Old 04-26-2013, 07:50 PM   #76141
ER70S-2
ER70S-2's Avatar
Oddometer: 6,274
Originally Posted by acesandeights View Post
Think it's more related to miles or time? How many years before you had 15k miles?
That's possible. I installed the 2nd set (that's in there now) Sept 2011, at 26,600 and they're very hard too. It took me six years to get to 15k (2010), I've been making up for lost time over the last three years.
2004 DR650: 62,496 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 04-27-2013, 07:07 AM   #76142
dentedvw
Where did I put that
dentedvw's Avatar
Oddometer: 2,158
Yesterday I bought another rider's (maybe an ADV rider?) DR project. It was located at Edge Motorsports in Draper, UT. It was a bit spendy, but it had all the bits I was looking for, and I don't have to go and add them. It rides nice, and once the electrical system was properly buggered with by the shop, it even started, had a horn, and brake lights.
One thing I wouldn't have done though is the Ti street bike exhaust. Huyabusa, or something like that. Here is the problem, it's loose. Real loose. So loose that some of the exhaust comes out the front of the can, but most out the back.
Does anyone know how these are supposed to be properly installed? Is it possible the pipe hasn't been flanged properly, or is there a plate that might be missing? Some kind of gasket?
And since I don't know anything about this exhaust, can it be repacked? It's a bit loud, but perhaps that's a function of some of the exhaust exiting the front of the can.
Since this is my first DR650, and it's used, what should I be checking for? It's only got a bit under 2k miles, and it's a 2008.
"Even though my trip turned out badly, I don't regret the kind of life I chose to live. Adventure!" RIP-Clay Schwartz 9/14/07
The bike never has been, never is, and never will be the limiting factor in my, your, or anyone else's ability to have an adventure. -jake28-
dentedvw is offline   Reply With Quote
Old 04-27-2013, 07:25 AM   #76143
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,827
Originally Posted by dentedvw
...One thing I wouldn't have done though is the Ti street bike exhaust. Huyabusa, or something like that. Here is the problem, it's loose. Real loose. So loose that some of the exhaust comes out the front of the can, but most out the back.
Something is not right. There should not be any gases escaping at the front of the can. Check KienTech's web site. I believe there is a gasket that goes between the mid-pipe and the can. I have a 40 (GSXR750?) can on my DR and I think it sounds great. Not loud at all.
Make sure the oil has been changed, check for loose fasteners/bearings, check the air in the tires and enjoy. This is my fourth DR (of various displacements) and they are some of the most maintenance free vehicles I have ever owned.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 04-27-2013, 09:24 AM   #76144
JagLite
JagLite's Avatar
Oddometer: 1,194
Question What muffler is it?
What exactly does it say on side of the muffler?
If it is a Suzuki muffler it will have the part number and the usual disclaimer.
On the end cap it might say Titanium, certain ones do.
If it is a stock Suzuki muffler from another bike, it does NOT need repacking, ever.
It WILL use a gasket between the mid-pipe and muffler, inside the bolted flange.
If it is not a Suzuki muffler then it probably does require repacking and it may always be too loud.
Can you post pictures of the muffler, the front flange connection to the mid-pipe, and the muffler hanger tab?
If it is not a genuine Suzuki muffler that will help us figure out what it is.
The mid-pipe also has a gasket between it and the headpipe, could that be leaking?
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 04-27-2013, 09:31 AM   #76145
dentedvw
dentedvw's Avatar
Oddometer: 2,158
I will definitely post the part number, I pick it up this morning, as soon as my wife gets out of the shower.
It's a Suzuki unit for sure, I didn't remember the number on it though, and it does say Titanium on the end.
How can I check some bearings while I am at the dealer? When I was riding it, there was some rattles I couldn't identify right away. Some of it was probably the can, and also it has one of those helmet lock dangly things on the back because of an aluminum rack in the way of the lock.
The speedometer is a bit hard to read, tucked away as it is in the clutter of the handle bar area. Is there a way to make it more visible? Perhaps moving it up?
I have always had good experiences with my DRZ, and I hope for the same from the DR. It's one of the reasons I chose a DR over a KLR.
Old 04-27-2013, 10:27 AM   #76146
TrophyHunter
Oddometer: 2,189
The rattling sound may be the upper chain roller. It was on mine. Go back 10 - 20 pages on this thread and read everything. It repeats often.
With any bike I pick up, I go front to back checking every nut & bolt, adjustments, etc. I buy the shop manual and measure tolerences - reasonable here - stuff I can see and get to without disassembly. Edit: 'cept the valve adjustment. Unless I know the shop or PO just changed the oil/filter & cleaned the air filter, that gets done.
I was raised by a mechanical engineer and my first 2 bikes came home in pieces. "you wanna ride, you'll have to learn about bikes" One of the best things that happened to me.
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter screwed with this post 04-27-2013 at 12:45 PM
TrophyHunter is offline   Reply With Quote
Old 04-27-2013, 05:23 PM   #76147
Thumper Dan
Oddometer: 325
x ring and DID x ring
Apologies if this topic has been discussed a hundred times previously ( I did search).
