Old 03-12-2013, 12:50 PM   #74641
MADurstewitz
MADMark
Oddometer: 159
Originally Posted by Rusty Rocket View Post
Mine smokes on start some times. I wonder if it is gas that has gotten "old". After it warms up no more for the rest of the day.
I have 20K miles on mine and it could be valves seals, but the PO was a Suzuki mechanic and he did a piston and rings and might have done some work on the head, so I just deal with it. It isn't every time and it really doesn't bother me because I had 2 strokes for the first 40 years of riding.
Try back-blowing your spark arrestor. If it's not done for a long time, carbon deposits build up and come out like light blue oil smoke, but with a funny (not oil) odor.
MAD
(yes, those are my real initials)
MADurstewitz is offline   Reply With Quote
Old 03-12-2013, 12:54 PM   #74642
sandwash
sandwash's Avatar
Oddometer: 1,357
There is a bolt/plug on the stock muffler,undo it for a few.
97dr650
sandwash is offline   Reply With Quote
Old 03-12-2013, 01:12 PM   #74643
Escaped
Escaped's Avatar
Oddometer: 488
Carb Talk
It's 72 degrees and Sunny here is Sacramento right now. I should be riding not stuck here at work, eating lunch and reading about jetting and pre-detonation
I have 41,000 + plus miles on my 2006 DR and with most of those miles with an missing side cover. The jetting is slightly rich by my reckoning (plug color) and the bike runs great 45 to 50 mpg. Closer to 45 in winter, 50 in summer - darn alcohol contaminated fuel.
I do run premium fuel, because after 2 or so tanks of regular fuel my bike seems to "cut out" like its running out of gas, when cruising at 50 MPH of so. Does not do that under full throttle or at lower speeds
Problem goes away as soon as I switch back to premium - I think I has to do with the alcohol in the the fuel. Maybe lean at 1/2 throttle?
2006 DR650 54,407 miles
DR650 - Eyes open all of the time
Escaped is offline   Reply With Quote
Old 03-12-2013, 01:13 PM   #74644
Novgorod
Oddometer: 11
Hello DR650'ers. I don't have one yet, but I am thinking about buying a used one I found for sale. I was wondering if someone could give me an idea on how much power they have, with a TM40 Mikuni and GSXR exhaust? I don't mean numbers, but by the seatofyourpants dyno. Also how well do they run at very low speeds through sticky stuff?
Novgorod is offline   Reply With Quote
Old 03-12-2013, 01:15 PM   #74645
motolab
motolab's Avatar
Oddometer: 2,619
Originally Posted by Adv Grifter View Post
Those links don't reveal specifics regards mods to individual bikes. Did they all have Open Air Boxes? And what jetting did they have? State of tune/condition of the bikes? In most cases pinging results from the owner either lugging the bike ... or doing a poor job of tuning/jetting/mods.
Previously, you said, "Hundreds of DR riders have opened the air box with no hint of detonation ... or any other problems.". Now you are asking about state of tune. They either had opened airboxes or not. If so, then the pinging could have been brought on by the opened airbox. If not, then the situation would be worse once the airbox was opened up.
Also, in some cases the owners are literally "hearing things" ... and don't really know what Pinging, Detonation sounds like. A flopping chain can fool a lot of riders.
I'm not sure how you can argue that hundreds of DR riders are astute enough to know for a fact that their engine is not suffering from detonation, while simultaneously being capable of hearing things and not really knowing what pinging and detonation sound like.
But are you saying stock compression is too high to handle the open air box mod?
I said no such thing. I said you want to be sure that it is not.
And timing may be too advanced to handle it?
Again, I'm saying that you want to be sure that it is not.
If that was the case then, IMHO, we'd have many more reports of severe detonation from guys who'd opened up the Air Box.
We have at least seven reports in the links. It can be quite harmful well before it is audible, and it is possible for it to happen without being aware that it has.
Do you believe my bike would have made it to 50,000 miles? ... mostly all on regular gas ... if severe detonation, or even MINOR detonation existed I would think my piston would be toast ... and bits of Alu would have shown up on my plugs before that.
One of the first things that happens is that the severe pressure rises on top of the piston cause the oil film between the wrist pin and its bores to fail, leading to galling. Another is that the pressure waves punch through the vapor barrier, leaving the oil film on the cylinder wall unprotected from normal combustion (much less uncontrolled combustion), causing it to burn off. The severe pressure rises present during detonation simultaneously push the rings into the cylinder wall much harder than normally, which cause cylinder wall and ring scuffing. Your bike could have made it 50,000 miles with detonation. The piston does not have to be destroyed as a result, nor do bits of aluminum have to appear on the spark plug.
I have no Dyno Charts. But maybe you can share with us any Dyno Charts you've done ... in your shop .... on customer bikes?
See http://www.moto-lab.com/gallery/search. Select "graphs" from the category drop down. Select a make model and year, and/or key words.
Regards,
Derek
motolab is online now   Reply With Quote
Old 03-12-2013, 01:22 PM   #74646
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,260
mine got knocked off. probably by a rock coming off the Kenda TrakMasterII. It is an epoxy patch now.
that's probably what it is. I hadn't even thought of that. That's why I hang around here.
maybe I'll put the SuperTrapp back on and see if it still happens.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket screwed with this post 03-12-2013 at 01:27 PM
Rusty Rocket is offline   Reply With Quote
Old 03-12-2013, 01:37 PM   #74647
rand0mlychrisUK
rand0mlychrisUK's Avatar
Oddometer: 28
Those RSE's are pretty cool and maybe worth having.
