Old 03-25-2013, 07:22 AM   #75106
gjcarving
Oddometer: 101
Originally Posted by ER70S-2 View Post
So are we.
Oops, DR pic:
If I remember correctly from your other post and pictures of your bike, it looks like you have been busy this winter adding lots of goodies to your bike. Looks Great!
gjcarving is offline   Reply With Quote
Old 03-25-2013, 11:03 AM   #75107
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,131
Originally Posted by Rob.G View Post
Hey does anybody know which bike the MX-Rob FCR carb for the DR comes from? I need to order a new choke for mine because it won't stay engaged.
Thanks.
Rob
Check with Sudco or Carburetor Parts Warehouse
http://carbparts.com/
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 03-25-2013, 12:10 PM   #75108
ER70S-2
ER70S-2's Avatar
Oddometer: 6,274
Originally Posted by LexTalionis View Post
Speaking for myself and I'm sure for many, many others: we are very grateful for your efforts, also!
Lex
Hi Lex.
Thanks, all dressed up and nowhere to go.
2004 DR650: 62,496 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 03-25-2013, 12:17 PM   #75109
motolab
motolab's Avatar
Oddometer: 2,579
Thanks.
Rob
If your carburetor has a choke, it's not likely to be an FCR.
Regards,
Derek
motolab is offline   Reply With Quote
Old 03-25-2013, 12:18 PM   #75110
ER70S-2
ER70S-2's Avatar
Oddometer: 6,274
2013 WR250R
Old 03-25-2013, 12:31 PM   #75111
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,228
Regards,
Derek
I disagree with a lot you have to say, but I kept my mouth shut, but this tops it. Do you really dyno bikes? Have you ever tuned a bike with an FCR on it?
Just about every bike I have ever been around with an FCR had a choke on it. My stock WR had a choke on it, and my DR with an FCR has a choke on it.
Added: I am sure you are going to chime in about the technical difference between a choke and an enricher circuit, but for the average person they are they same in the way they work to warm a cold bike up.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 03-25-2013, 01:10 PM   #75112
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,165
I looked up the price of a choke for the FCR in my Outlaw 525 and it was $100!!! So if that's the case off of all the variations of the FCR, maybe I can find another bike or something where I can get the thing cheaper. Otherwise I'll just keep dealing with it as it is. It's a mild annoyance is all.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 03-25-2013, 01:25 PM   #75113
ER70S-2
ER70S-2's Avatar
Oddometer: 6,274
Stock Vacuum Petcock in the Acerbis 5.3
Using the stock vacuum petcock with the Acerbis isn't a 'bolt and go' option.
Stock Acerbis.
I suggest changing the order that I did this project. File the flat first, if you loose interest or decide this is too much trouble, you can still use the Acerbis petcock. Once the hole is ovaled, there's no goin' back.
If your tank has a raised boss on the surface like the Acerbis 5.3, you'll need to file it flat or the rectangular o-ring on the stock petcock won't seal. The o-ring isn't very 'fat' and won't seal over the four red circles shown below. You want to be real careful here, since the o-ring is so thin, if you nick the surface with a power tool, it won't seal.
I used a hand file, it took forever and I'm happy with the result. File til my fingers hurt, watch TV, file til my fingers hurt, watch TV................................................ .. I used single file strokes, making sure the file was flat to the surface every stroke.
Petcock hole elongated for the double tube stocker. Once you commit to this point, the Acerbis petcock o-ring won't seal anymore.
Stock petcock on the left, Acerbis on the right.
Where it's going to leak.
Original debris inside new tank doesn't matter since the filing to fit added more (And why you want to rinse out your new tank before you use it). A benefit to the neutral color; it was easy to see inside the tank, all surfaces. I used hot faucet water to rinse the tank, shook it up good and drained it, three times. To get the remaining droplets out, I rubber banded a paper towel to a dowel. The neutral color made the drops sparkle, easy to blot up.
Another difference, the stock petcock is 1" taller than the Acerbis. This might be a problem since the uphill loop is now 1" higher. Note: ignore the vacuum port, which is less than 1" (a bit misleading in the photo).
