Old 03-25-2013, 10:44 PM   #75151
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
Fuel milage
with the way my DR is set up right now E7OS I got 177 165.354 fathoms from the tank before switching to reserve with another 218 722.66 cubits left approx before i totally run out of fuel. which would means i should refuel before another fortnight.
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Old 03-26-2013, 12:47 AM   #75152
Magnum Noel
Magnum Noel's Avatar
Oddometer: 196
Thumb JagLite
JagLite-That looks a million dollars. keep up the good work
Magnum Noel is offline   Reply With Quote
Old 03-26-2013, 01:01 AM   #75153
Thumper Dan
Oddometer: 329
throttle cable adjusment - tm40
I have a reasonable amount of free play at the throttle. I adjusted out the free play via the adjuster located up on the handlebars. However, the throttle won't snap back when removing the corrected amount of free play.
Do I need to go down to the 'pull' cable to add some adjustment there, to help with the snap back OR do I need to leave it where it is and have that bit of free play??
Just to note, I don't have any binding (nor did I - but will check after I finish with adjustments).
thanks from the noob.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 03-26-2013, 06:06 AM   #75154
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 918
Originally Posted by 3DChief View Post
I posted this up about a year ago, but here it is again. If you turn the carb inlet to the rear, no high spots and you can get all the fuel out. It is also in the bike specific thread under fuel system. It's an IMS tank with Raptor petcock.
Tim
I'd like to do just that but can't get the elbow to budge!
New Mexico, not really new, not really Mexico.
Carl Childers is offline   Reply With Quote
Old 03-26-2013, 06:50 AM   #75155
Otis357
Dirty Hippie
Otis357's Avatar
Oddometer: 433
Anyone know if an after market seat (Renazzco) for an IMS tank will fit a DR with the Acerbis 5.3 gallon tank??
Otis357 is offline   Reply With Quote
Old 03-26-2013, 07:03 AM   #75156
disconnected
rider
disconnected's Avatar
Oddometer: 7,449
It should, for comparision the Corbins for IMS work with the Acerbis. :)
IBA # 47004
disconnected is offline   Reply With Quote
Old 03-26-2013, 07:09 AM   #75157
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,190
TD,
Didn't you adjust the 'pull' cable? If so, yes, you may need to slacken the 'push' cable to allow the butterfly to snap closed.
I know of a few folks that simply remove the 'push' cable as it's redundant (I have not but I did on my DR350SE). There's already a big return spring on the carburetor itself so why add another cable? Some opine that it's due to liability and the 'push' cable is some attorney's idea of how to reduce/eliminate said liability. YMMV.
So, adjust the 'pull' cable with slack in the 'push' cable. Then, remove the slack from the 'push' cable without binding things up. Extra slack in the 'push' cable won't harm anything.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 03-26-2013, 07:13 AM   #75158
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,190
Originally Posted by dukegnarley
has anyone had the starter torque limiter start to slip? my bike has developed a weird whining sound when trying to start the bike. The engine will still turn over, but it sure doesn't sound right.
Any thoughts? It's a 2001. with about 7,000 miles.
My DR does that when temps are below 40 F. As inmate 'dman' indicated, the starter bushings need lubrication. Unfortunately, the starter can't be removed without pulling the cam chain tensioner. It's not difficult but it's not as trivial as just removing the starter and lubing the bushings.
Old 03-26-2013, 07:16 AM   #75159
shu
Oddometer: 1,073
Originally Posted by SoPaRider View Post
shu
As per your recommendations, today I ordered the same set of tires your running. I think this question was already asked, but what the heck, what tire pressures do you run, paved/rocks/sand? How far south of the boarder have you gotten on this ride? Enjoying your warm and sunny ride report from Mexico as it snowed here today too, forest roads are still frozen over in places and the highest HILLS we have are only 1,400 feet!
Jeff
Hi Jeff-
If you look at a map of Mexico we went to the farthest point south on the curve of the Pacific coastline. Little town called Puerto Angel, due south of Oaxaca. 95 - 98* F down there. We're now back up in the highlands west of Mexico City.
Tire pressure for MEFOs and Heidenaus: I've settled on 26 front and 28 rear. Plenty hard for the relatively lightweight DR and I've never worried about bending rims or slipping tires/tubes. Occasionally I'll lower the pressure for sand but never below 20 psi- maybe I'd ride sand better if I did but I don't want to risk my wheels etc.
...........shu
shu is offline   Reply With Quote
Old 03-26-2013, 07:26 AM   #75160
TRAVELGUY
Old Traveler
Oddometer: 716
I like!! Very impressive!!
TravelGuy
Originally Posted by JagLite View Post
Before I reach for a Kleenex, er, tissue, let's get back to DR's.
Here is the fiberglass tank I made with my first attempt at painting with base and 2 part clear coat.
And my first ever buffing and polishing effort.
It's not great, but good enough for a dirt bike
I was trying to get a good reflection on it.
All I have left to do is the lettering and pinstripes on the tank and tail, and to mount the oil cooler, chain, and chain guide...
It has been a fun project and I look forward to riding it.
Although I will be riding my other DR a lot more often. Now I have a street (and smooth dirt road) hot rod as well as my dual sport DR that is far more comfortable to ride.
Love it or hate it but it beats some of the boring posts recently.
If only because it has pictures
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is online now   Reply With Quote
Old 03-26-2013, 07:28 AM   #75161
Kommando
Kommando's Avatar
Oddometer: 7,390
Only stiff seats like Corbins typically have a problem fitting different tanks.
Kommando is offline   Reply With Quote
Old 03-26-2013, 07:29 AM   #75162
disconnected
rider
Oddometer: 7,449
does anyone have any tips on how to get every last drop of fuel out of the stock DR tank.? I replaced my stock tank and have it for sale and there seems to be some fuel in there. I have poured what I could out of the petcock etc. I guess it may/should evaporate out of there?
IBA # 47004
Old 03-26-2013, 07:31 AM   #75163
TRAVELGUY
Old Traveler
Oddometer: 716
Didn't someone post recently that it could be possible to just pull the end cap off the starter to re lube the bushing with removing the cam chain tensioner?
TravelGuy
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
Old 03-26-2013, 07:35 AM   #75164
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
The Renazco's are built on the stock pan, so it should fit just fine.
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 03-26-2013, 07:49 AM   #75165
TRAVELGUY
Old Traveler
Oddometer: 716
Did you find really heavy winds in the area of Puerto Angel? In 2008 on my way to Costa Rica we crossed into Guatemala at Tapachula Mx. Thought it must be the windiest place on earth. There were 100's of electric generating wind mills along that coastline for probably 40 miles. Was very dangerous riding with the high winds and sand on the pavement. One of the few times I have felt real fear on a motorcycle. Wish I had been riding my DR instead of my V Strom.
TravelGuy
Originally Posted by shu View Post
Hi Jeff-
...........shu
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
Times are GMT -7.   It's 05:59 AM.