An RSE is exactly what I am looking at, a '93 RSEU to be more exact. I'm on a budget and it looks perfect for my needs (mostly asphalt, a tiny little offroad). Also, since I am mostly going asphalt, then the 50lbs might not be so bad for me, and the fairing might come in useful. Also, I understand the pre96 models have a little more torque, which may be useful for around town.
What about the mechanical differences? People talk about the chain counterbalancing system being terrible, I have no idea or experience.
Thanks for the answer, hope to get a little more insight from you guys.
Thanks, Chris
rand0mlychrisUK is offline   Reply With Quote
Old 03-12-2013, 01:47 PM   #74648
Rusty Rocket
Life behind "Bars"
Oddometer: 9,260
Thanks, Chris
I don't know if you can get a KLR 650 where you are, but here in the U.S., it would be a better choice. They were the same for 20 years leading up to 2008 when the changed the body. It's electric start and I believe the Suzuki is kick start. It looks a lot like a KLR at first glance too. Accessories are much more available for the KAW. Maybe in Europe the RSE was more widely available.
Ask here:
http://www.advrider.com/forums/showthread.php?t=61568
These guys will know a lot more about the engine at least.
The 1996 and newer DR650 is easier to get parts and accessories for also. Unless you are determined to have that bike, you will likely be better off with a new generation DR or a KLR.
2009 DR650
Old 03-12-2013, 02:22 PM   #74649
procycle
procycle's Avatar
Oddometer: 2,306
In the Suzuki category - DRZ400, 1500 Intruder, 1200 Bandit, GXSR750, GSX1100, C50 Boulevard.
No DR650.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 03-12-2013, 03:11 PM   #74650
motolab
motolab's Avatar
Oddometer: 2,619
Originally Posted by procycle View Post
No DR650.
I've already said many times that I have not tuned one.
Regards,
Derek
Old 03-12-2013, 03:13 PM   #74651
spanker
bada bing, capiche?
spanker's Avatar
Oddometer: 825
yo Russ,
Thing is, my Penton has been hiding in the basement and only comes out every 5 years or so for a vintage event. The TS185 needs to be cleaned up an made running (been gonna do that job for about 5 years now)
I figure if I sell them to raise some cash, I could add a bike that i will actually use.
Russ, if you ever sell that Penton w/o giving me first cut, I will come up there and beat you with a 2x4!
2010 BMW R1200RT, a sweet scooter for my daily 100 mile commute.
'08 Husqvarna TE-610, sold
waiting till I retire to get a new adv bike. meanwhile........
spanker is offline   Reply With Quote
Old 03-12-2013, 03:28 PM   #74652
shu
Oddometer: 1,010
Originally Posted by ER70S-2 View Post
When I go from a 15t to a 16t, it raises my comfortable cruising about 8 mph; from 67-8 to 75.
I'm guessing 14t to 15t will be about the same, from whatever speed you're willing to run the 14t.
I like to run mine to turn over just a little faster than you do, ER70S-2. I find cruising on the freeway at about 75 (GPS speed, almost 80 on the speedo) is comfortable with the 15T stock sprocket.
With the 14T I prefer to go 67-68 GPS (73 speedo).
I just did several back to back highway days on my way south at 70-75 all day. It always surprises me how smoothly and stably the DR650 does on the big roads doing moderately high mileages. Gotta love this bike.
.............shu
shu is offline   Reply With Quote
Old 03-12-2013, 03:31 PM   #74653
TeeVee
His mudda was a mudda!
TeeVee's Avatar
Oddometer: 775
not sure there is one on my gxr can. or are you referring to some other spark arrestor?
bike ran fine in november, and started with no trouble at all in january, although i did not ride it in january.
also, it may be possible that the oil is contaminated with fuel. read on thumpertalk that if the fuel valve leaks while in the on position, fuel can contaminate the oil. well, when i pulled the tank off the other day, i noticed that the fuel valve was leaking. SHYTE! leaving things as is always leads to problems, eh? guess, i'll be changing the oil and filter too.
______________
'08 DR650
'07 DL1000
TeeVee is offline   Reply With Quote
Old 03-12-2013, 03:39 PM   #74654
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,811
another piece of the puzzle to make sure this is done right.
-adjust the chain properly and make sure the left and the right side adjuster cams are on the same notches.
-then mark the left drive side with a marker at that notch so you can get back in a flash with tire chains
-then check the alignment of the chain & sprockets
http://www.motorcycle-superstore.com/14/71/995/4876/ITEM/Motion-Pro-Chain-Alignment-Tool.aspx?SiteID=Google_PLA995&WT.mc_ID=10012&esvt=0-GOUSC&esvadt=9-0-3886819-1&esvaid=30548&kw={keyword}&gclid=COvPzOWe-LUCFaUWMgodSFQAoA
this tools clamps to the rear sprocket and you look down the rod to the front of the bike/front sprocket. it must be parallel with the chain
-if not the sprockets are not aligned and will wear out the chain faster.
adjust the right ride adjuster to align properly. the left stays the same as that's for proper slack. the right side aligns. mine was off 2 slots.
Obard:
Use a ratchet strap across the seat to get the 3 points aligned like BD's diagram. Pad the seat so the strap doesn't cut the seat cover. The bike will roll with the suspension pulled down (strapped), so check the tightness in several places.
When you're doing this, the chain slack will NOT be 1.2"-1.8". You just want free movement (no binding). And too loose is better than too tight!!
Be careful, as the kickstand might be too long and tip the bike over on the right side.
Like this (my shock is disconnected in this pic, don't pull it down this far).
Better pic, pulled down too far:
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 03-12-2013, 03:51 PM   #74655
Rusty Rocket
Life behind "Bars"
Oddometer: 9,260
I'll wait till you move to FL so it'll cost you more to make the trip to beat me.
2009 DR650
Times are GMT -7.   It's 09:43 AM.