The uphill loop and potential vacuum lock. When the fuel level gets low, there isn't enough head pressure to overcome the air bubble in the loop. This means the bike quits running even though you can still see gas in the tank. It's a common problem on both the IMS and Safari aftermarket tanks, some work, some don't. I haven't heard anything on the Acerbis yet.
And: the vacuum petcock is thicker where it screws to the tank. I don't like the idea that there aren't threaded metal inserts in the tank, the mounting screws thread into the plastic. My point is, now the provided 2 screws are too short for a good secure bite in the plastic. OCD, maybe. The provided screws are 3/4", I bought a pair 1" long (size 12x1 SAE stainless is just a bit larger O.D. [.17mm] than the 5mm that were supplied).
Before:
Reason, low profile front tire:
After:
2013 WR250R
ER70S-2 screwed with this post 04-02-2013 at 03:15 PM
Old 03-25-2013, 01:29 PM   #75114
motolab
motolab's Avatar
Oddometer: 2,579
Rob
Is the carburetor you have an FCR or an FCRMX?
Regards,
Derek
Old 03-25-2013, 01:44 PM   #75115
sandwash
sandwash's Avatar
Oddometer: 1,349
I got my FCR MX off a YFZ 450 quad(straight body/slide) and it has choke knob and it evens works!
97dr650
sandwash is offline   Reply With Quote
Old 03-25-2013, 02:05 PM   #75116
clfarren5944
Oddometer: 41
/QUOTE]
I decided to use the Acerbis supplied petcock because of the large weight difference between stock and Acerbis. They might have planned it that way so the screws into plastic would not present a problem.
Chris
clfarren5944 screwed with this post 03-25-2013 at 08:00 PM
clfarren5944 is offline   Reply With Quote
Old 03-25-2013, 02:09 PM   #75117
NYTrainer
NYTrainer's Avatar
Oddometer: 145
My FCR41 has a choke.
BTW, the guy who is selling his original carb in the Flea Market who stated that the " The pumper was not worth the trouble to set up" does not know what he is missing!
I was lucky & bought mine from a very knowledgeable gentleman who sent it to me set-up & ready to go. A true bolt-on.
On the road the CV does OK, but off-road there is no comparison!
"Win without boasting...lose without excuse!"
2004 DR650 Suzuki,1978 Yamaha XS750,
1981 Yamaha XS650 Street Tracker,1981 Yamaha XV920 Chain-drive
1986 Yamaha YZ490-Vintage MX project, Yamaha TW200(Girl Friend's Ride) Yamaha TDM 850
NYTrainer is offline   Reply With Quote
Old 03-25-2013, 02:11 PM   #75118
ER70S-2
ER70S-2's Avatar
Oddometer: 6,274
Chris:
You may be right.
Could you go back and edit out 11 of those photos? It's a bandwidth thing for some users.
2013 WR250R
Old 03-25-2013, 02:15 PM   #75119
motolab
motolab's Avatar
Oddometer: 2,579
Unless someone did a really strange retrofit, your FCR41 has a cold start enrichment circuit.
A choke is closed when an engine is cold and opened when it is warm, whereas a fuel enrichment circuit is opened when the engine is cold and closed when it is warm. A choke works by restricting the air flow, whereas an enrichment circuit works by adding extra fuel. A choke requires a fast idle cam or something akin to it (or you have to hold the throttle open manually), whereas an enrichment circuit adds a little extra air simultaneously with the extra fuel, so the fast idle is already built in.
Regards,
Derek
Old 03-25-2013, 02:34 PM   #75120
Rusty Rocket
Life behind "Bars"
Oddometer: 9,131
Regards,
Derek
How many times do you feel it necessary to point this out.
All adjustable wrenches aren't Cresent wrenches, but if someone says "Cresent wrench" everyone knows what they are talking about.
Same with Allen wrenches.
The little picture on the handlebars of the DR650 shows an image that is unmistakeable that a true choke resides in our carburetors.
Maybe that's where the confusion originates. I'm sure when someone pulls that carb apart, a lightbulb goes on and they will come to realize the reality.
Let's just all agree that when someone says the choke on their DR, they mean the system used for coldstarting the bike.
Regards, Rusty
2009 DR650
Times are GMT -7.   It's 02:24 AM.
