: 663
Strange advice coming from someone named "Rumlover"? I would worry more about people drinking and riding or driving.
TravelGuy
Also I think your suggestion that riders mark off the throttle in 1/16 increments , and note precisely what is going on, is a little too precise for the street -- your going to get somebody injured or killed.[/QUOTE]
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is online now   Reply With Quote
Old 03-10-2013, 08:14 PM   #74557
Rumlover
Ed
Oddometer: 707
[QUOTE=TRAVELGUY;20915586]Strange advice coming from someone named "Rumlover"? I would worry more about people drinking and riding or driving.
QUOTE]
Not sure if that is a joke or a jab. But for the record I worry about drunk drivers also.
Old 03-10-2013, 08:21 PM   #74558
motolab
motolab's Avatar
Oddometer: 2,708
I don't remember arguing that the weight of the shim could have an effect on slide height, although it is a valid point.
Both points seem like hair splitting to enth degree.
I agree when it comes to the weight of the shim, but disagree when it comes to preload on the spring. I have done dyno testing that demonstrates that clipping two coils off a BST40 slide spring on an LC4 richens the mixture in the bottom half of the rpm range by an amount I would call significant. Adding preload should have the opposite effect. In fact, some FP jet kits come with heavier slide springs for that very reason, that is to help overcome inordinately rich mixtures that were caused by opening up airboxes and installing the appropriate main jet (that is one that that provides the correct mixture at high rpm). Dyno testing I have performed demonstrates that it works. On the other hand, others here claim that shimming the needle cured a stumble. Make no mistake, if the stumble was cured by shimming the needle, then it was cured by lowering the slide instead of by raising the needle, unless the issue was at a point where the slide is against the stop. If the issue was at a point where the slide is against the stop, then that means the throttle is most of the way closed (i.e. 1/8 opening or under), which then in turn means that in reality the wrong circuit was used to fix the problem (it should have been fixed with pilot jet size instead).
I think it safe to say that the shim (usually .002 to .004) also moves the needle higher in the needle jet for any given slide height.
Well .002" to .004" is awfully small, to a point of not really producing a discernible result. However, regardless of what thickness of shim is chosen, you are correct that a shim will move the needle higher in the emulsion tube for a given slide height, except you are neglecting that, for a given intersection of throttle position and rpm, the slide height will at the same time be lower than it was.
You have to define "corrects". If by that you mean that the symptom is gone, then perhaps. To me, just because the symptom is gone does not mean the problem has been corrected. To me corrected means that the mixture has been brought to where the CO is between 3 and 5 percent, or to where best power is being achieved for a given intersection of throttle position and rpm, and doing so was not to the detriment of some other intersection of throttle position and rpm (or at least the best compromise). Remember that the symptoms can be gone, but that the mixture can still be poor enough to cause hot running, detonation & poor mileage on the lean side, and carbon deposits, oil being washed off the cylinder wall & poor mileage on the rich side.
My suggestion always includes the admonishment, "Don't have an accident trying to look at the marks while riding. If you do, I'm not responsible!" In other words, if you feel you can't do this safely, don't do it. Clearly, it's up to the individual to decide.
I'd like to ask you, what is your opinion of people who make a habit of attempting to hold others responsible for the choices they make?
Regards,
Derek
Old 03-10-2013, 08:46 PM   #74559
Rumlover
Ed
Oddometer: 707
I don't remember arguing that the weight of the shim could have an effect on slide height, although it is a valid point.I agree when it comes to the weight of the shim, but disagree when it comes to preload on the spring. I have done dyno testing that demonstrates that clipping two coils off a BST40 slide spring on an LC4 richens the mixture in the bottom half of the rpm range by an amount I would call significant. Adding preload should have the opposite effect. In fact, some FP jet kits come with heavier slide springs for that very reason, that is to help overcome inordinately rich mixtures that were caused by opening up airboxes and installing the appropriate main jet (that is one that that provides the correct mixture at high rpm). Dyno testing I have performed demonstrates that it works. On the other hand, others here claim that shimming the needle cured a stumble. Make no mistake, if the stumble was cured by shimming the needle, then it was cured by lowering the slide instead of by raising the needle, unless the issue was at a point where the slide is against the stop. If the issue was at a point where the slide is against the stop, then that means the throttle is most of the way closed (i.e. 1/8 opening or under), which then in turn means that in reality the wrong circuit was used to fix the problem (it should have been fixed with pilot jet size instead).Well .002" to .004" is awfully small, to a point of not really producing a discernible result. However, regardless of what thickness of shim is chosen, you are correct that a shim will move the needle higher in the emulsion tube for a given slide height, except you are neglecting that, for a given intersection of throttle position and rpm, the slide height will at the same time be lower than it was.You have to define "corrects". If by that you mean that the symptom is gone, then perhaps. To me, just because the symptom is gone does not mean the problem has been corrected. To me corrected means that the mixture has been brought to where the CO is between 3 and 5 percent, or to where best power is being achieved for a given intersection of throttle position and rpm, and doing so was not to the detriment of some other intersection of throttle position and rpm (or at least the best compromise). Remember that the symptoms can be gone, but that the mixture can still be poor enough to cause hot running, detonation & poor mileage on the lean side, and carbon deposits, oil being washed off the cylinder wall & poor mileage on the rich side.My suggestion always includes the admonishment, "Don't have an accident trying to look at the marks while riding. If you do, I'm not responsible!" In other words, if you feel you can't do this safely, don't do it. Clearly, it's up to the individual to decide.
