Old 03-10-2013, 11:08 PM   #74566
Rumlover
Ed
Oddometer: 707
Originally Posted by motolab View Post
There is only one condition under which what you are saying could be true, and that's if, for a given intersection of throttle position and rpm, it's the slide rather than the butterfly that's causing the most restriction.That it's ridiculous because it's bad is not really an argument. That said, it is possible that there may be some misunderstanding about how this can be done in a relatively safe manner. I do not advocate riding around and looking at the marks at whatever random time a symptom crops up. Rather, I suggest opening the throttle to each of the marks in a premeditated manner and letting the engine accelerate through the range to whatever rpm it will (based on how well/poorly it is tuned - top gear usually gives the best data and acceleration won't be as brisk). It should certainly possible to find a stretch of road with little traffic and no driveways/side streets to do this on, especially since the largest opening that requires the use of a mark is 1/4. 1/16 and 1/8 openings are so small that they can be tested in a medium sized empty parking lot.
How do you respond to people who think that things you like to do/advocate are ridiculous?
Regards,
Derek
You either totally miss my point about needle position , find it irrelevant, or just enjoy confusing the issue. I really don't care anymore!
I see no need to continue to justify my opinions to you about what I think is ridiculous or why. I have already commented more then enough.
Good Night
Rumlover is offline   Reply With Quote
Old 03-10-2013, 11:45 PM   #74567
motolab
motolab's Avatar
Oddometer: 2,777
None of the above.
Well, that's unfortunate. I much prefer it when people reach an understanding together.
As you wish...
Regards,
Derek
motolab is offline   Reply With Quote
Old 03-11-2013, 05:10 AM   #74568
doug s.
Oddometer: 1,348
if i correctly understand what derek is saying, it's that, if you shim a stock needle, you change the spring tension, which lowers the slide. if you get an adjustable needle and raise it w/o shimming, the needle is raised, but the spring tension remains the same; therefore you have no lowering of the slide.
of course, i could also be completely off the mark here!
doug s.
doug s. is offline   Reply With Quote
Old 03-11-2013, 05:30 AM   #74569
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,799
doug s.
You may be on to what he's saying.
But then it would hit the wall of what the suspension guys say about springs - that their rate and tension don't change by pre-load, which is what a shim would do, unless they were a progressive-rate spring and it took up some lower-rate squish of the spring.
Not that I care that much one way or the other - my DR650 with ProCycle's needle and kit seems to run just fine. When push comes to shove, and when the needle wears the slide, I'll buy one of the better carb options out there.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 03-11-2013, 06:34 AM   #74570
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,550
Any of you people have a Wee Strom along with the DR650 willing to send me a PM about your observations as to the dirt ability of the Wee and the road abilty of the DR and how much of an overlap there is. I have some friends with WeeStroms at are tyring to talk me into adding one. I'd love to have more bikes, but is there enough difference to be worth it.
I thank you in advance for you thoughts. No need to clog up this thread with this talk, unless you feel it adds to the value of this thread.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 03-11-2013, 06:45 AM   #74571
Rumlover
Ed
Oddometer: 707
doug s.
I will try to explain my position one last time (I really regret bringing it up at this point)
Assuming the carb is running on the needle circuit:
I understand that preloading the spring will cause the slide to be slightly lower then previous.
However the shimmed needle will still be raised in the slide. So unles the loss of slide height is greater then the amount the needle is raised by the shim, the needle will still be higher in the needle jet and flow more fuel.
Also the shimmed needle will always be higher in the needle jet for any given slide height. Motolabs explanation doesn't seem to think that is significant and makes it sound (to me) like the needle and slide are working independently. I know that wasn't his intent, but that's how it came across.
Anyway I was simply trying to point out that I don't think the loss of slide height is greater then the gain at the shimmed needle. And even if it is the flow through the needle jet will still be higher for the new slide height when compared to the same slide height for an unshimmed needle.
Hope that is clear as mud
Just one mans opinion
Rumlover screwed with this post 03-11-2013 at 07:22 AM
Old 03-11-2013, 06:46 AM   #74572
ShadyRascal
Master of None
ShadyRascal's Avatar
Oddometer: 6,766
I have both and love the smoothness of the Wee on the road. The Wee is fine on gravel roads but any kind of mountain fire road with tighter corners the Wee gets to be a pig real quick.
Overall I'd say the DR is a better street bike than the Wee is a dirt bike. It's just more of a comfort thing for me with the Wee, I travel longer distances pretty regularly. But whenever it gets dirty, I want to be on the DR, and some roads or trails I'll just avoid with the Wee. All depends on your terrain and length of trip I guess.
Originally Posted by Javarilla
Evolution, or, natural selection, has nothing to do with better.
It merely weeds out what is no longer suitable for the given context.
Originally Posted by Dragoon
I would rather be on my motorcycle thinking about God than in church thinking about my motorcycle.
ShadyRascal is offline   Reply With Quote
Old 03-11-2013, 06:49 AM   #74573
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,849
I will try to explain my position one last ime (I really regret bringing it up at this point)
However the needle will still be raised in the slide. So unles the loss of slide height is greater then the amount the needle is raised by the shim, the needle will still be higher in the needle jet and flow more fuel.
Anyway I was simply trying to point out that I don't think the loss of slide height is greater then the gain at the needle.
What kind of oil are you running in it?
Old 03-11-2013, 07:02 AM   #74574
Rusty Rocket
Life behind "Bars"
Oddometer: 9,550
2009 DR650
Old 03-11-2013, 07:05 AM   #74575
Kommando
Kommando's Avatar
Oddometer: 7,389
Originally Posted by Rusty Rocket View Post
pew! pew! pew!
Kommando is offline   Reply With Quote
Old 03-11-2013, 07:10 AM   #74576
Rumlover
Ed
Oddometer: 707
The slippery stuff works best!
Old 03-11-2013, 08:16 AM   #74577
dman
Oddometer: 624
I have both also, and concur with this. It also depends on your skill. The weight, limited suspension travel, and tires (though that can be changed) intimidate me from doing anything too rough on my Wee. Based on what I've seen on various Wee threads, others can ride these bikes almost anywhere.
-dman
dman is offline   Reply With Quote
Old 03-11-2013, 08:26 AM   #74578
TRAVELGUY
Old Traveler
Oddometer: 699
+1 There is very little overlap of performance. I like both bikes very much. Their just different tools for different needs. If I could only own one bike it would probably be the Wee Strom but I find myself riding my DR the most.
TravelGuy
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 03-11-2013, 08:40 AM   #74579
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
Rum oil.
Old 03-11-2013, 10:03 AM   #74580
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I will try to explain my position one last time (I really regret bringing it up at this point.
Both Rumlover and Derek are two of the more valuable contributors to our little DR thread. I see both points of view ... but must admit it gets a bit confusing after a while. I don't have enough experience to even have a clue who is correct ... I've never worked in the Factories in Japan to observe their running cutaway models they use for R&D ... (they have 'em guys!)
I'd hate to lose either guy over a minor disagreement.
I have a question for Derek:
Do you own a DR650? Ever ridden one? Worked on one?
If not I'd love to see you get hold of a DR and spend some time on it, riding and tuning.
It's a VERY different bike to an KTM 640 ... and I don't think we can assume that Carb settings that work for a 640 will work on the DR650.
Times are GMT -7.   It's 02:09 AM.
