Old 04-14-2013, 10:10 AM   #75766
deathu
deathu's Avatar
Oddometer: 77
reinstalling the clutch
Hi,
As part of my 1998 DR650SE rebuild, I got a complete new clutch set, and I have the following issue with it's installation.
It seems that up to this point, the concaved washer (or judder spring) was installed with the wrong orientation, and it left a deep mark on the first driven plate:
Now as per the service manual, I try to install the replacement plates. First goes the washer seat:
Then the concave washer (judder spring), with the orientation as per the service manual, with the raised edge towards the inside of the sleeve hub:
then the first (thicker) driven plate:
At this point I am unable to install the stopper ring, because as you can see in the above image it's channel is completely "buried" under the clutch plate. The judder spring seems very difficult to compress, I think would require some special tools but the manual doesn't mention anything about this. Is there some trick to do this installation? Is the concaved washer orientation stated in the service manual correct? (as mentioned it seems it was installed the "wrong" way until now, which allows it sit a little bit lower on the sleeve hub).
Another question I have is regarding the drive plates, the service manual states that 7 of them are of one type, and the remaining one of another type. My kit contains 8 drive plates that seem identical to me . How do I identify the drive plate "no 2" (that should go first in the hub)?
deathu is offline   Reply With Quote
Old 04-14-2013, 10:49 AM   #75767
Zafo
Zafo's Avatar
Oddometer: 2
Hi Everyone,
I've been a street rider (cruiser) for many years and two years ago at the CADVR Rally I got the taste of dirt and haven't looked back. I sold my Honda Shadow and got a Suzuki DR650. I love it! Just wanted to introduce myself and say hi, "Hi". Thanks for all the great advice on this forum.
Zafo is offline   Reply With Quote
Old 04-14-2013, 11:05 AM   #75768
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,282
Originally Posted by Zafo View Post
Hi Everyone,
.....got a Suzuki DR650. I love it! Just wanted to introduce myself and say hi, "Hi". Thanks for all the great advice on this forum.
Welcome Zafo
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 04-14-2013, 11:32 AM   #75769
wayno
wayno's Avatar
Oddometer: 6,731
Originally Posted by deathu View Post
Hi,
Now as per the service manual, I try to install the replacement plates. First goes the washer seat: Then the concave washer (judder spring), with the orientation as per the service manual, with the raised edge towards the inside of the sleeve hub:
See if this helps: http://drriders.com/topic5244.html
RIDE SAFE
wayno is offline   Reply With Quote
Old 04-14-2013, 01:05 PM   #75770
deathu
deathu's Avatar
Oddometer: 77
Originally Posted by wayno View Post
Thanks a lot! The information was extremely useful to me, although I didn't have the necessary number of c-clamps available, the thread inspired me so I did my own "circular" clamp/vice . I just sandwiched the assembly between two old sprockets and the stopper ring went on ridiculously easy.
Once again thank you for the help. That really saved me from a lot of trouble.
Old 04-14-2013, 01:08 PM   #75771
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,685
Originally Posted by thump! View Post
The OEM battery is a sealed (AGM or gel) and doesn't leak acid when the bike is on it's side. Might not matter to you but that's important to me. Some of the cheaper replacements in this size are not sealed.
And the DR runs its battery tilted anyway so an unsealed lead-acid battery is just inviting problems.
Emmbeedee is online now   Reply With Quote
Old 04-14-2013, 05:05 PM   #75772
frecks
frecks's Avatar
Oddometer: 246
Originally Posted by JagLite View Post
Not a dumb question at all as many of us have struggled to get it back in.
First thing, the shop manual is wrong.
It says to put it in from the left side (shifter side).
That will waste a lot of your time like it did for me.
Finally I realized the picture (drawing?) they show is NOT the '96+ bike frame.
Our bikes have a removable engine mount on the RIGHT side, not the left.
OK, next thing to know is it will only go in by slightly twisting or rotating it to get the bump on the front of the engine case in between the frame rails.
Once you get that started in you adjust the engine so it will squeeze into position.
Many have found that laying the engine on its right side and then lowering the frame down over it was easier to do.
I used my engine hoist and lowered the engine on its side down into the newly painted frame so that I wasn't trying to support the 100+ lbs engine and work it into the frame.
It will go in fine with the side case covers on, but no carby of course.
It can certainly be done with the bike vertical or on the kick stand.
The problem is that if you are trying to support the engine weight AND wiggle it around you may injure your back.
Or your hands as they get trapped between engine and frame.
Or your sanity since you know it came out, but???!!!
I stick the front engine mount plate and bolts in as soon as I can as that holds it in one plane while lining up the other bolts.
First time is often painful and frustrating.
Your post got me thinking and I realized that a neighbor has a lift built into his garage for removing the hard top from his jeep. We laid the bike down on its right side, lifted it up, put the engine on its right side on top of a milk crate, and lowered the frame right down on top of it. It was super easy. Saved a ton of time. Thanks so much for the suggestion.
frecks is offline   Reply With Quote
Old 04-14-2013, 06:57 PM   #75773
ER70S-2
ER70S-2's Avatar
Oddometer: 6,483
Originally Posted by Carl Childers View Post
I'll be in the market for another battery soon, any feed back on a good quality replacement? I'm not looking for a high dollar high end battery just a good middle of the road unit.
