Old 03-14-2013, 05:11 PM   #74761
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Originally Posted by rspratley View Post
Just added a 45 vision x light to my DR
I am also thinking about adding a single 40degree Vision X. please let us know how you like it in the deep dark.
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 03-14-2013, 06:01 PM   #74762
MATT0404
MATT0404's Avatar
Oddometer: 172
Originally Posted by Mambo Dave View Post
Sounds like a jet is a little clogged or something.
Sea Foam for a few tanks, then determine if it's still a problem.
Originally Posted by Adv Grifter View Post
Normal. But after a minute on choke ... you can just ride off. Leave the choke on for another minute or so ... riding will achieve warm up ten times faster than sitting at idle. Don't over rev it or Lug it for the first five minutes ... after that ... anything goes.
Be sure to practice what you learn in the riding course ... especially things like identify and avoidance. Try to learn how NOT to target fixate ... many Noob riders go off the road or hit someone in their path because of that. Most times you can STEER around obstacles. But you have to stay cool and NOT fixate on the car in your path. Look for a safe out.
Practice tight figure 8's, holding throttle on steady, using rear brake to control speed. Go ahead, lean that sucker OVER! Learn to counter steer. Understand what that is. Remember .... YOU WILL GO WHERE YOU LOOK. Don't fixate. Doing tight figure 8's ... turn your head left and look way left. You will go there.
Also learn to safety check your bike. Tire pressures are important. Check 'em once a week at least. Know you tank range ... and know how to switch to reserve instantly without looking, must be done by feel. This could save your life.
Do braking practice. Learn to use BOTH brakes and learn how NOT to lock the rear brake and how to really hammer the front brake when you need to.
It's a jungle out there ... ride accordingly. Be safe, have fun!
Originally Posted by shu View Post
30* F? Brrrr...getting cold.
Normal, as Grifter said. It will buck and snort for a little while at small throttle openings when cold, but it should run tolerably well at just a bit higher speeds. Keep it at the lowest throttle where it still feels smooth and let it gradually warm up for 10 minutes as you ride.
Try to avoid jumping right onto the freeway with cold motor.
..........shu
Thanks for all the info and tips, guys! Much appreciated. I'll see how she does tomorrow morning.
MATT0404 is online now   Reply With Quote
Old 03-14-2013, 07:35 PM   #74763
TrophyHunter
Oddometer: 2,266
Originally Posted by SoPaRider View Post
Does anyone know a source or part number for the drilled rear brake master cylinder guard I've seen on some DR650's? '09 DR650SE
http://www.procycle.us/images/bikepa...cylguard-1.jpg
Procycle
'07 WR450 2013 HD Road King '73 Hodaka Wombat '15 Tiger 800 XCx
TrophyHunter is offline   Reply With Quote
Old 03-14-2013, 07:40 PM   #74764
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Originally Posted by TrophyHunter View Post
I have this guard (can't stand the expanded metal look of the one Procycle carries).
http://www.tpimotorcycleparts.com/in...category_id=64
Old 03-14-2013, 07:42 PM   #74765
WindPipe
WindPipe's Avatar
Oddometer: 211
I recently did the procycle jet kit, and it improved the starting and warmup time considerably. In fact, with the temp in the high 40s, I didn't even have to use the choke this afternoon. Much better at low-rpm cruising too.
The future is wide open.
WindPipe is offline   Reply With Quote
Old 03-14-2013, 08:48 PM   #74766
shu
Oddometer: 1,054
more from South of the Border
Heading south of the Monterrey / Saltillo area today on backroads to Galeana and beyond.
Oops.....
First drop of the trip.
We wanted to get an idea of what the real back roads were like here so we we turned off the pavimento and started down a little track by the river. Karst waved me on, so I headed off through the 3 small water crossings (puddles really). The puddles all had about about six inches of water with round river cobbles (hand-sized to foot-sized) in the bottom. A little slippery but okay. Unfortunately, in the third puddle the cobble layer was bottomless. The rounded stones were covered with algae and rolled on each like roller bearings. Two thirds of the way through my front wheel buried itself about 10 inches deep in the stones and down I went. Karst, being a good friend, immediately got his camera out and took a bunch of pictures....... then, he came into the water to help me right my bike.
