Old 03-18-2013, 06:53 PM   #74911
garnaro
MotoBlunderer
garnaro's Avatar
Oddometer: 288
Originally Posted by motolab View Post
What is the "this" you are referring to?Yes. Going to two lift holes halves the life of the slide guide, emulsion tube, slide and possibly jet needle. Enlarging two lift holes to .125" halves the life again.
Regards,
Derek
By 'this' I meant the extra wear on the slide and the jet needle. Very good to know as I never considered this. Throttle response is somewhat improved with the drilled slide, but before a long trip I may just put a stock slide back in.
bugsonmyboard.org
two wheeled wave hunting dispatches
garnaro is offline   Reply With Quote
Old 03-18-2013, 07:00 PM   #74912
Skidmarkart
Dirty Middle Age Man
Skidmarkart's Avatar
Oddometer: 209
Originally Posted by Escaped View Post
The store said I order the wrong tire and they would not refund my $$$. I said "BS here is the order form filled out by your employee and here is my notes on tire size". After a period of heated discussions they refunded my money for the tire but not for shipping - bastards!
Damn - that sucks. Hop eyou gave them a lovely Yelp review.
I don't think these guys were doing anything bad intentionally - it was an honest mistake. I should have come in and looked at the other tire, and they should have told me it was a different size. I just hope they have a decent attitude about it.
Honestly, IMHO that's the real sign of a decent shop. How do they act when something goes wrong? Guess I will find out soon.
Skidmarkart is offline   Reply With Quote
Old 03-18-2013, 07:43 PM   #74913
procycle
procycle's Avatar
Oddometer: 2,276
Originally Posted by kbuckey View Post
an off idle stumble - harder to get moving, I've stalled it more than once at lower elevations forgetting that it needs more throttle to get moving. ....
Yes my mileage has improved lately. Don't really know why. Not riding it any differently. From a normal 48 ish to about 52 mpg.
I've seen these exact symptoms. The problem turned out to be the plastic washer on the needle was severely worn which was causing the needle to run in a lower (leaner) position. If that's what is happening with your bike you can flip the plastic washer over and be back to the original needle height.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 03-18-2013, 08:17 PM   #74914
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Considering the multiple reports of pinging, at least some of which were on a completely stock bike, I would not recommend opening the airbox and jetting lean unless I was able to verify that the engine was in a safe zone with regards to detonation.
Regards,
Derek
I'm not suggesting jetting leaner than stock or too lean ... but to MATCH stock jetting ... or get close.
When the air box is opened and carb re-jetted, DJ (or other) needle installed, jetting is typically set richer than stock to compensate for the open air box and more free flowing air filter. (IE: from stock 140 Mikuni Main jet to a 160 Dyno Jet main jet)
All I suggest is don't go TOO RICH on the Main jet or needle clip position ... try to match stock jetting. Obviously if pinging occurs ... you've got a problem ... and I'm betting in some cases it's the "loose nut behind the wheel" ! (Lugging?)
I've ridden 3 brand new DR650's ... going back to 1996. No pinging on any of them running mostly regular gas. Also, my riding group now has 6 DR riders ... no pinging reported among that group either. 3 are stock, 3 are opened up and re-jetted. We've ridden together 10 years and about 50,000 miles. Almost always a DR or three on our rides.
But always best to start a bit rich and lean things out step by step. Experts would use a gas analyzer and dyno to get the set up precise. YMMV.
Old 03-18-2013, 08:25 PM   #74915
Adv Grifter
Oddometer: 6,128
The shop on the other hand was great - In the end they only charged me for the one tire mounting - even when I went back to with the correct tire for the front.
I can see paying someone to change and mount a rear tire ...but honestly, the front is a piece of cake. Do it your self. Once you get it down .... maybe you can tackle the rear tire?
Remember: it's Technique, Not Technical.
Old 03-18-2013, 10:14 PM   #74916
french horn
Just Add venture
Oddometer: 470
Looking for advice ... my sons' DR got drowned in the Bundaberg floods.. A mate of his took it home and "checked it out" ... I'm not sure what he found but after a few days said it was now OK.
