Old 04-09-2013, 07:51 PM   #75616
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Emmbeedee View Post
Thanks for the advice. You're right, the carb does look filthy. I had hoped to not have to take the carb off but I just may have to.
Which Warm N Safe jacket do you have? Ours are 90 watts at full power. My wife and I have one of each, on separate bikes, of course. Not two 90 watt jackets on one bike.
Yea, for sure pull the Carb off and get to know it. Much easier in the end.
Warm & Safe
Mine is an old 90 Watt version also. I got it to review for a magazine years ago. It's very well made but heat wise, sub standard compared to my 15 year old Gerbing. Yep! And the Gerbing only draws 77 Watts.
Of course BOTH Gerbing and Warm & Safe (now sold through First Gear) are now much better, put out more heat and draw less current.
The latest Gerbing is quite efficient. But lots of heated gear options out there. Be careful running your W & S at full power or you may end up with a dead battery. (HID headlight recommended) Run the Troller at about 75% ... that helps too.
Old 04-09-2013, 07:55 PM   #75617
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,438
Originally Posted by badweatherbiker View Post
Thanks for all the kind words guys everything is in Gods hands.
I will miss the DR and there is no doubt I will be on another one it is a fine bike
I'm not going anywhere I have grown quite fond of those DR's and thanks to you guys I know a good bit about them.
Yeah, don't be a stranger. We're a family here and just cuz you don't have a DR at the time, you can still participate.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 04-09-2013, 08:52 PM   #75618
badweatherbiker
badweatherbiker's Avatar
Oddometer: 706
I'll drink to that!
1996 Kawasaki KZ1000P (currently being rebuilt)
World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements!
Earn extra income, become a distributor or just purchase:
Advocare products-www.advocare.com/12084065
badweatherbiker is offline   Reply With Quote
Old 04-10-2013, 05:21 AM   #75619
Sleepy John
Grumpy Adventurer
Sleepy John's Avatar
Oddometer: 3,730
Check that the little fuel strainer in the fuel intake tube on the carb is clear . Easy to miss.
Sleepy John
'10 R1200GSA Big Pig, '10 DR650SE Piglet
Don't shoot... It's only me!
Women and cats will do as they please, and men and dogs should relax and get used to the idea.
Sleepy John is offline   Reply With Quote
Old 04-10-2013, 05:31 AM   #75620
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
It was the first thing I checked. It's clean, or at least it was last Sunday.
But I just remembered one more weird thing that happened on my ride on Monday: even though I filled the tank with fresh fuel in the morning, at about 150 km, the bike displayed all the symptoms of having run out of gas as the motor quit completely, and wouldn't fire up again until I hit reserve on my Pingle fuel tap.
And when I filled up, it only took 10 liters to fill my IMS tank so it was still half full.
So I think the next step is to check out the fuel tap.
Emmbeedee is online now   Reply With Quote
Old 04-10-2013, 05:38 AM   #75621
ChuckV
Itinerant Settler
ChuckV's Avatar
Oddometer: 56
Thumb I bought badweatherbiker's DR650
Well guys it was fun while it lasted but I sold the DR to an inmate this weekend. It was alot of fun while I had her but I took a beating on my commute with the Florida thunderstorms and wind recently.
Thanks for all the help and conversation and I am sure the new owner will be checking in now and then
I'm the new owner of badweatherbiker's DR650. I can't wait to pick it up and ride once again with my good friends in the panhandle and beyond.
It has been way too long!
Chuck
Seat time is my pew.
ChuckV is offline   Reply With Quote
Old 04-10-2013, 05:49 AM   #75622
TrophyHunter
Oddometer: 2,251
Welcome. Look forward to some stories to continue it's legacy. Good to hear it went to an enthusiast.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 04-10-2013, 06:35 AM   #75623
shu
Oddometer: 1,040
...and the venting in the gas cap. Do you have the locking cap? The vent gets plugged in mine which at some point makes a vacuum in the tank and the float bowl won't fill fast enough to keep the motor happy.
(Procycle advises taking the cap apart and poking a hole with an icepick in the rubber piece.)
Originally Posted by procycle
The locking cap has a small rubber disk inside it that acts as a one way valve so fuel doesn't splash out through the internal vent. You can access the disk by removing the rubber gasket and unscrewing the green plastic piece inside the cap. Take a sharp pointed pick and poke a tiny hole in the disk and you will solve the venting issues. The hole should be barely more than a pinhole. If you make the hole too big you might have a small amount of fuel spillage in a tipover.