I'm almost back out of the puddle and my rear wheel keeps spinning and burying itself in the cobbles.
Taking a break
We came out of the mountains and turned off at a little town called Rayones- muy tranquilo- and stopped for something to drink at this little roadside food stand.
........................shu
shu is offline   Reply With Quote
Old 03-14-2013, 09:04 PM   #74767
ER70S-2
ER70S-2's Avatar
Oddometer: 6,960
Oops.....
Whatta buddy.
Taking a break
Rock-n-roll Shu: Keep 'em comming.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 03-15-2013, 03:29 AM   #74768
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,666
Originally Posted by blackcap View Post
trailtech sells a 14mm brass washer sensor that you can use to replace one of the brass washers on the oil line that goes into the cylinder head. that way your getting a reasonable ide of what the oil temp is and if your counter shaft oil seal spits itself out and the bike dumps all the oil before you notice, youll hopefully notice a spike in head temp before doing to much damage.
Or you can use a round file and file out the stock one that is supposed to go over the plug. I did this and have fitted it to the upper oil banjo with good results.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 03-15-2013, 05:06 AM   #74769
rspratley
Oddometer: 26
I had mounted it in the wrong position so the first test was medium. I have already changed it to the correct position (it was rotated 90 degrees from correct position) and will test it again.
rspratley is offline   Reply With Quote
Old 03-15-2013, 06:17 AM   #74770
Kommando
Kommando's Avatar
Oddometer: 7,389
Originally Posted by KJD19892 View Post
Ok so I know it has to have been covered in here somewhere but I guess I'm technically challenged today or something. I'm wondering two things for my 00' dr650:
One: How do I bypass the clutch safety switch thing, and the kickstand one?
Two: Can anyone recommend a headlight and surround that looks and works better than stock? I looked and the trail tech torch but it doesn't list a DR as compatible?
Thanks!!
KLX450 light and surround with an HID. Complement it with a YZ450F front fender.
Kommando is offline   Reply With Quote
Old 03-15-2013, 07:10 AM   #74771
blackcap
blackcap's Avatar
Oddometer: 548
Thanks!!
check out brittania composites. if you got the money the extra light is worth it.
"One must die sometime and to die with ones boots on is very noble" - Carl Stearns Clancy, first RTW motorcycle, 1912-13
Australia to Iceland on a DR650 http://oztoice.wordpress.com
and facebook https://www.facebook.com/oztoice
blackcap is offline   Reply With Quote
Old 03-15-2013, 08:10 AM   #74772
MATT0404
MATT0404's Avatar
Oddometer: 172
Oops.....
Taking a break
Looks like a good time! Nice photos and story. Thanks for sharing.
I got out this morning for about 15 miles on some private dirt roads this morning. I rode for a few minutes with the choke half on and it seemed to help the bogging and sputtering. Once warmed up, it ran great.
2012 Suzuki DR650 by mkrepp, on Flickr
Old 03-15-2013, 08:31 AM   #74773
TrophyHunter
Oddometer: 2,266
Shu - thanks for keeping the riding spirit alive with the pics. Universal motorcycle experience...."are ya dying?...No..?...hang on, lemme get my camera.."
I went with a Polisport front fender for about $25 shipped off of ebay. Straight bolt in and I like the looks. Rock solid at freeway speeds.
Old 03-15-2013, 08:37 AM   #74774
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,219
There's a better way of mounting those aux lights.
Just get a longer bolt and a couple of spacers from Home Depot and run them into the lower of the two fork bolts.
I used to have little brackets that attached to those same bolts, but after two years, the vibration broke one clean off and the other one was cracked, so I removed them and came up with this solution. Now they're totally solid.
As for performance, they're outstanding. And at 10W each, they don't take much power. Aim the right and oncoming cars RARELY have an issue, though cars ahead of you will hate you. All the better -- they tend to get out of the way quicker.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 03-15-2013, 08:45 AM   #74775
KJD19892
KJD19892's Avatar
Oddometer: 143
I'm liking that look. How much modifying has to be done to make that work??
KJD19892 is offline   Reply With Quote
Times are GMT -7.   It's 07:44 AM.
