Old 04-28-2013, 04:58 PM   #76186
ER70S-2
ER70S-2's Avatar
Oddometer: 7,221
Jay:
No one has mentioned the acceleration and deceleration ramps on the cam lobes. They're cut to lift and close the valves gently. If your clearances are too loose, the valves are getting slammed open and dropped shut. I'd redo them.
I wish I was there and you were here.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 04-28-2013, 06:33 PM   #76187
crash alot
crash alot's Avatar
Oddometer: 182
Originally Posted by JagLite View Post
This picture and the comments of others brings into question the engine mounts even more. Remove one engine mount bolt at a time and see if the bolts all slide in and out easily. IF the frame is bent and is putting stress on one or more of the engine mounts, the bolt will be jammed in place and under tension. NOT acceptable.
That would mean that the engine is holding the frame in shape and that can lead to the stresses on the aluminum engine case mounts could crack the cases over time and vibration.
All the great stuff you have bought will transfer to any DR so that is not lost money.
As mentioned by others, a crash that could bend a frame like that would have destroyed the forks and front wheel also so those parts, and probably the triple clamps too, have been replaced. Most likely from another crashed DR.
If you got a super good deal on the bike it MIGHT be worth keeping.
On the other hand, there are a lot of very good used DR's for sale.
You could send him a text that you want to give him an opportunity to make things right BEFORE you go to the Police and report him for FRAUD and go to the DMV to alert them of a suspicious seller of damaged (unsafe) vehicles.
If he is innocent of knowing about the damage, he will give you your money back.
If he is guilty, he will WANT to give you back your money to keep the Police from knocking on his door.
Keep in mind also that you will NOT be able to sell that bike for what you have in it. Not even close.
You could go visit the Police and, keeping the seller's name out, discuss what they recommend you do to get your money back.
I had a "situation" and after talking with a nice lady cop she offered to accompany me. That made a big difference.
The advice "talk softly and carry a big stick" came to mind.
No charges made, no problem for anyone, but the other person knew he was now on the Police radar.
Just a few more thoughts for your rotten situation.
we want to help any way we can...
no stress there, bolts will come right out (motor mount). from what I can figure, it was straightened ok but not perfect, im not out a shit load of money on the bike, 3300.00. which would have been a good deal, but now the bike is not worth that in this condition, nor would I have bought it. I think the steering head is a couple degrees out of plumb, like someone said, probably not a big deal with knobbies and dual sporting but would not be good for super moto or curve carving.
the guy will not return my text or a stern voice mail with me asking for an explanation. he knew
most likely ill put it back together and sell it to one of u guys and wait for u to discover the totaled frame.
just kidding.....I think ill stiffen up the bent backbone with some pipe cut in half, trick it all out with my stuff, go to Utah in June, and ride the shit out of it. ( tat Utah section to Nevada and back). ill be looking for a silver frame and swap everything out over the winter. used frame that is, ( new frame 1600.00)
win some, lose some.........josh, if your on this forum (don't know if he is an inmate)....go f yourself
07 bmw k1200s..78 CB 550 custom
08 450 husaberg...klx 140L
05 ktm 950 adv
2011 ducati multi 1200 S
2011 DR 650......12 ural gear up
crash alot screwed with this post 04-28-2013 at 06:54 PM
crash alot is offline   Reply With Quote
Old 04-28-2013, 11:25 PM   #76188
Jammin
Living on a DR
Jammin's Avatar
Oddometer: 1,563
Originally Posted by Mongle View Post
it will be noisy and a little down on power. By having more clearance the valve is not opening as much. I have never done it on a bike but if we put too big of a cam in a boat motor we have put more clearance on the rockers with no issues. I can't imagine a bike being any different. Really if you think about it the exhaust are set at .2mm and there is no problems. They usually run less on the intake just because it doesn't get as hot and expand as much.
I always use my rear wheel to find TDC- I worry about breaking that dang cap. Makes it a little easier if someone spins the wheel so you can watch valves and TDC marks.
Good luck!
Thanks for the quick reply. I spun the wheels and got it adjusted properly.
Originally Posted by BergDonk View Post
They are a fair bit loose and will hammer the tappet screws and valve stems more as a result. Will it cause any damage, dunno. But revving it will make it worse.
I did the valves on a mates bike the other day. We suspect it was the first time they'd been looked at at 20,000 kms. The inlets were both loose and needed tightening up, and 1 exhaust was loose too. Much quieter now. Were they originally this loose, or did they loosen over time, dunno.
