Old 04-10-2013, 12:16 PM   #75631
ER70S-2
ER70S-2's Avatar
Oddometer: 7,289
Originally Posted by wayno View Post
Tks for the answer, any other opinions
Is the skid plate made for the DR, or another bike? Can you post pics of both sides?
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 04-10-2013, 01:02 PM   #75632
warp9man
Gravel in my Travel
warp9man's Avatar
Oddometer: 591
Originally Posted by JB650 View Post
Did some searching and can't seem to find a real answer so I was hoping some others could give me a hand. I installed emulators and new springs in my forks and I now notice a clunking when holding the front brake and rocking the bike back and forth. At first I thought perhaps the steering head bearings might be loose but I don't think that is it. If I put the front wheel against the wall and push up and down the fork will stroke nice and quiet. It seems like the noise is coming from slight front caliper movement and maybe I just never noticed before. Just curious if any others notice this sound. Really appreciate any assistance with this so I can stop pulling things apart trying to find it. Thanks.
Hey JB650, chances are good its the front rotor thats knocking on you. the dr650 has a 2 peice front rotor and the rivets that join the inner and out plates wear just slightly and youll feel the knock/play when you grab the brakes. your in no danger unless its really bad its just annoying.
ride safe
warp9man is offline   Reply With Quote
Old 04-10-2013, 01:22 PM   #75633
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,974
Originally Posted by ER70S-2 View Post
Would you mind posting a photo of that nasty twist, just for the curious? Be sure to understand, the Monday morning quarterbacks are probably going to question your routing; even though you had no choice in the alignment.
It's not pretty, but this is what I put on it this afternoon. Some clear line which loops around and back to the carb. I have the line tied to the fuel tap so it doesn't melt on the engine. This is more of an experiment than a finished setup. I hate looped lines, but I couldn't see any other way to do it right now. For the moment, there's no filter in the line, aside from the one on the Pingle tap inlet.
I rode about 30 km and the bike didn't hiccup even once, so that's a good sign.
I also put new spark plugs in and blew all the passageways out of the carb so it's hard to tell which change is responsible.
Old 04-10-2013, 01:37 PM   #75634
ER70S-2
ER70S-2's Avatar
Oddometer: 7,289
Thanks for the photo.
You might notice an air bubble in the high spot but that doesn't mean fuel won't flow. I used clear filters on my dirt bikes (long ago), and they always had an air bubble. It made me knutz.
It looks like the IMS petcock is about 1-1/2" farther back than the Acerbis. Kudos for experimenting. My retirement buddy will starve to death before trying anything new or different. Narrow minded old fuddy. That's why I asked for the pic, always looking for new ideas, whether I use them or not.
2013 WR250R
Old 04-10-2013, 02:32 PM   #75635
Graniteone
3,2,1...Beer me!
Graniteone's Avatar
Oddometer: 466
I picked up a 2008 earlier this week.
Here is what I have on order already. What else should I get? I want a good all a rounder. Desert, mountains, some touring. Carb up grade? Pipes? I felt like suspension needed the most attention right away.
Stock Body Rebuild w/Cogent SSA-Stock DR Shock Body Rebuilt with Cogent Shock Shaft Assembly
7.5 Rear Spring
CNC Collar and Thrust Bearing
RSW Fork Brace
Oil Filter Magnet
Acerbis 5.3 Gal. Tank - White
Front Signal Relocation Kit
1 Inch Handlebar Risers
Clymer Manual DR650
Graniteone is online now   Reply With Quote
Old 04-10-2013, 02:34 PM   #75636
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,782
speaking of IMS tank with gravity-feed fuel valves: one positive thing I learnt is that, at least on the IMS rigs of last 4 years or so, the cap fits tightly enough that if you have a good fitting vent hose on it, the whole thing will hold pressure. I found that when I got the 'air bubble' fuel flow restriction that many of you have experienced, if you blow in that hose and hold pressure with a thumb or finger, it will start. trust me. I've been 'stranded' in several spots and had this happen, check the tank and there wwas fuel in it but not enough pressure. did this, turned the starter over and let it spin a couple seconds and she fired up.
It was the first thing I checked. It's clean, or at least it was last Sunday.
