03-08-2013, 11:37 PM
#74656 |
Motersykle Advntyers
Oddometer: 439
I've got a big block front and a tkc rear right now in big bend. Can't say enough about the setup, handles the sand out here really well. Can't speak to wear but it's making me smile a lot :)
I haven't been everywhere, but it's on my list. 2007 BMW R1200 GSA, 2009 DL1000, 2005 DR650 |
03-09-2013, 01:25 AM
#74657 |
Oddometer: 194
My bike it is ready to race :)
dopra bike and ride - thread http://www.advrider.com/forums/showthread.php?t=855584 |
03-09-2013, 03:38 AM
#74658 |
Oddometer: 920
Looks well set up, dopra. I'd fasten down that front brake line so you don't lose it on the first bush. Are those frame protectors a manufactured item or home built? They look great and would be a good addition to my bike if you have a source.
Thx for the pics. Always a benefit of the DR....the ability to make it your own.
www.dualsportmoto.com 2005 DR650 2013 HD Road King "It's a small amount of gas, but it represents a long walk" My Dad... |
03-09-2013, 03:42 AM
#74659 | |
Oddometer: 194
03-09-2013, 04:29 AM
#74660 |
Oddometer: 573
thanks
That looks fairly simple, is the trick just getting good balance on a hard surface?
Where might one find one of these? Thank you good sir.
Scott 06' Triumph Tiger (my lifer) 06' Husqvarna TE610 |
03-09-2013, 04:32 AM
#74661 | |
Oddometer: 573
thanks
Thanks Sarah, that looks great for the garage, is it fairly sturdy?
![]() Quote:
03-09-2013, 04:52 AM
#74662 | |
Procrastinators
Oddometer: 5,804
They work really well for removing wheels, or lubing the chain, which is what I'm doing in the picture.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 03-09-2013 at 05:30 AM |
03-09-2013, 05:29 AM
#74663 | |
Meh
Oddometer: 15,770
Pro cycle and keintech sell an upgraded version.
COHVCO Member and Blue Ribbon Coalition Member I have a DR problem |
03-09-2013, 06:21 AM
#74664 | |
Oddometer: 92
I see Keintech also has a "simple stand", works on the front or back. I think it's ~$30 or so. |
03-09-2013, 07:08 AM
#74665 | |
What? Me hurry?
03-09-2013, 09:16 AM
#74666 | |
Butler Maps
Oddometer: 14,434
The K270 has incredibly tall lugs (so tall in fact that it detracts from paved road performance and squishes all around when cornering...but hey it's cheap ie. a KLR tire). There is just alot of rear tire rubber height to wear down before they wear out. The rubber is not that great of a compound but there is alot of it. The the knobby height of the Big Block is very short compared to. I think Kenda just decided let's make a shorter knobby version for bigger bikes that will not be so squirmy on the pavement. Then they forget to engineer some better rubber compounds to deal with less rubber being available before wear out point. They did it on the cheap and it shows. Before the Shinko 705, Maxxis had the Pressa tire. It looked to be middle ground between the TKC & the Tourance. Maxxis also used crap rubber and they wore out fast. Maxxis dropped the tire and have not heard from in the ADV tire market since. My point? Once you start building tires for the ADV market you're now in the big boy game with Michelin, Metzler, Conti, Heidenau and even Shinko. You better bring your A game with unique tread design and rubber compounds. Kenda brought their C game.
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps eakins screwed with this post 03-09-2013 at 09:21 AM |
03-09-2013, 09:28 AM
#74667 |
Life behind "Bars"
Oddometer: 6,259
so, as a compromise tire, which gives the the better offroad grip,
Shinko 244 or Kenda 270? Looking for something that will last longer than a full knobby, but retain as much grip in dirty situations as possible. Since I have an 18" wheel avail, I'm even thinking about Pirelli MT43.
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
03-09-2013, 09:29 AM
#74668 | |
Butler Maps
Oddometer: 14,434
You can see it here on the left tire pic. http://www.google.com/imgres?imgurl=...9QEwBg&dur=516. The Big Block was all knobs and shorter ones at that. To fix their fast wear problems they'll either need better rubber (but I doubt if they have the technology as were talking Chinese cheap here) or just add a center rubber wear strip (the cheap fix). If you start studying a K761 and a Heidenau K60 you see they are using the same general tread design idea. The K761 would make a good rear tire for a mullet combo, but I'd still put $ on this one if you need to go the distance on a long tour: http://www.motorcycle-superstore.com...Rear-Tire.aspx
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
03-09-2013, 09:31 AM
#74669 |
Oddometer: 1,405
I like the DR because its aircooled and no doohickey to fix unlike the KLR. I like the KLR because it is big and roomy with a 6 gallon gas tank. Has anyone ever put a DR motor in a KLR frame? Best of both worlds me thinks and it would lighten the KLR too.
Socialism works good until you run out of other people's money to spend.
03-09-2013, 09:39 AM
#74670 | |
Butler Maps
Oddometer: 14,434
the lugs are slightly wider and the rubber compound is slightly softer thus grippier. there is also the IRC GP-1 http://www.motorcycle-superstore.com...Rear-Tire.aspx Shinko gets all the attention because of the good price and decent tire but IRC (japanese build) is a better tire...at $128 it's a hard sell however and most choose Kenda or Shinko instead.