Regards,
Derek
Yes .002 is awfully small. it was an error and I corrected it to .02 a few minutes after I wrote it. Sorry for the confusion.
I still am not convinced on that small bit of preload accounting for the entire difference. Maybe I miss read but your conclusion was based upon cutting springs, not actually preloading it. But regardless why do you discount the needle being higher in the needle jet for any given slide height. Surely that accounts for some of the increase in richness even if the slide is slightly lower.
To your question:
I believe people are responsible for their own actions, and have a responsibility to exercise a little common sense and judgement when taking the advice of others. That is why I would never go riding down the street and trying to read 1/16 incremental marks on my throttle while trying various throttle positions. Maybe I am not as sharp as others, but sooner or later my eyes are going to be in the wrong place and I might miss that truck pulling in front of me.
So yea you are off the hook and not responsible for others, but it still sounds a little ridiculous to me.
Old 03-10-2013, 08:50 PM   #74560
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,996
Derek,
You post alot of variables that people should check when having problems (thank you!), but often there are not answers/solutions to what people should do to fix the issues. Granted people are not responding so well with throttle position feedback for solutions and that's not your fault.
When know the DR, in stock form, is lean. Some surge.
When modified some stumble off idle as a result. (still dealing with my issue with that.)
You say you've done alot of dyno testing with different carb settings.
How about a to do list (a baseline of mods to do) for those with stock carbs who want better performance.
Let's assume a stock muffler and everything else. Where to start and see how the bike works?
-adjust pilot jet to where?
-what jet sizes?
-what if anything to do to the carb?
-where to set the needle?
-check and set the float to what height?
-drill another hole in the slide or not?
-mods to the airbox?
get my idea?
Then maybe a aftermarket pipe list and a list to check when you have off idle stumble.
You seem to have the same conversation over and over with people checking in, but it does not seem they've responded that it's been resolved.
Question? I'm confused.
You recommend the non-US adjustable needle to tune and richen the bike. It's the same shape as the US needle. Yes? So then you can raise it to richen (or lower it to lean) the bike.
If it's the same shape then why would adding a washer shim under the US needle not have the same effect as lower the clip on a non-US needle. Both methods raise the needle up higher and thus come out of the emulsion tube faster thus releasing more gas. The position of the slide is the same either method. Am I missing something here???
Thanks, Bill
Regards,
Derek
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 03-10-2013 at 08:55 PM
Old 03-10-2013, 09:03 PM   #74561
BadDogMax
Oddometer: 161
Bike surges at lower RPM's is the main issue. Bike is really cold blooded, not sure if that can be fixed. Snorkel has been removed, GSXR muffler mod in the works.
Had the same symptoms as you and the suggestions in that link worked for me.
2007 Suzuki DR650
BadDogMax is offline   Reply With Quote
Old 03-10-2013, 09:07 PM   #74562
motolab
motolab's Avatar
Oddometer: 2,708
Once again, you are neglecting that when the spring has more preload in it, the slide height will be lower than it was before for a given intersection of throttle position and rpm, while the needle will be in an unchanged position (unless the slide is against either stop).
Why does it still sound ridiculous? Does everything you wouldn't do sound ridiculous? Some people won't ride motorcycles at all. What would your response be if they told you your being a proponent of motorcycle riding "sounds a little ridiculous" to them?