..............shu
shu is offline   Reply With Quote
Old 04-10-2013, 06:55 AM   #75624
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,863
Originally Posted by GRinCR View Post
Hi all
I have one of the old school models and have fount the book says DO NOT use lapping compound when seating the valves. The locals here find this strange and insist they seat them with lapping compound.
Can anyone shed light on this? Will it f*ck the whole deal if lapping compund is used?
Cheers
That book is written by the people who built the bike and the valves and valve seats,at least if its a factory manual.
On almost all newer 4 strokes the valves arent lapped in they are simply installed and checked for seal. If the old valve is worn down to a sharp edge then you gotta see what shape the valve seat is in.
Old school mechanics will want to lap the valves regardless of what the maker of said valves says. It wont hurt but they dont need it.
They are so hard not much will happen lapping them.
I put new valves in my 01 DRZe a while ago,the old ones still looked good,new valves were 26.00 each so for the heck of it new ones were installed,they sealed perfect with no lapping.
DRZ/DR valves are simple steel valves,on newer tricker 4 strokes they have hard coatings/titanium valves maybe that cost 100's of dollars.
1 or two adjustments and they are toast,the hard coating is worn through and its time to replace them.
DR's valves last a long time and are simple good quality valves.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-10-2013, 08:29 AM   #75625
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,003
Originally Posted by skysailor
So, my poor DR has sat in the garage all winter. It'll start, then die after about three seconds. Used fuel stabilizer when I put it to bed. Ideas?
Lyle
Don't let it sit all winter without starting it? In all seriousness, I use fuel stabilizer (or race gas) and simply start the bike every second or third weekend thru the winter. Let it run for 5-10 minutes (to generate some temperature) and then shut it off. I've never had any trouble come Spring.
Your issue might be a partially clogged pilot jet.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 04-10-2013, 08:43 AM   #75626
Archery720
Archery720's Avatar
Oddometer: 1
Newbie
Just stopping in to say hello. Name is Andy, I just bought a 2005 DR650 and been surfing through this thread, picking up tips and tricks. I have had KLR 250's prior to this DR. I have only rode about 1/4 mile due to weather and waiting on gasket to fix my screwup, but that 1/4 mile was awesome! Look forward to getting to know all of you.
Archery720 is offline   Reply With Quote
Old 04-10-2013, 08:51 AM   #75627
wee-twin
Oddometer: 199
Welcome Andy. When you click on thumpers at the top there is a stick: bike specific, click on that and then go to dr650. Tons on info.
Bill
wee-twin is offline   Reply With Quote
Old 04-10-2013, 09:47 AM   #75628
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
..............shu
I had the locking cap until last Fall when the gasket started leaking, so I put a standard IMS cap on it. The tap flows at a verified 500 ml per 15 seconds, so it's not the tap itself at fault. I'm thinking it could possibly be the fuel line being constricted since the carb still has the inlet pipe going straight up, so the line is fairly short from the Pingel tap to the carb, and has a nasty twist which could be restricting the flow.
I'm going to try to make that line up better but the last time I attempted to turn the inlet pipe, it failed to move no matter what I tried.
Old 04-10-2013, 10:11 AM   #75629
Minsk99
Oddometer: 56
Did you instal an inline fuel filter between the Pingel and the inlet pipe? Might want to check to see if it needs replacing.
Minsk99 is offline   Reply With Quote
Old 04-10-2013, 10:48 AM   #75630
ER70S-2
ER70S-2's Avatar
Oddometer: 6,780
Would you mind posting a photo of that nasty twist, just for the curious? Be sure to understand, the Monday morning quarterbacks are probably going to question your routing; even though you had no choice in the alignment.
My Acerbis 5.3 passed the first 'run it until completely empty' test. But adding the gallon I had, wouldn't flow thru(sic) the uphill bend. I had trouble getting it restarted. This was my first exposure to the situation, next time I'll use the fuel enrichment immediately (hi Derek ) (it was completely warmed up and I thought it would fire right up). Yes, the petcock was set to PRI while I put my helmet and gloves back on to refill the float bowl.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Times are GMT -7.   It's 04:53 AM.