Son rode it home ( a few K's ), then it wouldn't go again.
Here's the question: ... bike shop has looked at it and estimates $3000 to fix it ... WHAT COULD BE WRONG? ... I thought an oil change would resolve the "swim" .... any/all thoughts appreciated.
french horn is offline   Reply With Quote
Old 03-18-2013, 10:44 PM   #74917
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 163
Sorry, but not enough information...
Was it making noises when it 'stopped'?
Was it running when son turned it off, or did it die and refuse to re-start?
Did it stop violently or with a "bang"?
What was the $3000 estimate for?
What did the shop say needing fixing?
VooDooDaddy is offline   Reply With Quote
Old 03-18-2013, 11:25 PM   #74918
reinstein7
Oddometer: 7
2013 DR650se NEW WOOT
Im the damn proud owner of a new dr, love this site, just wanted to let yall know that dr350 ims super stock pegs bolt right up to the new 650 and what a damn fine addition to the already damn fine dr. nuff said bout the pegs, got the best rack for the rear and mounted the three gallon black rotopax tool box with locking t bar looks sweet, put oil filter magnet and oil drain plug magnet on it. way more goodies on the way, quickly before the wife notices! postin picks ina few weeks. posted all my new dr350s stuff on this site and sold it all, want to thank all of you that bought it, thats over a grand of goodies for the new zuk. one question, any reason to switch my petcock to the pingle? or just wait till the oem wears out?
Reinstein7
reinstein7 is offline   Reply With Quote
Old 03-18-2013, 11:35 PM   #74919
ER70S-2
ER70S-2's Avatar
Oddometer: 6,276
Welcome.
Reinstein7
I don't get the Pingle love. The manual Yamaha Raptor petcock is $25.
I just installed the stock vacuum petcock on my new Acerbis 5.3 gallon tank. Oh, the petcock has 9 years and 44,323 miles.
2004 DR650: 62,496 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 03-19-2013, 12:23 AM   #74920
YnotJP?
Oddometer: 2,395
Reinstein7, Welcome, you will surely enjoy the DR650. I have a Pingel petcock and like it very much. I am sure the Raptor petcock works very well also, and does cost a lot less.
The only reason I like a manual petcock is that is all I have ever had and I understand it and turning it off is automatic for me.
YnotJP? is online now   Reply With Quote
Old 03-19-2013, 12:31 AM   #74921
french horn
Just Add venture
Oddometer: 470
Thanks for the response, .... that's all I know at the moment, I'll try getting that info asap...may take a few days.
cheers
Old 03-19-2013, 01:51 AM   #74922
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,518
Originally Posted by 8gv View Post
Is anyone here aware of a year by year comparison of DR650 models since their inception?
Is there a first, second or third generation on these?
If I were looking for newer, is there a model year range that is basically the same as the 2013 model?
EPA Q's:
Has pollution control crept into this model?
Is there a "50 state" model and a "49 state model"?
You might find the answers here somewhere: follow this link and have a look at the DR history pages;
http://dr650.zenseeker.net/
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 03-19-2013, 04:35 AM   #74923
rand0mlychrisUK
rand0mlychrisUK's Avatar
Oddometer: 28
Question What a Shock
Would a '92 RS rear shock absorber fit a '93 RSE? IE, do they share most mechanical parts, or would they each have their own configuration and spares?
Cheers,
Chris
rand0mlychrisUK is offline   Reply With Quote
Old 03-19-2013, 08:24 AM   #74924
kbuckey
Oddometer: 831
Thanks, Jeff. If I'm going to open it up anyway, think I'll do a complete refresh. Heck, might buy a used carb too and then I can screw with one and still have one I know is going to be OK!
kbuckey is offline   Reply With Quote
Old 03-19-2013, 08:35 AM   #74925
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,133
Cheers,
Chris
Chris, Almost everyone here has the newest generation (if you can consider 1996 new ) DR650's
best to ask here:
http://www.advrider.com/forums/showthread.php?t=61568
These guys are far more likely to be able to answer your question.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Times are GMT -7.   It's 06:41 PM.