Regards,
Derek
Old 03-10-2013, 09:22 PM   #74563
Rumlover
Ed
Oddometer: 707
Once again, you are neglecting that when the spring has more preload in it, the slide height will be lower than it was before for a given intersection of throttle position and rpm, while the needle will be in an unchanged position (unless the slide is against either stop).Why does it still sound ridiculous? Does everything you wouldn't do sound ridiculous? Some people won't ride motorcycles at all. What would your response be if they told you your being a proponent of motorcycle riding "sounds a little ridiculous" to them?
Regards,
Derek
I am not neglecting that the slide is lower with more spring preload. I pretty much conceded that in both posts. Why do you fail to see that at its now "lower" position the needle is higher in the needle jet (with a shim) for that position, and that also has an impact.
It still sounds ridiculous to me because I think it is bad advice. It's my opinion, get over it.
And no that doesn't apply to everything I wouldn't do, just the stuff "I think" is ridiculous.
Old 03-10-2013, 10:02 PM   #74564
gofast1320
gofast1320's Avatar
Oddometer: 741
40F0 muffler
Got my two brothers mid-pipe back from Jesse to mount my 40F0 muffler on my bike. Got it on and really like the change in sound. Seems to fire up easier and the low end off idle pull is better.
Previously I'd noticed a little stumble and got to thinking about all the different comments I've seen on here regarding removing the snorkel, adjusting clips, bigger jets etc. and the jist of it seems to be that introducing more air intentionally or a leak has more affect on stock DRs because of a chronic lean from the factory condition.
I'd had a jacked up, gummed or clogged needle seat that let fuel overflow into the airbox. Just running a couple of tanks of fuel with Stabil in it cleared up the leaking seat problem. I'd forgotten about removing that little nipple thing over the 1/2" outlet on the front at the bottom of the airbox to let all the gas run out. . I sealed that and the popping on deceleration has stopped.
Back to the mid-pipe business- I'd sent mine to Jesse to get the right flange welded on along with his bracket and other small parts to mount my muffler. They've got their act together. I got all of that with 2 photos showing what goes where and the install was a breeze. His stuff fits perfectly.
gofast1320 screwed with this post 03-11-2013 at 06:17 AM Reason: sp
gofast1320 is online now   Reply With Quote
Old 03-10-2013, 10:25 PM   #74565
motolab
motolab's Avatar
Oddometer: 2,708
I've posted how to tell at which throttle position the problem is occurring at. I've posted which circuits are responsible for what throttle positions. I and others have also posted various methods to determine whether the problem is rich or lean. I have explained that it's fairly easy to "tell where you are" once you bump up against the most minor of lean misbehavior (with the caveat that doing so can be dangerous depending on compression, exhaust flow, timing and quality of fuel). People have been given all of the information to tune themselves within the confines of what is possible without a dyno. If they can't figure it out, they are not following the instructions for whatever reason (fear of damaging the engine is a good reason), or they are up against the limitations of what can be done without gas analysis or HP readings.
It sounds to me like you want the answer without doing the work. That's unfortunately not how it works.
You can start where you are (perhaps temporarily using better fuel to prevent damage). The engine will tell you what it wants, but not without your listening to what it is trying to tell you.
-what jet sizes?
get my idea?
Yes. I get the idea that, once again, you want the answer without doing the work. I have made one specific recommendation, where the trend is strong enough to in my mind guarantee the validity, and that is to stay away from the DJ needle. There is no instance I can think of where such a shape will be useful for a DR, and especially not with airbox mods, where the change in shape from stock is in a direction exactly opposite of what would be beneficial.
Perhaps you would like to provide me with a bike, a selection of pipes, and perhaps pay my bills while I tune all of the combinations of parts we can conceive of, realizing of course that all we would end up with are trends, as bikes with the same combinations of parts may still run differently and want different jetting. I have given a list of things to check when there is an off idle stumble several times. I've also requested that people clearly define what they mean by "off idle". In most cases, no clarification was given. I can give no further advice without knowing precisely what throttle position is being referred to, as I can't determine what circuit is responsible without having that information.
I'm pretty sure they have, but if they hadn't what would that prove? Are you implying that the information I have given is incorrect?
Correct.
Yes, raising the needle richens the mixture, and lowering it leans the mixture.
Yes, you are missing that for a given intersection of throttle position and rpm, shimming the needle clip lowers the slide rather than raising the needle (unless the slide is against either stop).
Regards,
Derek
Times are GMT -7.   It's 06:39 AM.