FWIW, I posted this a while back, its how I do the valves:
http://www.advrider.com/forums/showp...&postcount=371
Thanks for the informative link. Good to know about spinning in the wheel in 5th gear. I got it adjusted and she's happy now
Originally Posted by ER70S-2 View Post
Jay:
Yup, figured best to redo it and got it done. Sounding much better now
J A Y on a 98 Suzuki DR650SE (sanDRina)
Trip Website: JamminGlobal.com
Current Ride Report: Global South | Past Trips: CDR '09, Alaska '08, Mexico '07 | YouTube Videos
Jammin is offline   Reply With Quote
Old 04-29-2013, 06:46 AM   #76189
Jammin
Living on a DR
Jammin's Avatar
Oddometer: 1,563
Cool2 About sanDRina, a 1998 Suzuki DR650 in Adventure Spec
April 29, 2013
Here's a video detailing why I chose the Suzuki DR650 as my bike of choice for my three-year motorcycle journey from Chicago to Delhi and then specifically, what are all the features on sanDRina that bring her up to Adventure Spec
Details on Aqualine Safari Tank, Pivot Pegz, WER Steering Stabilizer, Fork Brace, Happy Trails Panniers, Vapor Dash Computer, Galfer Rotors, Answer Handlebar, Ricoh Intiminator, Touratech GPS Mount, Vision X LED Lights, Suzuki GSX-R1000 Titanium Exhaust, Scotts Stainless Steel Oil Filter and more...
(this video was shot before I properly set the valves, so they sound really loud )
Click here for more Videos
Old 04-29-2013, 06:54 AM   #76190
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,899
As for me,I wouldnt ride a bike with a frame that looked like that. The thought of a frame breaking and being crooked to start with is not a good one.
It had to be REALLY bent to have to make the backbone look like that to sorta straighten it.
Going by his place with a cop in tow would be fun.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-29-2013, 07:04 AM   #76191
Foot dragger
singletracker
Oddometer: 12,899
Originally Posted by Adv Grifter View Post
Some interesting comments about the Bent frame. Shame.
But there are specialists who can straighten frames properly. We have a guy out here in Sacramento, California called The Frame Man. He mostly straightens bent race bikes. Impressive results.
Using Laser alignment, specialized Jigs and hydraulic presses ... those guys have straightened up hundreds of wasted bikes. These specialists are rare, no idea if the OP has any such shops in his region, but might be worth it to look around.
In normal circumstances ... as mentioned ... that frame would be junked. But if the buyer is over a barrel money wise, then straightening might be solution?
If the steering is off it could be simply tweaked forks (easily fixed in 5 minutes) or tweaked rubber dampers below the bar mounts on top triple clamp. Also easy fix ... just push them the opposite way. Bent bars are rare
but with the crash that bike was in, certainly possible. Bars are cheap.
Replace if needed.
If after the forks are straightened (just loosen clamps and tighten back up) and bars are straight in dampers, the bike still is "off" when riding, then its likely the FRAME is not straight.
Weird handling is the other obvious tell tale. Handling should be 100%
neutral. If not ?? ... well, do what you can to fix it.
I have a feeling if the Frame Man looked at that frame he would pass as its destroyed/kinked/badly straightened already.
Its a total not a slightly bent frame, and every weld and tube on the rest of it would be suspect. Considering how cheap a DR can be had with a blown engine its not worth it trying to save that frame.
Its a 400 lb bike,that frame could easily come apart elsewhere.
Old 04-29-2013, 07:05 AM   #76192
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 4,089
What's been done to that frame has created weak points and places where the frame will crumple in a much lower impact. Stiffening that area may or may not be a good idea, but ultimately it will need to be replaced. Even at $1600 for a new frame that's not too much money for a 2011 with only ~3000 miles.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 04-29-2013, 07:17 AM   #76193
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,723
I'd be getting in touch with law enforcement. Probably Motor Vehicle Dept.
Sue in small claims court if you must. This was fraud, and if you sell the bike in this condition, without disclosure you will be the one who gets sued.
You were sold a vehicle that is "unfit" for safe operation. Get your money back by whatever means necessary. Or at least enough for a new frame + time spent swapping it.