I got 6 years on my original Yuasa and changed it (with another) for no other reason than because I thought it might be time. Sure I'd like a 2oz battery . But I don't trust the new technology, Boeing comes to mind.
Hey, good photos, everybody loves good photos.
Thanks for showing us your solution, it will most likely be passed on to the next rider having similar issues.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 04-14-2013, 06:59 PM   #75774
barko1
barko1
barko1's Avatar
Oddometer: 3,352
Anyone know where I can buy one spoke
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 04-14-2013, 07:20 PM   #75775
procycle
procycle's Avatar
Oddometer: 2,321
Suzuki does not sell them separately. You can have a single spoke custom made by Buchanan's.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 04-14-2013, 08:19 PM   #75776
JagLite
JagLite's Avatar
Oddometer: 1,251
Cool2 DR650 is a winner. Officially! (Even in disguise)
Yes, it amazed me too.
The judges at our annual motorcycle show placed my bike first in the "Adventure Bike" class proving the DR is a WINNER!
Of course my bike is "slightly" modified from stock...
Here is the "Before" picture I put up at the show:
And here it is today:
At the show:
Not only did it get a trophy, but also a $100 check!
I didn't know they gave trophies let alone cash prizes too.
2nd place went to a beautiful fully farkled ($25,000?) 2012 BMW GS.
The billet aluminum oil cooler didn't arrive in time so I painted and reinstalled the stock one but it sure sticks out with the skinny tank.
Fortunately the Warp 9 chain guide from PC arrived just in time to bolt it on.
Now, if I could get ProCycle to sponsor me for a 790 kit...
Jeff, that's a hint...
In case you are wondering, those are fiberglass case guards made with black tinted epoxy then sanded for the sand cast look.
They are held on with Industrial Velcro so I can peel the right side off to change the oil filter, and the left side when desired.
They are 1/4" thick and incredibly strong as well as protecting the entire side covers.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 04-14-2013, 08:24 PM   #75777
ER70S-2
ER70S-2's Avatar
Oddometer: 6,483
205'd by JagLite:
Damn, that looks great, nice work.
After ruining my one gallon auxillary tank (hokey but completely functional) in a low speed tipover (flat front tire), I decided that it's time to upgrade to one of the 5 gallon tanks available for my DR. I chose the Acerbis 5.3 because it's a bit more modern and its angularity matches the DR headlight cowl. I really don't care about appearances, it's a dirt bike....................see my sig. I chose the natural color because I want to be able to see my fuel level. I had always reset my odometer when fueling, and the DR was very consistant with when it hit reserve, but I wanted visual feedback. If you look closely, you can see the fuel level, right at the top of the A. It's much more obvious in real life. The dots mark each gallon, in this pic, the bike is on the side stand so the fuel level doesn't align with the dots.
Tonight, as I was headed to the store, I glanced over at the bike (level on the stand)..................... kewl, I have 1/2 a tank. There's no way I'd have known that without looking at the odo.
But for those of you that are concious of appearances, this is what mine looks like at 900 miles. I used some Zep high performance degreaser something or other to try to clean the smudge, it didn't help, not even a little bit. I don't care, dirt bikes are for riding, any aftermarket plastic tank is likely to stain; white and natural are probably the worst. You take yer chances.
Edited to add a tip from TrophyHunter:
Originally Posted by TrophyHunter View Post
Cleaning the rub marks on the tank.http://www.amazon.com/Nu-Finish-Liquid-Car-Polish/dp/B000BPSW7C
I'm not fanatical about it but enjoy keeping up the appearance of the bike. The Nu Finish is a fine enough compound to remove stains and fine scratches.
2013 WR250R
ER70S-2 screwed with this post 04-15-2013 at 10:40 AM
Old 04-14-2013, 10:56 PM   #75778
bluegroove
Motorcycle junkie
bluegroove's Avatar
Oddometer: 444
Question Eibach spring identification?
My bike has a rear spring that's too stiff. The previous owner said it's Eibach 8.0. Is there anything on the spring that will verify this rate?
Anybody got a softer one to sell me?
thanks
Former Mechanic in Honda and Kawasaki Dealer (eons ago). 38 yrs. of riding and racing dirt and street.
bluegroove is offline   Reply With Quote
Old 04-14-2013, 11:14 PM   #75779
bluegroove
Motorcycle junkie
bluegroove's Avatar
Oddometer: 444
oh also - anyone know the rate of the stock spring? Just as a reference point...
my bike is 2006
Old 04-15-2013, 03:46 AM   #75780
thump!
thump!'s Avatar
Oddometer: 1,444
thanks
Rick at Cogent Dynamics ( http://motocd.com/) has a box full of stock DR650 springs (including mine) that he sends to the metal recycler from time to time. I bet he would give you one for the cost of shipping.
thump! is offline   Reply With Quote
Times are GMT -7.   It's 03:24 AM.