But I just remembered one more weird thing that happened on my ride on Monday: even though I filled the tank with fresh fuel in the morning, at about 150 km, the bike displayed all the symptoms of having run out of gas as the motor quit completely, and wouldn't fire up again until I hit reserve on my Pingle fuel tap.
And when I filled up, it only took 10 liters to fill my IMS tank so it was still half full.
So I think the next step is to check out the fuel tap.
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 04-10-2013, 02:42 PM   #75637
JB650
Oddometer: 23
ride safe
Thanks warp9man. I have been looking at it and it is definitely the brake. Caliper or rotor. With the wheel against the wall the forks stroke real nice and smooth with no noise. I can feel it in the brake caliper also when holding the front brake. So I'm going to just ignore it. Was hoping to ride soon but 30 degrees and freezing rain. Nothing like a big old ice storm in April. Thanks for the response warp9man.
JB650 is offline   Reply With Quote
Old 04-10-2013, 03:46 PM   #75638
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
7.5 Rear Spring
RSW Fork Brace
Oil Filter Magnet
Clymer Manual DR650
Fork braces get mixed reviews. Most find the front fork springs way too soft, and swap springs, then add emulators from RaceTech or Ricor Intiminators.
Have you done any distance yet? Very often the stock seat is the first thing upgraded. Just be careful when you fling that Suzuki seat away, not to hit anyone with it. The edges are sharp!
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 04-10-2013, 04:50 PM   #75639
Graniteone
3,2,1...Beer me!
Graniteone's Avatar
Oddometer: 466
This bike came with a Sargent seat and the stock seat. I think a fork brace makes sense. We shall see.
Old 04-10-2013, 05:35 PM   #75640
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,974
Yeah, it's all really tight in there with the fittings in their current positions. I think I'm going to look for a couple of elbows to make two short lengths of hose and a filter fit in the space and have as clear a run as possible.
One of these, perhaps:
And one of these, too.
Old 04-10-2013, 05:59 PM   #75641
FastEddie454
Oddometer: 1
New 2013 DR650
Hey everyone, long time reader of advrider first time poster. Well I did my shopping around for about a year or so while I rode my old beat up drz400. sold it and finally bought a New 2013 DR650 last saturday. I absolutely love it, it is everything I expected and I got a killer deal. Just installed the tail tidy kit from procycle and new gun metal skid plate from procycle, looks awsome. Also got some case savers to put on. I appreciate all the great advice I have read on this forum it helped me decide which bike to go with. I look forward to posting some awsome ride pictures once I get her broken in and I can start letting loose. I would post a picture of it with the new skid plate etc. but I'm not sure how. You have to have a photobucket account or the likes?
FastEddie454 is offline   Reply With Quote
Old 04-10-2013, 06:32 PM   #75642
wayno
wayno's Avatar
Oddometer: 6,883
A straight line is a PITA so will try ur way thanks
RIDE SAFE
wayno is offline   Reply With Quote
Old 04-10-2013, 06:53 PM   #75643
wayno
wayno's Avatar
Oddometer: 6,883
Yes made for DR650...
RIDE SAFE
Old 04-10-2013, 08:27 PM   #75644
TrophyHunter
Oddometer: 2,312
FastEddy - congrats and welcome aboard! Ride it a bit and figure out if there's anything you want to change. It's nice to get something new for yourself once in a while.
Graniteone - sounds like some personalizing. Very nice. As mentioned, get a feel for the front end and keep the upgrades in mind. The shock changes may affect the way the front works for you.
Wayno - looks fine IMO. Mine is closer than that - I have the AMP guard on there too. I'd rather have it closer than further away. Plenty of protection and not sticking out there to take a bite outta me while I ride it into the ground.
'07 WR450 2013 HD Road King '15 Tiger 800 XCx
TrophyHunter is offline   Reply With Quote
Old 04-10-2013, 08:34 PM   #75645
vicster
Oddometer: 1,138
What I did was remove the stock carb nipple and replaced it with a straight one so I could just run the fuel line straight to the carb. And for a filter I just use the stock one. Oh the horror! But it's dead easy to check and clean with my arrangement.
vicster is online now   Reply With Quote
Times are GMT -7.   It's 06:55 AM.
