Old 03-31-2013, 10:16 PM   #75361
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,787
Originally Posted by sandwash View Post
Speaking of clutch cables:
Alright, alright - I'll order a new clutch cable this week.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 04-01-2013, 07:32 AM   #75362
procycle
procycle's Avatar
Oddometer: 2,403
This kind of failure is caused by the nubbin on the end of the cable not moving freely in the arm. This is a maintenance point that is often overlooked. Whenever you're washing the bike, changing the oil, etc. put a drop of lube on the cable nubbin. Do the lever end too.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle screwed with this post 04-01-2013 at 08:01 AM
procycle is offline   Reply With Quote
Old 04-01-2013, 07:44 AM   #75363
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,517
Originally Posted by Mambo Dave View Post
What do you all think is the average mileage (road miles) out of a DR650 clutch cable?
I've got a 2002, so between corrosion and miles (or use), I'm strongly thinking about ordering another to carry with the bike.
Put the new one on and carry the old one as a spare. That's what I did.
Couldn't believe how much easier the clutch pulled afterwards.
I do a lot of off road, so my mileage #'s won't apply.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 04-01-2013, 07:48 AM   #75364
sandwash
sandwash's Avatar
Oddometer: 1,366
I have about 28K on my 97 this happen around 23K, bought it with 13K.Good call on the drop of oil. Ya way smoother.
97dr650
sandwash is offline   Reply With Quote
Old 04-01-2013, 10:55 AM   #75365
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,787
Oil, or Grease?
I'd think grease should be better.
their motorcycles
RyanR
Old 04-01-2013, 11:31 AM   #75366
procycle
procycle's Avatar
Oddometer: 2,403
Oil, or Grease?
Anything is better than nothing. I usually use chain lube. When I'm lubing the chain I also go over the bike and add a little spritz on any moving part - cable ends, footpeg pivots, side stand pivot, lever pivots, brake pedal, folding shifter end, etc.
Old 04-01-2013, 02:19 PM   #75367
BergDonk
BergDonk's Avatar
Oddometer: 3,788
Originally Posted by procycle View Post
anything is better than nothing. I usually use chain lube. When i'm lubing the chain i also go over the bike and add a little spritz on any moving part - cable ends, footpeg pivots, side stand pivot, lever pivots, brake pedal, folding shifter end, etc.
+1
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 04-01-2013, 06:04 PM   #75368
ER70S-2
ER70S-2's Avatar
Oddometer: 6,880
Anything is better than nothing. I usually use chain lube. When I'm lubing the chain I also go over the bike and add a little spritz on any moving part ...................................- brake pedal, ............................. etc.
http://www.advrider.com/forums/showp...5&postcount=22
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 04-01-2013, 10:15 PM   #75369
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by eakins View Post
don't forget, you tape the ends shut so dirt does not enter the cable.
i've read using black wire shrink wrap is the shiz.
after shrinking, hit the finished end with a lighter, melt a bit and pinch it shut.
i'd say that is an technique from RTW riders who need a spare.
modern cables are built very well and maybe fray at the end to warn you.
i can't remember in this whole DR thread much being said about the Suzuki cable failing. if you're worried change it every 20-30K. it's hard to predict when one will fail, if ever.
PLUS ONE!!!
Did you read what Shu wrote above? Are you setting off for Mongolia and Africa soon?
You need to keep exposed clutch cable lightly oiled ... and clean. Make sure routing (at both ends) is not twisting or bending or abrading ... as this will wear cable.
Pull back the rubber sheath by the clutch lever, inspect cable. It won' lie ... you will see any fraying or wear. Mine is at 50K and I don't carry a spare on board because having ridden/serviced bikes my whole life ... I KNOW when a cable is going bad. They rarely just snap ... unless abused or tampered with. (another story) In the "BAD OLD DAYS" cables were JUNK and broke if you breathed on them. Thank God for the Japanese. I've not had a broken cable in decades.
Riding Bikes 101
Everyone should learn to ride their bike with no clutch. Its easy on the DR ... not so much on Gold Wing, BMWGS or Ninja 1000 You learn to be very creative at stops (slow racing anyone? ) Its a bit of a pain but certainly should not be a show stopper for anyone. PRACTICE! (motor will not be happy lugging but will survive fine)
Old 04-02-2013, 12:44 AM   #75370
rand0mlychrisUK
rand0mlychrisUK's Avatar
Oddometer: 28
Talking
Hi guys!
This is my 1996 DR650SE, got it a couple of weeks ago, so happy with it so far. Thinking of luggage solutions and working on a rack - already primed and drying.
rand0mlychrisUK is offline   Reply With Quote
Old 04-02-2013, 04:04 AM   #75371
thump!
thump!'s Avatar
Oddometer: 1,560
The old air-cooled VWs had a clutch cable. I once drove mine about 100 miles with a broken cable... Yeah, slow race.
thump! is offline   Reply With Quote
Old 04-02-2013, 05:06 AM   #75372
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,787
I thought about responding to Grifter with my stories of having driven or ridden with clutch cables/hydraulics gone, but figure he isn't worth responding to since I know my situation, I know where I live and what I ride through, and I know how much danger the last broken clutch cable put me in to ride back home.
Don't feel you have to respond to guys who reply solely based on their advantageous riding areas (especially those who never hit, or even totally avoid, true city traffic) or limited imaginations as to your circumstances. It's just not worth it.
their motorcycles
RyanR
Old 04-02-2013, 09:44 AM   #75373
ER70S-2
ER70S-2's Avatar
Oddometer: 6,880
You might know what your riding conditions and experience level is, but we don't. There are many new guys showing up, we try to give broad answers to help them learn from your questions too.
2013 WR250R
Old 04-02-2013, 09:48 AM   #75374
barko1
barko1
barko1's Avatar
Oddometer: 3,405
I like using Dupont Teflon Spray, dries so it doesn't grab any dirt.
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 04-02-2013, 09:50 AM   #75375
barko1
barko1
barko1's Avatar
Oddometer: 3,405
Originally Posted by rand0mlychrisUK View Post
Hi guys!
You got the good one with the purple frame. Purple = Power
Times are GMT -7.   It's 07:10 AM.
