Old 04-13-2013, 05:06 AM   #75736
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,861
Just wondering how long plastic tanks like the IMS last... I noticed a note in the workshop manual which came with my bike when I bought it in 2010 about the IMS being added to the bike in 1998, so that makes it about 15 years old, so I'm wondering if it's getting brittle or what, from having had fuel in it all that time.
Old 04-13-2013, 07:39 AM   #75737
maynard911
Oddometer: 142
My guess is that sun exposure is the determining factor, where I am at high altitude in Arizona with 320 or so sunny days a year unprotected plastic does not last long. Generally speaking clear is the worst because the uv is able to penetrate the full depth, solid non transparent colors last longer.
Maynard " Youth is fleeting, immaturity is forever"
maynard911 is offline   Reply With Quote
Old 04-13-2013, 07:59 AM   #75738
maynard911
Oddometer: 142
Originally Posted by DockingPilot View Post
I have a newish left over K60 from my F800 but it's a 140. Anyone know if a 140 can be shoe horned in on the DR or is it too wide ?
Frank
It depends on what you mean by "too wide".
No it is not too wide to fit in the swingarm, the motard types are running 150's.
Yes it is too wide for the stock rim. Google 'motorcycle tire fitment chart. A 140 tire is designed to go on a 3.5" rim, the DR has a 2.5" rim.
So you can use it but understand that the profile will not be what the manufacturer had in mind, the sides of the contact patch will be pulled up and the center more rounded.
Old 04-13-2013, 09:28 AM   #75739
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,849
Understood, ok, Nix that idea.
thanks
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is online now   Reply With Quote
Old 04-13-2013, 09:53 AM   #75740
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
This is true. Being a cheapskate I've run Odd sized tires on my DR and other bikes. With the narrow DR rim the tire profile will be "squeezed", distorting the profile from ideal. Could make for some "weird" handling and wear patterns.
I ran out of tire in Mexico once ... mounted a 140 on my then KLR .... very scary handling ... but got me home.
I ran a 140 section MT-60 Pirelli on my DR years ago ... not so good.
Old 04-13-2013, 10:14 AM   #75741
ER70S-2
ER70S-2's Avatar
Oddometer: 7,022
Originally Posted by Rainier_runner View Post
Looking good for her age!
All-American
Awesome
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 04-13-2013, 10:45 AM   #75742
frecks
frecks's Avatar
Oddometer: 246
This may sound dumb, but I'm struggling to get my newly rebuilt engine back in the frame. Does anyone have any tips on how to squeeze it back in? If I remember correctly, I think I already had the clutch and clutch cover off when I took the engine out, which gave it some extra clearance. I already put that stuff back on, but I figure there must be a way to get it in without taking that stuff off again.
frecks is offline   Reply With Quote
Old 04-13-2013, 10:59 AM   #75743
Davis53
Oddometer: 575
If you put the motorcycle on a MX stand so it is upright and squeeze the engine back in on the throttle side is what works for me. You have to remove the foot brake and master cylinder but it worked for me. It is a heavy engine get someone to help you from the other side.
Davis53 is offline   Reply With Quote
Old 04-13-2013, 11:08 AM   #75744
frecks
frecks's Avatar
Oddometer: 246
That's what I had tried, except I just had the bike on the kickstand. I wouldn't have though that having it upright would make that big of a difference, but maybe it will make enough. I don't have an mx stand, so I'll try to get it up on a milk crate or something similar. Thanks for the idea to make the bike sit upright.
Old 04-13-2013, 12:03 PM   #75745
Burnt Toast
Slingshot: engaged.
Oddometer: 225
WASHER GONE!
Several posts around here on the NSU, but yes you'll have to make/buy some sort of tool to get that thing out. I have a set of small right-angle tools with inserts that I used. A phillips bit held by vise-grips has also been effective for some folks.
Originally Posted by mattomachu View Post
Yeah.. Thanks everyone for your input. The clutch side was pretty easy to fish the washer out. I'm now in the process of replacing the NSU screws. how does one get the top screw out. I'm thinking right handle phillips similar to an allen key? Here is a pick of that darn washer.
Burnt Toast is offline   Reply With Quote
Old 04-13-2013, 12:31 PM   #75746
JagLite
JagLite's Avatar
Oddometer: 1,394
Pissed Engine in
Not a dumb question at all as many of us have struggled to get it back in.
First thing, the shop manual is wrong.
It says to put it in from the left side (shifter side).
That will waste a lot of your time like it did for me.
Finally I realized the picture (drawing?) they show is NOT the '96+ bike frame.
Our bikes have a removable engine mount on the RIGHT side, not the left.
OK, next thing to know is it will only go in by slightly twisting or rotating it to get the bump on the front of the engine case in between the frame rails.
Once you get that started in you adjust the engine so it will squeeze into position.
Many have found that laying the engine on its right side and then lowering the frame down over it was easier to do.
I used my engine hoist and lowered the engine on its side down into the newly painted frame so that I wasn't trying to support the 100+ lbs engine and work it into the frame.
It will go in fine with the side case covers on, but no carby of course.
It can certainly be done with the bike vertical or on the kick stand.
The problem is that if you are trying to support the engine weight AND wiggle it around you may injure your back.
Or your hands as they get trapped between engine and frame.
Or your sanity since you know it came out, but???!!!
I stick the front engine mount plate and bolts in as soon as I can as that holds it in one plane while lining up the other bolts.
First time is often painful and frustrating.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 04-13-2013, 01:11 PM   #75747
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,861
Good point, the sun factor. Mine has been inside a garage most of the time unless it's being ridden. It doesn't look or feel brittle, but I was just curious.
Old 04-13-2013, 01:59 PM   #75748
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,574
Originally Posted by Burnt Toast View Post
WASHER GONE!
maybe: http://www.sears.com/craftsman-offse..._tnt=39869:4:0
Enlarge Image
I have one, but I don't know if it works because I have Allen head cap screws on the NSU. I use a special home cut-down allen key to do mine.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 04-13-2013, 06:49 PM   #75749
ER70S-2
ER70S-2's Avatar
Oddometer: 7,022
JagLite:
Nice write-up.
2013 WR250R
Old 04-13-2013, 08:11 PM   #75750
blackcap
blackcap's Avatar
Oddometer: 548
and next time put the bottom end in the frame before you bolt the top end on. gives a lot more wiggle room and a lot less weight.
"One must die sometime and to die with ones boots on is very noble" - Carl Stearns Clancy, first RTW motorcycle, 1912-13
Australia to Iceland on a DR650 http://oztoice.wordpress.com
and facebook https://www.facebook.com/oztoice
blackcap is offline   Reply With Quote
Times are GMT -7.   It's 04:53 PM.
