Old 04-12-2013, 06:48 AM   #75691
mattomachu
Oddometer: 8
DR650 Magneto bolt...right or left hand threads?
Just bought a 2003 DR650 It has 6000 miles on the dial. It wasn't running when I bought it last week. I put a new battery in and it fired up. I don't think the valves have been adjusted since the first owner. This is where the chaos begins. The small cover on the left side with the allen key was stripped into a complete circle. I tried to use a chisel and it wouldn't budge. I ended up taking the entire side cover off. I then drilled the little cover and installed some bolts to to jimmy the thing off. Finally got the thing off, but in the process the starter clutch gears came out and the two washers fell out. I tried to catch them, but they eventually slid down in the bottom of the engine. So I don't think it's a good idea to leave them down near the oil drain...I tried to use a few different things to no avail to try to get them out.
If I remove the magneto I'm almost positive that I can use a small pick to retrieve them. Has anyone else had to deal with this chaos? Which direction are the threads on the initial 17mm nut? I tried both directions w/o a budge. Anyone have a lead on a magneto puller? I'll pay for shipping both ways...
mattomachu is offline   Reply With Quote
Old 04-12-2013, 07:15 AM   #75692
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Does anybody have the Jesse's midpipe for a Hayabusa muffler that they're looking to sell? Standard header size
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 04-12-2013, 08:02 AM   #75693
sandwash
sandwash's Avatar
Oddometer: 1,358
Try kientech or Two brother's wesite
97dr650
sandwash is offline   Reply With Quote
Old 04-12-2013, 08:09 AM   #75694
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,677
Originally Posted by barko1 View Post
I'd try inserting a phillips into the tube, as far in and as big around as will fit, then push the handle to turn it. I think that lessens any chance of deforming anything, YMMV
I was looking around for something which would fit nicely in there when I thought I'd give one last try to getting a hose to fit without all that unpleasant carb removal/heating/twisting/swearing/breaking/cursing/searching for another carb which would have been inevitable, considering my luck so far this week...
So I think I'm finally happy with this:
I think the most important part with making this line work is to not have the hose too long. When I first tried it, the bend at the top of the carb connection was quite tight, and it was solely because the hose was too long and needed to make more of a tight curve to go back down towards the Pingel.
The hose I ended up with is probably only 3" long, but it has no tight bends.
Yay!
Old 04-12-2013, 08:13 AM   #75695
thump!
thump!'s Avatar
Oddometer: 1,444
Yeah, people just love to tighten that plug to the point it can't be removed. There's an o-ring there. It just needs to be snug. It doesn't have to be tightened down like the drain plug on your grandfather's '49 Ford. Mine was like yours when I got it but I was able to remove it with a hammer and punch.
FWIW, while it makes the task easier, it is possible to adjust the valves without removing that plug. It's a single cylinder engine after all. You only have to find TDC once.
Good luck fishing out the parts. If it were mine, I'd try using a magnet attached to a flexible wire.
thump! is offline   Reply With Quote
Old 04-12-2013, 08:22 AM   #75696
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,237
Tanks and carbs
I have an Acerbis tank and a FCR on my bike. I can run my bike to literally dry and have to push it. How do I know? As I was trying to test how far I could go on a tank, and was on reserve not on (dumb ass that am I). Luckily i was able to lay the bike down to get the fuel to the left side, got another mile or so and it died about 100 yards from a gas station.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 04-12-2013, 09:08 AM   #75697
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,237
Tanks and carbs
Old 04-12-2013, 09:41 AM   #75698
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,354
It is always a good reminder to people to get their bike fully warmed up before trying to remove that plug. When the engine is warm, it comes out easily...
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 04-12-2013, 09:46 AM   #75699
ER70S-2
ER70S-2's Avatar
Oddometer: 6,469
Yay!
That looks pretty damn good. And you were able to do it without turning the carb fitting.
Could you put that in Krusty's DR Index? It seems most other solutions are under "Fuel", not "Carb/Intake". (He lists tanks, petcocks and filters in the first post)
http://www.advrider.com/forums/showthread.php?t=635647
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 04-12-2013, 10:15 AM   #75700
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,677
Be happy to add it...
Old 04-12-2013, 10:16 AM   #75701
ER70S-2
ER70S-2's Avatar
Oddometer: 6,469
2013 WR250R
Old 04-12-2013, 10:26 AM   #75702
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,677
How does this look?
Old 04-12-2013, 10:32 AM   #75703
ER70S-2
ER70S-2's Avatar
Oddometer: 6,469
That worked so well for you that I'm going to shorten mine (a little at a time), if the weather warms for more than one day inna row. But right now, one day warm spells are for riding, like tomorrow.
2013 WR250R
Old 04-12-2013, 10:42 AM   #75704
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,677
Isn't that what cold days are for? To work on the bike so you can ride on warm days? We don't have heat in the shed but short spells work ok. Then I come back in to warm up by the wood stove.
Old 04-12-2013, 10:46 AM   #75705
mattomachu
Oddometer: 8
Does anyone know if I take the clutch side cover off if it will be easier to fish that washer out that fell into the left side? I know that the two halves are connected with some oil ports in the bottom of the engine. I can't get a wire/magnet down on the left side w/o removing the magneto. I can't find a puller locally.
Times are GMT -7.   It's 10:42 PM.