Best of luck.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 04-29-2013, 07:22 AM   #76194
blackcap
blackcap's Avatar
Oddometer: 550
quick plug for Chaingang sprockets from australia. the following photos are from my DR after 36 000km most of it through rain, mud, sand and rocks on a fully loaded RTW DR that had a pretty average maintenance routine. also ive got a set of brand new sprockets from chaingang over in the flea market (ordered 525 like an idiot when i wanted 520, no selling the 525s so i can afford some 520s).
"One must die sometime and to die with ones boots on is very noble" - Carl Stearns Clancy, first RTW motorcycle, 1912-13
Australia to Iceland on a DR650 http://oztoice.wordpress.com
and facebook https://www.facebook.com/oztoice
blackcap is offline   Reply With Quote
Old 04-29-2013, 07:42 AM   #76195
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,931
My thoughts exactly. I wouldn't trust that frame at all no matter how much bracing was added.
Old 04-29-2013, 07:55 AM   #76196
JayHawk
Grandpa to 3
JayHawk's Avatar
Oddometer: 138
Like the others have said. Contact the law, keep after him, never let a thief get away with it. What if that insufficient repair had led to catastrophic failure?
'07 DR 650
JayHawk is offline   Reply With Quote
Old 04-29-2013, 11:22 AM   #76197
dentedvw
Where did I put that
dentedvw's Avatar
Oddometer: 2,175
I thought my new (to me) dr was a bit short, so I peeked at the dogbone, and sure enough it could come up. So up it went, and it's more comfortable for me now.
Only, the sides stand is now too short. Any shorter stature Utah residents want to trade with me?
It's a stock looking unit, real nice, but a light grey, not dark like the rest of the bike's steel. It doesn't look like a chopped job, but probably aftermarket, judging by the quality of the welds and paint.
"Even though my trip turned out badly, I don't regret the kind of life I chose to live. Adventure!" RIP-Clay Schwartz 9/14/07
The bike never has been, never is, and never will be the limiting factor in my, your, or anyone else's ability to have an adventure. -jake28-
dentedvw is offline   Reply With Quote
Old 04-29-2013, 11:37 AM   #76198
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I suspect you are correct. The Frame Man would most likely avoid due to liability given it's a street bike. It'd be a Lose/Lose for him. I've seen some Alu beam frames he straightened on race bikes ... but very minor bends compared to that poor DR.
I've used the Frame Man many times over the years to straighten bent wheels. (TDM 850, VFR800, KTM Duke ll, V-Strom). The V Strom cast wheel eventually cracked all the way across. New owner had to replace the wheel. He lucked out, found a used one cheap.
Old 04-29-2013, 11:48 AM   #76199
Adv Grifter
Oddometer: 6,128
Originally Posted by Jammin View Post
April 29, 2013
Thanks for the Video Jay. Well done Vid!! (next time? a lavalier mic .. remember, I'm a movie sound man!)
Well done explanations of all your good mods. I loved your emphasis on simplicity. The DR650 certainly has that. But it's also got just plain good engineering and QUALITY parts. The Suzuki SACS system is, in large part, why the "air cooled" motor lasts so well and survives abuse. It's brilliant engineering, elegant and simple.
I had predicted your switch fuse block would fail. You proved me wrong! Well done Jay! Well thought out and well executed wiring mods can survive
60,000 miles of Hell! Hope you can keep your ride report going after India and let us all know what you end up doing.
Old 04-29-2013, 11:52 AM   #76200
joefromsf
Dark Happens
joefromsf's Avatar
Oddometer: 1,578
Question Sump oil screen accessibility
Anybody know how accessible the sump oil screen is on the DR?
Its #10 in this diagram http://www.mrcycles.com/fiche_sectio...0#.UX649MqQOyA
I had my oil sight glass poked out (actually in) by a downed tree branch and am trying to flush out the engine. Details here: http://www.advrider.com/forums/showthread.php?t=882879
Based on peering in from the left side where I have the clutch cover off, I think the sump oil screen is only accessible by splitting the cases. But there is a slim chance it could be accessible under the stator cover. Anybody know for sure?
Alternatively, does anyone have any good photos of what it looks like under the stator cover. Need a view that is very low, without the stator in place or the area below the stator.
BTW, this is the cliff jumping DR made famous by my crash video. After scores of hours, I finally got it running this weekend and then this freak incident happened two hours into my first shakedown ride.
joefromsf is offline   Reply With Quote
Times are GMT -7.   It's 10:36 PM.
