Old 05-07-2013, 05:38 AM   #76381
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 729
Originally Posted by french horn View Post
I know this is an old post but it got me thinking.
I have added panniers etc. with the intention of touring/camping, I feel my suspension is a bit saggy when fully loaded and was wanting to learn a bit about upgrading it.
My question to the vast think-tank: HOW do I work out what rating springs (front/rear) I need ... or what "specialist" should I contact?
I'm not too well off so if a cheap way of doing it is available, that'd be good as well.
Cheers guys.
Want to do it on the cheap? When you have the bike loaded up for travel increase the spring preload to the DR shop manual specification for the stiff setting it's a simple measurement and easy to do. Travels over and luggage off? Set it back to to standard or soft. Truth is the stock shock is not all that bad when set correctly for intended use. I ride my DR pretty hard off road and do extended trips in the back country and the stocker is just fine. I'm saving my $$ til it actually needs a rebuild. The front forks are a different story they definitely need some help, a pair of intiminators made a big difference with mine.
New Mexico, not really new, not really Mexico.
Carl Childers screwed with this post 05-07-2013 at 05:49 AM
Carl Childers is offline   Reply With Quote
Old 05-07-2013, 06:21 AM   #76382
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 3,997
Originally Posted by Emmbeedee View Post
Anyone know if this tool is the right one for the DR650?
eBay ad here.
No, this is the right one.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 05-07-2013, 06:29 AM   #76383
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,947
You can check what Race Tech thinks at http://www.racetech.com I think their settings fall on the firmer side of things (more dirt performance oriented), but it's definitely a start in the right direction.
You could also let us know what you weigh and how much weight you anticipate carrying and we can give opinions.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 05-07-2013, 06:33 AM   #76384
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,657
Figures - four times the price. Thanks for that.
Old 05-07-2013, 06:46 AM   #76385
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
You are darned lucky you got a stock shock that is pretty good,every time I rode mine stock even slightly hard with no load, it bottomed so hard and got so hot I was sure it would blow the seal out. Im only 180 lbs and the spring was too soft to set the sag right for me. I tried cranking preload all the way but it was still useless.
The wallowing drove me crazy mainly.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 05-07-2013, 06:50 AM   #76386
Foot dragger
singletracker
Oddometer: 12,856
Cheers guys.
www.kientech.com can maybe set you up a little cheaper suspension wise. When I put a full touring load on my DR with stock springs the Pelican boxes drug on the ground in corners.
Kinda distracting.
Old 05-07-2013, 08:07 AM   #76387
JagLite
JagLite's Avatar
Oddometer: 1,244
Eh? Huh?
Originally Posted by yegdod1 View Post
Anyone got a countershaft retainer seal for sale....? It needs to be shipped to Aust..
Uh, what is it you need?
The retainer seal?
I am pretty sure you mean you want the retainer FOR the countershaft seal.
ProCycle sells one but why not get one that is already in Australia?
Vic Strang sells them:
http://www.vincestrangmotorcycles.com.au/dr650.html
(near the bottom of the page in the "Chains/sprockets section)
From what I have read here, Suzuki dealers can get the new factory version now in Australia.
I have one on order here in the USA to see if we can get them yet.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 05-07-2013, 09:35 AM   #76388
poppawheelie
poppawheelie's Avatar
Oddometer: 562
Rider Sag
I know rider sag should be about 3" since the DR has 9" of travel (rear). What should it be with the link set on the lower setting? Does the bike still have 9" of travel? I doubt it.
OK, if the question was asked before, I pre-apologize, but I couldn't find it.
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie is offline   Reply With Quote
Old 05-07-2013, 11:29 AM   #76389
ER70S-2
ER70S-2's Avatar
Oddometer: 6,457
The travel changes from 10.2" to 8.7" front and rear.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 05-07-2013, 12:23 PM   #76390
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I know this is an old post but it got me thinking. I have added panniers etc. with the intention of touring/camping, I feel my suspension is a bit saggy when fully loaded and was wanting to learn a bit about upgrading it.
Cheers guys.
What is your weight? If over about 170 lbs. I would go to a heavier shock spring and heavier fork springs too.
The stock rear spring (I think) is about 6.5 kgs. I used an Eibach 7.6 kgs. (200 lb. rider) spring from Jesse at Kientech: http://www.kientech.com/
To go cheap on the forks you can add some pre load spacers on top of the ones already there. Use PVC pipe. Also, go up to 10 or 15 weight fork oil and add just a bit more than required.
Lots to do if you spend a bit of money. But you can start with above, but totally worth it to up grade everything if you really intend to ride the bike and tour on the bike.
Old 05-07-2013, 01:34 PM   #76391
poppawheelie
Oddometer: 562
Rider Sag
Front end is fine. I did Eibach Springs and Gold Valves last year. Just got the shock back from Cogent and wanted to set it up right. Got to thinking, I'm running the low setting so travel will be less.
oops There it is right in the Owners Manual, 8.7 " travel in the low setting. Regular is 10.2, not 9.
I only go 170 lbs, but with rider sag set at just 2", I've got way too much static sag at 1 3/4." Should have gotten the next step up in a spring.
Thanks everyone for advice. More?
poppawheelie screwed with this post 05-07-2013 at 01:42 PM
Old 05-07-2013, 01:55 PM   #76392
Carl Childers
Oddometer: 729
From reading all the posts here on shock problems I was going to send it off as a forgone conclusion and at the last minute thought to myself at least see if I can get it set to my liking and got pleasantly surprised.
Maybe I got a shock that was built on Wednesday but I wonder how many others like it are out there?
Unlucky at love, lucky at shocks.
Old 05-07-2013, 02:13 PM   #76393
thump!
thump!'s Avatar
Oddometer: 1,439
I'm about 220 lbs in riding gear and I've had as much as 80 lbs of luggage on the bike. have a Cogent shock now with a slightly stiffer spring. I like it and it is definitely better than stock but like you, in retrospect I don't think stock was all that bad. I believe ones assessment of the shock is highly dependent on riding style and locale. Very aggressive riders are probably the ones who find the Suzuki shock most lacking.
thump! is online now   Reply With Quote
Old 05-07-2013, 02:21 PM   #76394
newride
newride's Avatar
Oddometer: 704
Talking Cam chain tensioner gasket
hello all,
Has anyone had any experience changing this "simple" gasket out? I had heard that you should know what you are doing with this. I want to make sure I am not going beyond my ability.
http://www.flickr.com/photos/brewbik...in/photostream
1975 BMW R90/6
My moto blog: http://jbloggie1.blogspot.com/
newride is offline   Reply With Quote
Old 05-07-2013, 03:51 PM   #76395
Kommando
Kommando's Avatar
Oddometer: 7,378
Originally Posted by newride View Post
hello all,
Just be sure to set the engine to true TDC before removing the CCT. I do this by rotating the back wheel in 5th with a sparkplug taken out. You'll feel the air rush out of the cylinder as the piston approaches TDC. Do NOT rotate the engine once you start to remove the CCT. The cam chain could skip teeth on the timing sprockets if it's too loose.
Retract the CCT fully BEFORE trying to reinstall it. It should click into it's retracted and locked position. Once you have it fully bolted in, release it.
I used RTV high-temp gasket-maker, after scraping off the OEM gasket with some gasket remover chemical. My CCT hasn't leaked in over 10K miles now.
Kommando is offline   Reply With Quote
Times are GMT -7.   It's 06:46 PM.
