Old 03-28-2013, 05:19 PM   #75286
ER70S-2
ER70S-2's Avatar
Oddometer: 6,274
Eh?
The other photo in Lex's link: (thanks Lex)
2004 DR650: 62,496 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 03-28-2013, 07:39 PM   #75287
Kommando
Kommando's Avatar
Oddometer: 7,360
Originally Posted by acesandeights View Post
I don't either.
I believe it. Summer tires shouldn't even be stored in temperatures below freezing. They become brittle and slippery, like glass. Then they can shatter and/or crack, as you have seen.
A lot of people bad-mouth all-season cage tires as not being capable in the snow. They're not designed to be snow tires. They're simply designed to not become brittle and slick in freezing temps, while not vaporizing when heated up like many snow tires do. Moto tires are similar. If you see freezing temps, use tires rated for that.
Kommando is offline   Reply With Quote
Old 03-28-2013, 08:58 PM   #75288
shu
Oddometer: 999
I've lived in Colorado nearly all my life, and I've never seen a tire, moto or car, that froze and broke. You may be right but it gets below freezing here a lot, from Sept to May.
........shu
shu is offline   Reply With Quote
Old 03-28-2013, 09:15 PM   #75289
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,779
Growing up in PA seeing temps below zero for weeks at a time- I have never seen a tire freeze. I'm calling bullshit.
Mongle is online now   Reply With Quote
Old 03-28-2013, 09:21 PM   #75290
oldschoolsk8ter
Oddometer: 70
This is true for "high performance summer tires" refer to your manufacturer for their guidelines for each model of tire.
http://www.tirerack.com/tires/tirete...jsp?techid=220
oldschoolsk8ter is offline   Reply With Quote
Old 03-28-2013, 09:26 PM   #75291
oldschoolsk8ter
Oddometer: 70
Warning from Hoosier....
http://www.hoosiertire.com/safetywarning/index.htm
Old 03-28-2013, 09:34 PM   #75292
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
So no mention of motorcycle tyres at all.
Picture of one cracked tyre and all Bridgestones are bad?
It's like the "All Trailwings are Deathwings" crap.
It also looks like it would have had to be a combination of extreme cold and a pointed impact on that road tyre...
NordieBoy is offline   Reply With Quote
Old 03-28-2013, 10:39 PM   #75293
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,228
Freezing Tires
Don't know about tires freezing, but my F-250 4x4 (235-16 Toyo load E) and toy hauler (235-15 Toyo load D) had flat spots on them for about an hour of driving after being parked over nite at Teslin, Yukon when the mercury read -72F with strong winds.
We drove jogging speed for several hours to get out of that cold valley to warmer places. Several valleys over it was only -42F and we could pick up speed. The locals said to not go very fast because springs or axles could break when hitting chuck holes etc. One of the trailer springs did break on the way home... from too much weight (Toyota Land Cruiser in the toy hauler and lots of carpenter tools).
Glad that spring broke behind the axle. A piece of firewood was inserted between the axle and frame and wired in place. That field repair lasted several thousand miles to home. New springs were installed there in a warm shop. It was a nice month long road trip to Anchorage for Christmas to visit family and picked up the Toyota and tools.
Dave
smilin jack is offline   Reply With Quote
Old 03-28-2013, 11:16 PM   #75294
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,598
Originally Posted by smilin jack View Post
...Several valleys over it was only -42F...
There's a sentence you don't see every day. 'Only' ...
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 03-29-2013, 06:47 AM   #75295
basketcase
lifelong reject fixer
basketcase's Avatar
Oddometer: 1,417
"Summer tires?" Jeezum -- once again I've heard it all. Summer tires is as big a crock as the old prank of "winter air." Or the carpenter's prank of a "board stretcher," or the plumber's joke about "left-handed" pipe wrenches.
Dude - somebody has pee'd on your leg and convinced you it is raining.
The defining difference between a street tire and a rough terrain tire is the thread pattern. Rubber compound (softness or hardness) primarily impacts thread life (i.e., miles derived under use on the intended surface).
Off-road tires grip the terrain foremost due to thread pattern. Ambient temps have more influence on the terrain than on the tire. IOW, the terrain can be hot, dry, wet, or mushy, or frozen. The tire does not know the difference.
The thread pattern on street tires grip better on asphalt due to an increased contact patch. Rubber compound in street tires responds to increased temps due to impact stickability on asphalt surfaces, so hotter is better up to a point.
But all that said, the rubber does not know the difference in terms of low temps and cracking such as what was shown in those photos.
Those tires are either defective from the factory, or unbelievability old, but cold did not do that.
'00 BMW R1100RT, Gone away: 5 previous BMW's, 3 Honda's, 2 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius
basketcase is offline   Reply With Quote
Old 03-29-2013, 08:53 AM   #75296
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,921
........shu
That's kind of my point as well. In the teens here during the winter and no "broken" tires.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 03-29-2013, 08:56 AM   #75297
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,707
Question Raptor Petcock Fail ??? anyone seen this?
Gang
like others, Ifinally replaced the petcock on my IMS tank with the Yammie Raptor part. All was swell until recently. It leaks.
And, I can't really tell for certain where the fuel is getting by; I replaced the main gasket with a new one but it still leaks. Seems to be seeping around the seal of the valve itself but I am not sure.
if any of you have experience with this pls advise.
If I have to buy yet another petcock, which one will actually work??
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 03-29-2013, 09:02 AM   #75298
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,827
I had an issue with my IMS petcock on my old DR350SE. I contacted IMS and they sent me a new one for free. That said, they sell replacements for $20 (last time I checked). That's pretty cheap.
EDIT: I see you've switched to the Raptor unit so you've modified the tank. The IMS unit won't work now. Never mind.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 03-29-2013, 09:24 AM   #75299
ER70S-2
ER70S-2's Avatar
Oddometer: 6,274
Originally Posted by Zapp22 View Post
Gang
This might help, although Acerbis 5.3:
http://www.advrider.com/forums/showp...&postcount=108
P.S. I think someone recently said that a gasket cut from a tire tube would hold up to gasoline, in case you have to make a gasket with a larger surface area.
2013 WR250R
ER70S-2 screwed with this post 03-29-2013 at 09:30 AM
Old 03-29-2013, 09:53 AM   #75300
sandwash
sandwash's Avatar
Oddometer: 1,349
Ebay listing of the day:
http://www.ebay.com/itm/Dr650-oem-su...e85694&vxp=mtr
97dr650
sandwash is offline   Reply With Quote
Times are GMT -7.   It's 04:07 PM.
