Old 04-07-2013, 07:36 PM   #75541
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Originally Posted by acesandeights View Post
So, what's the best off road shock for the DR, a rider @ 200 lbs that rides moderately aggressive off road?
A well set up Ohlins.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 04-07-2013, 07:41 PM   #75542
BergDonk
BergDonk's Avatar
Oddometer: 3,843
Works great for me, haven't tried better, but not tried the popular Cogent or Ricor, or Racetech upgrades either. Ohlins just work, when setup.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 04-07-2013, 09:19 PM   #75543
JagLite
JagLite's Avatar
Oddometer: 1,393
Cool2 engine on ebay
Anyone looking for a complete engine?
http://www.ebay.com/itm/1999-DR650-D...e836e2&vxp=mtr
Excellent price I think.
If shipping to Alaska wasn't so expensive I would already have bought it!
But, now I will give you a chance
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is online now   Reply With Quote
Old 04-08-2013, 02:04 AM   #75544
Nullarbor63
Test Pilot
Nullarbor63's Avatar
Oddometer: 23
Lowering
I did the 17inch wheels several years back, and my wife (5'7") rode it through the Snowy Mountains when we holidayed there. I made suspension linkages (the aluminium 'dogbones' which connect the shock pivot to the swingarm) which are a half inch longer than stock. This lowers the rear wheel about inch and three quarters, and she has no trouble getting her feet down either side. There's a company over there that makes threaded, adjustable linkages. It's a two bolt solution, and you can always take it off if you don't like it. Cheers.
Originally Posted by frecks View Post
Finally finished my engine rebuild! I hope to get it in the bike tomorrow and see if she runs. I will be pretty excited to have it back in service after a year and a half, so hopefully all goes well.
The DR will see occasional use by me on the trails, but that won't be it's main use. It will mostly be used as a first bike for my girlfriend who's wanted a motorcycle for a couple years now. She's already taken the MSF course and got her endorsement. The DR makes a great bike to learn on so I feel it will do well in this role, with one exception - seat height. If I'm not mistaken, the DR has a stock seat height of 34.1". My girlfriend is 5'4" with a 30" inseam. I've got the bike on 17" supermoto wheels, which effectively lowered the front end by 2". I'm going to try lowering the rear by moving the rear shock bolt to the other hole as I've read can be done. This should have the added benefit of fixing the steering geometry. Switching to the 17" wheels without lowering the rear at all changed the rake/trail enough to cause a bit of a wobble at 80+, so hopefully that disappears.
The question I have is this: After I lower the rear as mentioned above, my math tells me that the bike will still be 2" too tall for her. What are your recommendations for dropping an extra 2" in seat height without destroying the steering geometry or causing the tires to hit the fenders when the suspension compresses? Anything I do has to be reversible and ideally wouldn't be too expensive. I will of course have her give it a try after I lower the rear to see if that is actually enough, but I suspect it won't be.
I appreciate the advice [if anyone actually bothered to read this long-winded post] & I have to say, this thread is great. I've learned a ton from reading this stuff.
Nullarbor63 is offline   Reply With Quote
Old 04-08-2013, 07:57 AM   #75545
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,875
Originally Posted by Emmbeedee View Post
Possible, but it wasn't too tight on my watch. I never run chains too tight.
Actually this came out when I finally got around to taking the roller off. I turned the bolt, and it's clear that the attachment was still strong enough so that I had to use as much pressure on the wrench as it would normally take to loosen the bolt, but that pulled the roller and mount off. So it could have happened at any time in the past.
The bike is a '96 which I bought a few years ago.
Theres a trick you can do,take the shock off and set the chain a little snug,then lower the back end of the bike down and watch where the chain goes up by the upper roller.
It will try to pull that roller out of the frame.
If the chain isnt tight it wont try to pull that roller out of the frame.
The notches in the snail cam chain adjusters are a big adjustment jump between notches so guys try to err on the side of tightness thinking its better then looseness.