I need to know the difference between an x ring chain and a "DID x ring chain"?? There seems to be a bit of a price difference between the two. Obviously the DID x ring would be superior quality which is reflected nearly double the cost of a standard x ring chain.
cheap: http://www.ebay.com.au/itm/370283100...84.m1423.l2649
expensive: http://www.ebay.com.au/itm/DID-X-RIN...1610e11&_uhb=1
thanks
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan screwed with this post 04-27-2013 at 05:29 PM
Thumper Dan is offline   Reply With Quote
Old 04-27-2013, 05:32 PM   #76148
bross
Where we riding to?
bross's Avatar
Oddometer: 4,530
thanks
I'd say pretty obvious but not stated, the cheaper one is no doubt from China, while the DID is a Japanese chain. Your choice.
Old 04-27-2013, 05:51 PM   #76149
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
thanks
DID is a Japanese company that has been making chains for decades. One of the best in Japan and first to use X ring technology on chains, as opposed to O ring. DID make a variety of chains for the DR650. The best are the X ring series. Previous VM-2 series (now super ceded) may still be available and a bit cheaper. But the current line is the VX Series chains.
In the USA DID are now offering complete kits ... chain and sprockets. I don't know who makes the sprockets but I assume they are Japanese made? (a good thing).
The cheap chain shown in your link is most likely a Chinese version. NOTE that no where in the Ebay blurb do they say where the chain is made. This should be a warming.
The Chinese are doing many things very well and progressing rapidly in quality. But AFAIK, their chains are not much good at this point. I'm sure this will change soon ... you can never count them out. But once they make chains as good as DID, RK, Regina or EK, the cost will probably be close to the same as Japanese chains.
FYI, i've put around 200,000 miles on DID X Ring chains. All good, tremendous service life, low maintenance.
Old 04-27-2013, 06:04 PM   #76150
GotDR650
GotDR650's Avatar
Oddometer: 22
Hi guys, its been a long time. I've been out testing my HD Drift Cam and i'd like to share a couple of vides with you.
More to come this Season (If summer ever reaches Germany) ;(
Hope you enjoy
http://www.youtube.com/watch?v=jdDIjBkr5z8
Tobi
DR 650 Dakar
DR 650 R
DR 650 RSE
DR 650 SuperMoto
Yamaha TX 650
Yamaha XJR 1300
BMW R75/5 Toaster
BMW R90/6
BMW R1100GS
Suzuki GS1000S
GotDR650 is offline   Reply With Quote
Old 04-27-2013, 06:27 PM   #76151
crash alot
crash alot's Avatar
Oddometer: 188
did i get taken?
pulling the bike apart to put on acerbiz tank and another 1000.00 of goodies, anyway this is the back bone on my frame, does this look right? I think its been wrecked, it seems to ride ok, however I did think the bars were just a little bent.
did a search and cant seem to find any pictures of a bike without the tank on.
07 bmw k1200s..78 CB 550 custom
08 450 husaberg...klx 140L
05 ktm 950 adv
2011 ducati multi 1200 S
2011 DR 650......12 ural gear up
crash alot is offline   Reply With Quote
Old 04-27-2013, 06:32 PM   #76152
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,592
That is horrible! I think you have been taken, depending on how much you paid.
Old 04-27-2013, 07:28 PM   #76153
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,487
Seems they crushed it in to fit some other tank?
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 04-27-2013, 07:51 PM   #76154
JagLite
JagLite's Avatar
Oddometer: 1,194
Pissed Totaled DR
YEEEEeeeeeoooooooooooocccccccccchhhhhhhhhhhhhhh!
That frame is toasted!
That is the worst DR frame damage I have seen
I am guessing the flat spots are where they pressed it with a hydraulic press to try to straighten it.
That is a potential lawsuit there...
That said, the Dr is amazingly stout and if the wheels are in line it will probably ride fine.
If you are comfortable riding it that is.
I doubt the frame is repairable and that much damage to the frame may be accompanied with other hidden damage that was caused by the same wreck.
Look for cracked or broken engine mounting bosses on the cases as well as stress cracks.
Probably not an option, but if you can get your money back I would strongly recommend it!
If you are stuck with it, look for a good used frame or a bike with a blown up engine.
I am sorry to see that you are the victim of a very dishonest person selling something without disclosing the damage history.
Of course, it is possible the one who sold it to you didn't know either...
Best wishes in a difficult situation brother
Attitude ~
James
Old 04-27-2013, 07:52 PM   #76155
Adv Grifter
Oddometer: 6,128
Was that a rebuilt insurance deal? Or maybe you got one of those Moto Kiwi DR's that were "lightly crashed"? From Arizona? Whatever, looks serious.
RETURN TO SENDER! Sorry to see that.
PS: There is a guy who is about to part out his DR over on DRRiders.com. His engine is toast but rest of the bike is fine as far as I know. Good luck!
Times are GMT -7.   It's 07:16 PM.
