Old 03-31-2013, 12:02 PM   #75346
refokus
Just Learning
refokus's Avatar
Oddometer: 2,377
Originally Posted by bross View Post
I think it's in here but running out the door... have a look.
http://www.advrider.com/forums/showthread.php?t=549433
Thanks bross!
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 03-31-2013, 03:10 PM   #75347
MATT0404
MATT0404's Avatar
Oddometer: 148
I was able to put around 200 miles on my new DR650 this weekend and had a great time doing so. I averaged 52 mpg over the weekend. This bike just might pay for itself being an alternative to driving my truck.
Two things I noticed. First, there seems to be hesitation on light throttle. Reading up on this it looks like it may be a lean condition due to the stock jetting. Is this something jetting the carb can take care of? I'm taking my time reading through the BST/carb threads.
Second, I'm going to need some luggage!
2009 F800GS
2007 XR650L
2001 Super Sherpa
MATT0404 is offline   Reply With Quote
Old 03-31-2013, 03:11 PM   #75348
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,335
What do you all think is the average mileage (road miles) out of a DR650 clutch cable?
I've got a 2002, so between corrosion and miles (or use), I'm strongly thinking about ordering another to carry with the bike.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 03-31-2013, 03:17 PM   #75349
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,459
I zip tie a spare cable right alongside the one in service. If it snaps, it's an easy and quick fix.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 03-31-2013, 03:52 PM   #75350
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,335
That is the plan, the question was only one of budgeting and time.
their motorcycles
RyanR
Old 03-31-2013, 05:04 PM   #75351
rogor
Oddometer: 38
Originally Posted by Krusty ... View Post
Until we choke on it ?
rogor is offline   Reply With Quote
Old 03-31-2013, 05:20 PM   #75352
ER70S-2
ER70S-2's Avatar
Oddometer: 6,099
I replaced my 2004 cable at 15k miles, but I left it in position. If the new one breaks all I have to do is switch ends.
Yes, it's on the wrong side of the bike, less cluttered and no exhaust pipe heat.
2004 DR650: 62,400 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 03-31-2013, 05:37 PM   #75353
shu
Oddometer: 996
I replaced mine at 34,000. It had worn halfway through one of the wire strands next to the cable barrel at the attachment point on the motor. Nowhere near breaking, but I'd carried a spare cable tied to it for 30,000 miles so I replaced it anyway.
.............shu
shu is offline   Reply With Quote
Old 03-31-2013, 05:56 PM   #75354
Kommando
Grumpy Young Man
Kommando's Avatar
Oddometer: 7,242
Welcome! This thread has all that info somewhere, but yes, TUNING your carb or swapping to a flat-slide pumper or EFI can reduce or eliminate hesitation and/or surging.
A common fix is to remove the snorkel and richen the needle and idle-mix screw. An adjustable needle and an extended screw make this very easy. www.Procycle.us sells kits for this whether you just remove the snorkel (Factory Pro) or go all out and open up the airbox (Procycle). The needles in these 2 kits have different tapers, BTW.
Kommando is offline   Reply With Quote
Old 03-31-2013, 06:20 PM   #75355
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,335
Thanks for the clutch cable experiences, gents.
I had a Kawasaki Vulcan with a really tough-to-pull clutch that had its replacement cable (so at least the second one that was ever on the bike) at under 20k miles. I'd say it was a mix of corrosion and tension.
Obviously the DR650 doesn't have the tension that other bike did. Still, getting that bike home with a broken clutch cable was a lesson learned. (the write-up story is here: http://www.vulcanforums.com/forums/s...ad.php?t=21711 )
their motorcycles
RyanR
Old 03-31-2013, 07:24 PM   #75356
Fred Garvin
Fred Garvin's Avatar
Oddometer: 217
spare clutch cable
All good ideas that have been around for years. In addition to the spare, you might want to cover the exposed ends with a dust/waterproof cover to keep the ends and the cable ready for installation.
Fred Garvin is offline   Reply With Quote
Old 03-31-2013, 07:53 PM   #75357
JagLite
JagLite's Avatar
Oddometer: 1,114
Question oil cooler hoses?
I reinstalled the oil cooler today after a repaint and had a bit of trouble figuring out which hose went where.
And which end attached to the engine, and which end attached to the cooler.
Was I looking at the manual wrong or do they have the lines reversed in the drawing?
I looked at my Clymer and Suzuki manuals and they both show it the same.
Seems to me that they show the short line on top instead of the long one.
It is at the end of the lubrication chapter.
I finally got it on right but installing the hoses and cooler shouldn't take an hour!
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 03-31-2013, 08:15 PM   #75358
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,459
After several failures doing things like this, i have learned to take a couple of pics before undoing things, the pics come in handy when going back together, you often think, oh that is no problem, it has to go back together just as easy as it came off, NOT.
Been there done that.
ChromeSux is offline   Reply With Quote
Old 03-31-2013, 08:44 PM   #75359
00Buck
dirt rules
00Buck's Avatar
Oddometer: 197
Ahhh, I love spring...
Mike
00Buck is offline   Reply With Quote
Old 03-31-2013, 09:42 PM   #75360
MATT0404
MATT0404's Avatar
Oddometer: 148
Thanks for the info! I'm going to get some more miles on the bike and see how it runs once I'm more familiar with it. As it stands now, I think the ProCycle kit is in my future.
2009 F800GS
2007 XR650L
2001 Super Sherpa
Times are GMT -7.   It's 01:55 AM.