So yeah somebody most likely ran it too tight before you got it.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-08-2013, 08:00 AM   #75546
Foot dragger
singletracker
Oddometer: 12,875
Ohlin's are nice if you dont mind spending a chunk of change,the Race-Tech gold valve and spring on my DR shock work fine.. after two revalves by the local suspension wizard,stock Race-Tech valving felt like a Supercross shock settup.
Old 04-08-2013, 08:11 AM   #75547
TRAVELGUY
Old Traveler
Oddometer: 701
Upper chain roller
Guys I think most of you are forgetting something about tearing out the upper chain roller. Whether the chain is adjusted too tight or not when you are under strong acceleration and the rear shock is under heavy compression the chain is going to push against the upper roller with a lot of force.
TravelGuy
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 04-08-2013, 09:27 AM   #75548
Rumlover
Ed
Oddometer: 707
upper roller
You might be able to adjust the chain loose enough to avoid problems with the upper roller if you are not an overly aggressive dirt rider--- but why?
I have never seen ONE report of a problem encountered involving a chain mishap because the upper roller was removed on a stock suspension, not one.
But if it makes you feel better having it on, go for it.
Rumlover is offline   Reply With Quote
Old 04-08-2013, 09:37 AM   #75549
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,100
Local pick-up only, in Maryland.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 04-08-2013, 10:13 AM   #75550
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by procycle View Post
Yeah, Rick and I think this will be a good fit.
The plan is for ProCycle to build up enough inventory of 'Cogent Built' shocks to be able to sell them on an exchange basis rather than the old way of sending a shock to Cogent and having the bike down for a couple weeks. It also should be easier for Rick as he will be running ProCycle shocks in batches without having to coordinate the anodizing with several separate shock customers.
Will this partnership allow for more custom damping rates? Swapping springs should not be a problem ... but revising rebound and compression to suit a wide variety of riders may not be a "one size, fits all" solution?
I see Rick offers many options like Nitride coating and lots more ... can these "extras" be offered on shocks Pro Cycle keep in stock?
Old 04-08-2013, 10:28 AM   #75551
ER70S-2
ER70S-2's Avatar
Oddometer: 7,019
TravelGuy
I'm on this side of the theoretical fence.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 04-08-2013, 12:13 PM   #75552
gjcarving
Oddometer: 119
Just ordered two sets of Warp 9 levers for our DRs. Since my wife and I are selling our BMW F650 and 800GS, it just makes sense to farkle the bikes we want to keep.
Long live simple bikes!
Just out of curiosity, why are you getting rid of the f800gs. It has been one of the bikes I have been thinking about in the near future and like to hear owner opinions about them. Positive and Negative. Thanks!
gjcarving is offline   Reply With Quote
Old 04-08-2013, 01:04 PM   #75553
bross
Where we riding to?
bross's Avatar
Oddometer: 4,641
Pm sent regards F800.
Old 04-08-2013, 02:25 PM   #75554
peng-a-win
Oddometer: 2
Throttle cable bracket?
I am in real need of help, i had my bike apart to install the pro-cycle jet kit and my wifes care came in with some major problems. and i had to drop everything to get her car back up and running. somewhere in the confusion i lost the throttle cable bracket for the (stock) carb. Suzuki has no part number and Mikuni will only sell as part of the whole carb. Does anyone know where a replacement can be found or a way to make something work safely. Any help would be greatly appreciated.
peng-a-win is offline   Reply With Quote
Old 04-08-2013, 03:09 PM   #75555
shu
Oddometer: 1,058
Do you mean the bracket that is attached to the top of the carb with 2 screws?
If so, PM me. I have a stock carb (2008) that is not in use. I can take the bracket off and send it to you. Where are you located?
..............shu
shu is offline   Reply With Quote
Times are GMT -7.   It's 01:14 PM.
