Old 04-25-2013, 01:22 PM   #76111
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,528
Originally Posted by thump! View Post
Your aftermarket clutch lever may not fit as precisely as the Suzuki part. In the picture it appears that the shoulder of the lever pivot bolt is not pulled down into the lever. If that's the case it would result in a lot of free play.
The lever pivot bolt is in as far as it can go. It's shouldered. Probably so it'll work with crappy Suzuki hand guards which attach at that point.
Bronco638: The gap between the lever and mount could be just standard cable slack. I have not been back out to the bike to see if I can make it line up properly. Will check later.
Old 04-25-2013, 01:40 PM   #76112
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,528
Originally Posted by Bronco638 View Post
I have the same slight gap between the clutch lever and the perch. Does that indicate an issue with the perch/lever pivot point or is everyone's DR like that?
Both of ours line up perfectly.
Old 04-25-2013, 02:22 PM   #76113
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,348
Originally Posted by bross View Post
Bet he was wishing he was wearing gear instead of a silly police uniform.
Old 04-25-2013, 02:36 PM   #76114
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,468
Actually had my Husky 610 foot peg bolt shear right off. That sucked ill tell ya.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 04-25-2013, 05:01 PM   #76115
sunthechip
Oddometer: 123
Is it necessary to remove the spark plugs when adjusting the valve clearance, and why do people take them out?
sunthechip is offline   Reply With Quote
Old 04-25-2013, 05:19 PM   #76116
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,348
Just one. It makes it a hell of a lot easier to turn the motor over that way to get to TDC.
Old 04-25-2013, 06:10 PM   #76117
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,232
And he should know that there are two top dead centers. Make sure to get the right one on the compression stroke.
Sent from my DROID RAZR MAXX HD using Tapatalk
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 04-25-2013, 06:49 PM   #76118
sunthechip
Oddometer: 123
I've adjusted the valves before, I just didn't remove the spark plugs. Turn it CCW until T is visible and the rockers can wiggle, right?
Old 04-25-2013, 08:22 PM   #76119
ER70S-2
ER70S-2's Avatar
Oddometer: 6,109
2004 DR650: 62,402 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 04-26-2013, 07:01 AM   #76120
TDY
TDY's Avatar
Oddometer: 194
Charging system question
I recently ran my battery down with electric vest and grip heaters set too high on a cold day so I installed an LED voltage monitor to keep me from making the same mistake again. The battery charged up fine with my battery tender and seems not to have suffered any damage. The LED monitor glows green when the charging voltage is greater than 13.2V but, curiously it changes to yellow indicating less than 13.2 when I rev the engine above idle then returns to green when the RPM returns to idle. I verified this voltage drop measured at the battery using a real volt meter. I then discovered that if I turn on my grip heaters the voltage goes up and turns the LED green and it stays green at all revs.
This all seems backwards to me. Could someone please verify if it's normal to have a load such as the grip heaters raise the voltage or explain to me the problem if it's not behaving normally. I did the alternator checks for continuity and AC output and it checks out fine.
In case it matters, I have a 60Cx GPS running off the battery and I had the controller for my vest plugged in but not turned on and the vest was not plugged in during my last test ride. The lights are all stock but the headlight is running through a relay to reduce voltage loss.
'15 FZ-07 (new road toy)
‘01 DR650 (work horse)
'08 CRF230F (fun in the trails)
'08 CRF100F (no trail too tight)
TDY is offline   Reply With Quote
Old 04-26-2013, 08:57 AM   #76121
8gv
Oddometer: 2,370
Fool tap...
I want to drain my tank and put in fresh gas.
The tap doesn't want to dispense while the bike isn't running.
Is that a vacuum line I see attached to the back of the tap?
Using a hand vacuum pump I appied vacuum.
No joy.
Is pressure used here rather than vacuum?
Do I need to open the tap and de-goo it?
Is there really no inline filter here or is it contained in the tap?
Thank you sir, may I have another...
8gv is online now   Reply With Quote
Old 04-26-2013, 09:15 AM   #76122
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 3,948
Yes.
No joy.
No.
Maybe. Have you tried the Prime position?
There is a screen in the tank as well as one in the stock carb inlet.
Answered in yellow above.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 04-26-2013, 09:35 AM   #76123
8gv
Oddometer: 2,370
Thanks.
I tried Prime and got a dribble. A roaring torrent is required by my level of patience. Is the screen in the tank located at the top of the fuel tubes?
Old 04-26-2013, 09:48 AM   #76124
Lil' Steve
Lil' Steve's Avatar
Oddometer: 3,948
Thanks.
Yes, there should be a screen on both tubes. You can take it apart and clean it, but a wise man said not long ago...
but if you do, Yamaha Raptor tap about $20, that's what I use.
The Yamaha tap bolts right on and isnt vacuum operated, you can turn it to off unlike the stock Suzuki tap.
Steve
Old 04-26-2013, 09:57 AM   #76125
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,791
I'm using the stock lever(s).
Thanks M.
Not only do I have that small gap, I can't seem to get rid of it. The clutch travel is very short; that is, from unengaged to fullly engaged seems to happen very quickly. I have the clutch arm positioned properly (I think) and the cable is new.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Times are GMT -7.   It's 11:55 AM.
